Every time i Maven Build or Maven install the project, it takes too long from 6 to 7 minutes.What is the solution for that ?
Hi Raidh,
What my hacks for this problem is..
1)instant of All-in-One Use repo and Share separately(rapo takes 3 to 4 min start and Share take 2 to 3 min to start in SDK 3)
2)If you are using SDK 3 then in Repo use Hot reloading it save a lot time..
if this is to much time for you then
3)use SDK 2 for development and migrate to SDK 3 at last and test all the things (not recommended by me if you are working in a team)(Repo take 2 to 3 min and Share also take 2 to 3 min to start)
I have 8GB RAM on my machine..If you have 12GB or 16GB machine then it also take less compare to me...
Thanks,Shyam Ghodasra
I don't think it's a matter of RAM, I have 12GB. But every time I run it, it downloads the dependencies again and again.Thanks.
can you tell us which dependency it download each and every time...?
This is an example of the output in the console :
[INFO] Configured Artifact: org.alfresco:aikau:1.0.85:jar[INFO] Configured Artifact: com.riadh:riadh-share-jar:1.0-SNAPSHOT:jar[INFO] Copying aikau-1.0.85.jar to E:\MavenProjects\riadh\target\share-war\WEB-INF\lib\aikau-1.0.85.jar[INFO] Copying riadh-share-jar-1.0-SNAPSHOT.jar to E:\MavenProjects\riadh\target\share-war\WEB-INF\lib\riadh-share-jar-1.0-SNAPSHOT.jar[DEBUG] Compressing 'E:\MavenProjects\riadh\target\share-war' into 'E:\MavenProjects\riadh\target\share.war'.[DEBUG] Configuring mojo org.apache.maven.plugins:maven-install-plugin:2.5.2:install-file from plugin realm ClassRealm[plugin>org.apache.maven.plugins:maven-install-plugin:2.5.2, parent: sun.misc.Launcher$AppClassLoader@5c647e05][DEBUG] Configuring mojo 'org.apache.maven.plugins:maven-install-plugin:2.5.2:install-file' with basic configurator -->[DEBUG] (f) file = E:\MavenProjects\riadh\target\share.war[DEBUG] (f) groupId = com.riadh[DEBUG] (f) artifactId = riadh-share[DEBUG] (f) version = 1.0-SNAPSHOT[DEBUG] (f) packaging = war[DEBUG] (f) createChecksum = false[DEBUG] (f) localRepository = id: local url: file:///C:/Users/AZZOUZ%20ROG%2001/.m2/repository/ layout: defaultsnapshots: [enabled => true, update => always] releases: [enabled => true, update => always]
[DEBUG] (f) repositoryLayout = default[DEBUG] (f) updateReleaseInfo = false[DEBUG] -- end configuration --[DEBUG] Using META-INF/maven/org.alfresco/alfresco-web-framework-commons/pom.xml for groupId, artifactId, packaging and version[DEBUG] Skipping installation of generated POM, already present in local repository[INFO] Installing E:\MavenProjects\riadh\target\share.war to C:\Users\AZZOUZ ROG 01\.m2\repository\com\riadh\riadh-share\1.0-SNAPSHOT\riadh-share-1.0-SNAPSHOT.war[DEBUG] Writing tracking file C:\Users\AZZOUZ ROG 01\.m2\repository\com\riadh\riadh-share\1.0-SNAPSHOT\_remote.repositories[DEBUG] Installing com.riadh:riadh-share:1.0-SNAPSHOT/maven-metadata.xml to C:\Users\AZZOUZ ROG 01\.m2\repository\com\riadh\riadh-share\1.0-SNAPSHOT\maven-metadata-local.xml[DEBUG] Installing com.riadh:riadh-share/maven-metadata.xml to C:\Users\AZZOUZ ROG 01\.m2\repository\com\riadh\riadh-share\maven-metadata-local.xml[INFO] Starting Tomcat[INFO] Unpacking DB Dialects and ibatis files from alfresco-repository artifact[DEBUG] Configuring mojo org.apache.maven.plugins:maven-dependency-plugin:2.10:unpack from plugin realm ClassRealm[plugin>org.apache.maven.plugins:maven-dependency-plugin:2.10, parent: sun.misc.Launcher$AppClassLoader@5c647e05][DEBUG] Configuring mojo 'org.apache.maven.plugins:maven-dependency-plugin:2.10:unpack' with basic configurator -->[DEBUG] (s) outputDirectory = E:\MavenProjects\riadh\target\test-classes[DEBUG] (s) groupId = org.alfresco[DEBUG] (s) artifactId = alfresco-repository[DEBUG] (s) version = 5.2.b-EA[DEBUG] (s) includes = alfresco/dbscripts/create/org.hibernate.dialect.PostgreSQLDialect/*,alfresco/dbscripts/upgrade/*/org.hibernate.dialect.PostgreSQLDialect/*,alfresco/ibatis/org.hibernate.dialect.PostgreSQLDialect/*[DEBUG] (s) artifactItems = [org.alfresco:alfresco-repository:5.2.b-EA:jar][DEBUG] (f) ignorePermissions = false[DEBUG] (s) local = id: local url: file:///C:/Users/AZZOUZ%20ROG%2001/.m2/repository/ layout: defaultsnapshots: [enabled => true, update => always] releases: [enabled => true, update => always]
