I have a problem with finish of the process.
My current end flow looks like this:
I have two last branches. In the Manual Task I am waiting for execution of both branches.
In the service class I am waiting for execution and when both variables are filled up, I want to push frocess further, which should be end. My code looks like this:
public void listen(DelegateExecution delegateExecution, String resultVar1, String resultVar2) {
Object variable = delegateExecution.getVariable(resultVar1);
Object variable2 = delegateExecution.getVariable(resultVar2);
if (variable != null && variable2 != null) {
runtimeService.trigger(delegateExecution.getId());
}Code executes successfuly, but process is not finished, it stays in the state with red arrow into end event
I tried with Manual task, Receive task, but nothing helps. Is there any other option?
The last idea I have is to put user task, and then complete user task. But this does not look properly, since this is nothing related to user.
Thank you
