Hello everyone.
I am trying to create a model2java code generator for the Alfresco model.xml files. Everything was going a-ok until i ran into the problem of actually getting hold of Alfresco types outside the normal bean bootstrapping.
Basically I need to get hold of both the NodeService(at least only the NodeService for now) and whatever security context is currently at play.
I am trying to get hold of the NodeService around the normal bean.xml heirachy of Alfresco by using
import org.alfresco.util.ApplicationContextHelper;
import org.springframework.context.ApplicationContext;
ApplicationContext context = ApplicationContextHelper.getApplicationContext();
NodeService ns = context..getBean(ServiceRegistry.class).getNodeService();
List<StoreRef> refs = ns.getStores();
But in my unit test which extends BaseWebScriptTest I run into the follwing exception:
net.sf.acegisecurity.AuthenticationCredentialsNotFoundException: A valid SecureContext was not provided in the RequestContext
at net.sf.acegisecurity.intercept.AbstractSecurityInterceptor.credentialsNotFound(AbstractSecurityInterceptor.java:481)
at net.sf.acegisecurity.intercept.AbstractSecurityInterceptor.beforeInvocation(AbstractSecurityInterceptor.java:359)
at org.alfresco.repo.transaction.RetryingTransactionInterceptor$1.execute(RetryingTransactionInterceptor.java:79)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:457)
at org.alfresco.repo.transaction.RetryingTransactionInterceptor.invoke(RetryingTransactionInterceptor.java:69)
at com.sun.proxy.$Proxy19.getStores(Unknown Source)
After that i found a suggestiong about using AuthenticationUtil as such:
List<StoreRef> refs = AuthenticationUtil.runAs(new AuthenticationUtil.RunAsWork< List<StoreRef>>()
public List<StoreRef> doWork() throws Exception
return ns.getStores();
}, AuthenticationUtil.getSystemUserName());
But I get the exact same exception.
I would very much appreciate some help firstly in understanding if I am doing something wrong and I have to somehow pass the SecurityContext along manually, and how to get execute code as a system-user or some other priviledged user during unit-testing.
