Hello!
I've created a custom transformer for a new xmind mimetype. It does three transformation: xmind to txt for the solr6 search engine, xmind to pdf for document preview in Share and png for thumbnails in Share. It works fine in tests and alfresco successfully use it for text and pdf transformation. But the repo do not initializes thumbnail generation:
Here is the transformer config:
"transformOptions": {
"xmindOptions": [
{ "value": { "name": "thumbnail" } },
{ "value": { "name": "resizeHeight" } },
{ "value": { "name": "resizeWidth" } },
{ "value": { "name": "resizePercentage" } },
{ "value": { "name": "allowEnlargement" } },
{ "value": { "name": "maintainAspectRatio" } }
"transformers": [
"transformerName": "xmind",
"supportedSourceAndTargetList": [
"sourceMediaType": "application/x-xmind",
"targetMediaType": "text/plain"
"targetMediaType": "application/pdf"
"targetMediaType": "image/png"
"transformOptions": ["xmindOptions"]
The javascript does not create doclib. There is no errors, just do nothing:
document.createThumbnail("doclib");
How to configure Alfresco or transformer to create the doclib thumbnail?
Thanks, Serge
Alfresco community 23.3, Docker Compose deployment
