Morning all,
I've got a problem with a scheduled job that we use to copy folders.
The job reads a csv file that contains a list of folders to be created and the metadata to be applied.
To create the folder I use the FileFolderService.copy(...) method to copy a folder template from /Data Dictionary/Space Templates, then I set the metadata on the new folder.
All of the copying operation works as expected except the copied folder does not get indexed so cannot be searched.
I have found that the job was running as System therefore the copied folders are created/modified by System (no particular reason for this - i was just copying the example code in the documentation).
If I change the code so the job runs as admin then the copied folders get indexed correctly !!
If I drop the SOLR index and re-build it, the "System" owned folders are still not indexed.
We have just run the job as part of a data migration so now have 500,000+ folders that will not index.
Does anyone know the easiest way to change the creator & modifier of all my folders to admin? I could then re-build the SOLR index and see if it picks them up? Or is there a way to tell SOLR to index System content.
Paul