[DEBUG] (s) markersDirectory = E:\MavenProjects\riadh\target\dependency-maven-plugin-markers[DEBUG] (f) outputAbsoluteArtifactFilename = false[DEBUG] (s) overWriteIfNewer = true[DEBUG] (s) overWriteReleases = false[DEBUG] (s) overWriteSnapshots = false[DEBUG] (f) project = MavenProject: com.riadh:riadh:1.0-SNAPSHOT @ E:\MavenProjects\riadh\pom.xml[DEBUG] (f) reactorProjects = [MavenProject: com.riadh:riadh:1.0-SNAPSHOT @ E:\MavenProjects\riadh\pom.xml, MavenProject: com.riadh:riadh-platform-jar:1.0-SNAPSHOT @ E:\MavenProjects\riadh\riadh-platform-jar\pom.xml, MavenProject: com.riadh:riadh-share-jar:1.0-SNAPSHOT @ E:\MavenProjects\riadh\riadh-share-jar\pom.xml][DEBUG] (s) remoteRepos = [ id: alfresco-public url: https://artifacts.alfresco.com/nexus/content/groups/public layout: defaultsnapshots: [enabled => true, update => daily] releases: [enabled => true, update => daily], id: alfresco-public-snapshots url: https://artifacts.alfresco.com/nexus/content/groups/public-snapshots layout: defaultsnapshots: [enabled => true, update => daily] releases: [enabled => true, update => daily], id: alfresco-private-repository url: https://artifacts.alfresco.com/nexus/content/groups/private layout: defaultsnapshots: [enabled => true, update => daily] releases: [enabled => true, update => daily], id: central url: https://repo.maven.apache.org/maven2 layout: defaultsnapshots: [enabled => false, update => daily] releases: [enabled => true, update => daily]][DEBUG] (f) silent = false[DEBUG] (s) skip = false[DEBUG] (s) useJvmChmod = true[DEBUG] -- end configuration --
[INFO] Configured Artifact: com.riadh:riadh-platform-jar:1.0-SNAPSHOT:jar[INFO] Copying riadh-platform-jar-1.0-SNAPSHOT.jar to E:\MavenProjects\riadh\target\platform-war\WEB-INF\lib\riadh-platform-jar-1.0-SNAPSHOT.jar[INFO] NOT copying Alfresco Enterprise license, running Community edition[DEBUG] Compressing 'E:\MavenProjects\riadh\target\platform-war' into 'E:\MavenProjects\riadh\target\platform.war'.[DEBUG] Dependency collection stats: {ConflictMarker.analyzeTime=0, ConflictMarker.markTime=0, ConflictMarker.nodeCount=40, ConflictIdSorter.graphTime=1, ConflictIdSorter.topsortTime=0, ConflictIdSorter.conflictIdCount=19, ConflictIdSorter.conflictIdCycleCount=0, ConflictResolver.totalTime=0, ConflictResolver.conflictItemCount=40, DefaultDependencyCollector.collectTime=47, DefaultDependencyCollector.transformTime=1}[DEBUG] org.apache.maven.plugins:maven-install-plugin:jar:2.5.2:[DEBUG] org.apache.maven:maven-plugin-api:jar:2.2.1:compile[DEBUG] org.apache.maven:maven-project:jar:2.2.1:compile[DEBUG] org.apache.maven:maven-settings:jar:2.2.1:compile[DEBUG] org.apache.maven:maven-profile:jar:2.2.1:compile[DEBUG] org.apache.maven:maven-plugin-registry:jar:2.2.1:compile[DEBUG] org.codehaus.plexuslexus-interpolation:jar:1.11:compile[DEBUG] org.codehaus.plexuslexus-container-default:jar:1.0-alpha-9-stable-1:compile[DEBUG] junit:junit:jar:3.8.1:compile[DEBUG] classworlds:classworlds:jar:1.1-alpha-2:compile[DEBUG] org.apache.maven:maven-model:jar:2.2.1:compile[DEBUG] org.apache.maven:maven-artifact-manager:jar:2.2.1:compile[DEBUG] org.apache.maven:maven-repository-metadata:jar:2.2.1:compile[DEBUG] backport-util-concurrent:backport-util-concurrent:jar:3.1:compile[DEBUG] org.apache.maven:maven-artifact:jar:2.2.1:compile[DEBUG] commons-codec:commons-codec:jar:1.6:compile[DEBUG] org.apache.maven.shared:maven-shared-utils:jar:0.4:compile[DEBUG] com.google.code.findbugs:jsr305:jar:2.0.1:compile[DEBUG] org.codehaus.plexuslexus-utils:jar:3.0.15:compile[DEBUG] Created