Hi
I build my repo and share projects, and place the amp files in amps and amps_share folder in alfresco-community. When i try apply the amps to create alfresco.war and share.war.apply_amps.bat -force command is also applying all the amps which i placed previously inside of the amps folder also. What is the way to apply only the current amp file.
My database connectivity (MySql) is correct,previously its working fine, now also database is connecting with alfresco,but some other issue is there. After changed the amp files only,its not working fine.
this is my db settings in alfresco-global.properties
db.driver=org.gjt.mm.mysql.Driver
db.username=root
db.password=root
db.name=alfresco
db.url=jdbc:mysql://localhost:3306/${db.name}
# Note: your database must also be able to accept at least this many connections. Please see your database documentation for instructions on how to configure this.
db.pool.max=100
db.pool.validate.query=SELECT 1
db.port=3306
log :
2017-11-22 16:06:15,248 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr
.AlfrescoCoreAdminHandler@4237c6e6_Worker-2] Tracking failed
java.net.SocketException: Software caused connection abort: recv failed
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(Unknown Source)
at java.net.SocketInputStream.read(Unknown Source)
at sun.security.ssl.InputRecord.readFully(Unknown Source)
at sun.security.ssl.InputRecord.read(Unknown Source)
at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)
at sun.security.ssl.SSLSocketImpl.readDataRecord(Unknown Source)
at sun.security.ssl.AppInputStream.read(Unknown Source)
at java.io.BufferedInputStream.fill(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at org.apache.commons.httpclient.HttpParser.readRawLine(HttpParser.java:
78)
at org.apache.commons.httpclient.HttpParser.readLine(HttpParser.java:106
at org.apache.commons.httpclient.HttpConnection.readLine(HttpConnection.
java:1116)
at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$Http
ConnectionAdapter.readLine(MultiThreadedHttpConnectionManager.java:1413)
at org.apache.commons.httpclient.HttpMethodBase.readStatusLine(HttpMetho
dBase.java:1973)
at org.apache.commons.httpclient.HttpMethodBase.readResponse(HttpMethodB
ase.java:1735)
at org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.j
ava:1098)
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(Htt
pMethodDirector.java:398)
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMe
thodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.jav
a:397)
a:323)
at org.alfresco.httpclient.AbstractHttpClient.executeMethod(AbstractHttp
Client.java:135)
at org.alfresco.httpclient.AbstractHttpClient.sendRemoteRequest(Abstract
HttpClient.java:111)
at org.alfresco.httpclient.HttpClientFactory$HttpsClient.sendRequest(Htt
pClientFactory.java:408)
at org.alfresco.solr.client.SOLRAPIClient.getModelsDiff(SOLRAPIClient.ja
va:1178)
at org.alfresco.solr.tracker.ModelTracker.trackModelsImpl(ModelTracker.j
ava:256)
at org.alfresco.solr.tracker.ModelTracker.trackModels(ModelTracker.java:
214)
at org.alfresco.solr.tracker.ModelTracker.doTrack(ModelTracker.java:174)
at org.alfresco.solr.tracker.AbstractTracker.track(AbstractTracker.java:
190)
at org.alfresco.solr.tracker.TrackerJob.execute(TrackerJob.java:54)
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.j
ava:563)
2017-11-22 16:09:15,248 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr
.AlfrescoCoreAdminHandler@4237c6e6_Worker-11] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 10200003 api/solr/aclchangesets re
turn status:404
at org.alfresco.solr.client.SOLRAPIClient.getAclChangeSets(SOLRAPIClient
.java:169)
at org.alfresco.solr.tracker.AclTracker.checkRepoAndIndexConsistency(Acl
Tracker.java:354)
at org.alfresco.solr.tracker.AclTracker.trackRepository(AclTracker.java:
320)
at org.alfresco.solr.tracker.AclTracker.doTrack(AclTracker.java:111)
190)
ava:563)
2017-11-20 16:09:15,258 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr
.AlfrescoCoreAdminHandler@4237c6e6_Worker-13] Model tracking failed
org.alfresco.error.AlfrescoRuntimeException: 10200004 GetModelsDiff return stat
us is 404
va:1181)
ava:256)
214)
at org.alfresco.solr.tracker.ModelTracker.ensureFirstModelSync(ModelTrac
ker.java:236)
at org.alfresco.solr.component.EnsureModelsComponent.prepare(EnsureModel
sComponent.java:87)
at org.apache.solr.handler.component.AlfrescoSearchHandler.handleRequest
Body(AlfrescoSearchHandler.java:292)
at org.apache.solr.handler.RequestHandlerBase.handleRequest(RequestHandl
erBase.java:135)
at org.alfresco.solr.Cloud.getResponse(Cloud.java:165)
at org.alfresco.solr.Cloud.getSolrDocumentList(Cloud.java:149)
at org.alfresco.solr.SolrInformationServer.getDocsWithUncleanContent(Sol
rInformationServer.java:722)
at org.alfresco.solr.tracker.ContentTracker.doTrack(ContentTracker.java:
81)
190)
ava:563)
2017-11-20 16:09:15,637 ERROR [solr.tracker.AbstractTracker] [org.alfresco.solr
.AlfrescoCoreAdminHandler@4237c6e6_Worker-12] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 10200002 api/solr/aclchangesets re
turn status:404
.java:169)
Tracker.java:354)
320)
190)
ava:563)
