Activiti 6 didn't seems to support historization into the DB (table ACT_HI_DETAIL) for long (>2000) string form values as for the variables. Is this a design limitation, a misconfiguration or a bug ...?
Thanks for your help !
Following the complete scenario :
When attempting to submit a task form with a huge String value via the API WS http://localhost:8082/activiti-app/api/form/form-data (POST) an error is raised claiming the value to be inserted into the ACT_HI_DETAIL is too big :
INTO ACT_HI_DETAIL (ID_, TYPE_, PROC_INST_ID_, ACT_INST_ID_, EXECUTION_ID_, TASK_ID_, TIME_, NAME_, TEXT_) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?) INTO ACT_HI_DETAIL (ID_, TYPE_, PROC_INST_ID_, ACT_INST_ID_, EXECUTION_ID_, TASK_ID_, TIME_, NAME_, TEXT_) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?) ...
Cause: java.sql.SQLDataException: ORA-01401: inserted value too large for column
The method preparing the form data insertion (org.activiti.engine.impl.persistence.entity.HistoricDetailEntityManagerImpl#copyAndInsertHistoricDetailVariableInstanceUpdateEntity) seems to differ from the one preparing the variable variable insertion (org.activiti.engine.impl.persistence.entity.HistoricDetailEntityManagerImpl#copyAndInsertHistoricDetailVariableInstanceUpdateEntity) precisely on the binary support for the huge values :
public HistoricDetailVariableInstanceUpdateEntity copyAndInsertHistoricDetailVariableInstanceUpdateEntity(VariableInstanceEntity variableInstance) {
HistoricDetailVariableInstanceUpdateEntity historicVariableUpdate = historicDetailDataManager.createHistoricDetailVariableInstanceUpdate();
historicVariableUpdate.setProcessInstanceId(variableInstance.getProcessInstanceId());
historicVariableUpdate.setExecutionId(variableInstance.getExecutionId());
historicVariableUpdate.setTaskId(variableInstance.getTaskId());
historicVariableUpdate.setTime(getClock().getCurrentTime());
historicVariableUpdate.setRevision(variableInstance.getRevision());
historicVariableUpdate.setName(variableInstance.getName());
historicVariableUpdate.setVariableType(variableInstance.getType());
historicVariableUpdate.setTextValue(variableInstance.getTextValue());
historicVariableUpdate.setTextValue2(variableInstance.getTextValue2());
historicVariableUpdate.setDoubleValue(variableInstance.getDoubleValue());
historicVariableUpdate.setLongValue(variableInstance.getLongValue());
if (variableInstance.getBytes() != null) {
historicVariableUpdate.setBytes(variableInstance.getBytes());
insert(historicVariableUpdate);
return historicVariableUpdate;
}public HistoricFormPropertyEntity insertHistoricFormPropertyEntity(ExecutionEntity execution,
String propertyId, String propertyValue, String taskId) {
HistoricFormPropertyEntity historicFormPropertyEntity = historicDetailDataManager.createHistoricFormProperty();
historicFormPropertyEntity.setProcessInstanceId(execution.getProcessInstanceId());
historicFormPropertyEntity.setExecutionId(execution.getId());
historicFormPropertyEntity.setTaskId(taskId);
historicFormPropertyEntity.setPropertyId(propertyId);
historicFormPropertyEntity.setPropertyValue(propertyValue);
historicFormPropertyEntity.setTime(getClock().getCurrentTime());
HistoricActivityInstanceEntity historicActivityInstance = getHistoryManager().findActivityInstance(execution, true, false);
if (historicActivityInstance != null) {
historicFormPropertyEntity.setActivityInstanceId(historicActivityInstance.getId());
insert(historicFormPropertyEntity);
return historicFormPropertyEntity;