new class realm plugin>org.apache.maven.plugins:maven-install-plugin:2.5.2[DEBUG] Importing foreign packages into class realm plugin>org.apache.maven.plugins:maven-install-plugin:2.5.2[DEBUG] Imported: < maven.api[DEBUG] Populating class realm plugin>org.apache.maven.plugins:maven-install-plugin:2.5.2[DEBUG] Included: org.apache.maven.plugins:maven-install-plugin:jar:2.5.2[DEBUG] Included: org.codehaus.plexuslexus-interpolation:jar:1.11[DEBUG] Included: junit:junit:jar:3.8.1[DEBUG] Included: backport-util-concurrent:backport-util-concurrent:jar:3.1[DEBUG] Included: commons-codec:commons-codec:jar:1.6[DEBUG] Included: org.apache.maven.shared:maven-shared-utils:jar:0.4[DEBUG] Included: com.google.code.findbugs:jsr305:jar:2.0.1[DEBUG] Included: org.codehaus.plexuslexus-utils:jar:3.0.15[DEBUG] Configuring mojo org.apache.maven.plugins:maven-install-plugin:2.5.2:install-file from plugin realm ClassRealm[plugin>org.apache.maven.plugins:maven-install-plugin:2.5.2, parent: sun.misc.Launcher$AppClassLoader@5c647e05][DEBUG] Configuring mojo 'org.apache.maven.plugins:maven-install-plugin:2.5.2:install-file' with basic configurator -->[DEBUG] (f) file = E:\MavenProjects\riadh\target\platform.war[DEBUG] (f) groupId = com.riadh[DEBUG] (f) artifactId = riadh-platform[DEBUG] (f) version = 1.0-SNAPSHOT[DEBUG] (f) packaging = war[DEBUG] (f) createChecksum = false[DEBUG] (f) localRepository = id: local url: file:///C:/Users/AZZOUZ%20ROG%2001/.m2/repository/ layout: defaultsnapshots: [enabled => true, update => always] releases: [enabled => true, update => always]
[DEBUG] (f) repositoryLayout = default[DEBUG] (f) updateReleaseInfo = false[DEBUG] -- end configuration --[DEBUG] Using META-INF/maven/org.alfresco/alfresco-platform/pom.xml for groupId, artifactId, packaging and version[DEBUG] Skipping installation of generated POM, already present in local repository[INFO] Installing E:\MavenProjects\riadh\target\platform.war to C:\Users\AZZOUZ ROG 01\.m2\repository\com\riadh\riadh-platform\1.0-SNAPSHOT\riadh-platform-1.0-SNAPSHOT.war[DEBUG] Writing tracking file C:\Users\AZZOUZ ROG 01\.m2\repository\com\riadh\riadh-platform\1.0-SNAPSHOT\_remote.repositories[DEBUG] Installing com.riadh:riadh-platform:1.0-SNAPSHOT/maven-metadata.xml to C:\Users\AZZOUZ ROG 01\.m2\repository\com\riadh\riadh-platform\1.0-SNAPSHOT\maven-metadata-local.xml[DEBUG] Installing com.riadh:riadh-platform/maven-metadata.xml to C:\Users\AZZOUZ ROG 01\.m2\repository\com\riadh\riadh-platform\maven-metadata-local.xml[DEBUG] Configuring mojo org.apache.maven.plugins:maven-dependency-plugin:2.10:unpack from plugin realm ClassRealm[plugin>org.apache.maven.plugins:maven-dependency-plugin:2.10, parent: sun.misc.Launcher$AppClassLoader@5c647e05][DEBUG] Configuring mojo 'org.apache.maven.plugins:maven-dependency-plugin:2.10:unpack' with basic configurator -->[DEBUG] (s) outputDirectory = E:\MavenProjects\riadh\target\share-war[DEBUG] (s) groupId = org.alfresco[DEBUG] (s) artifactId = share[DEBUG] (s) version = 5.2.a-EA[DEBUG] (s) type = war[DEBUG] (s) artifactItems = [org.alfresco:share:5.2.a-EA:war][DEBUG] (f) ignorePermissions = false[DEBUG] (s) local = id: local url: file:///C:/Users/AZZOUZ%20ROG%2001/.m2/repository/ layout: defaultsnapshots: [enabled => true, update => always] releases: [enabled => true, update => always]
If you using eclipse then try this scenario.
First time run project,it will download all dependency.
Now Go to Run configuration->Offline(check that box) and skip test(check that box).
What it will do,it will not download dependency from internet,it will use your local maven and it will be faster and skip test skip the testing of unit test.
HiI don't have a settings.xml file in .m2 folder, do I need to create it ? if yes, what should I put inside that file ?I searched a bit and I found the template but I didn't know what to put in those tags.Thanks.
No,its not required.
