Hello Team,
I am using ADF 6.10 (Alfresco Content App), Alfresco Content Services 23.2.
I have found that Alfresco file list component (files.component.html), that have adf-document-list component which opens context menu on right click,
<adf-document-list
#documentList
acaDocumentList
acaContextActions
[selectionMode]="'multiple'"
[multiselect]="true"
[currentFolderId]="node?.id"
[loading]="true"
[showHeader]="showHeader"
[node]="nodeResult"
[allowDropFiles]="true"
[navigate]="false"
[sorting]="['name', 'asc']"
[imageResolver]="imageResolver"
[headerFilters]="true"
[filterValue]="queryParams"
[isResizingEnabled]="true"
[blurOnResize]="false"
(node-dblclick)="handleNodeClick($event)"
(name-click)="handleNodeClick($event)"
(filterSelection)="onFilterSelected($event)"
(error)="onError()"
It's using directive acaContextActions which is having HostListener which opens context menu on right click
@HostListener('contextmenu', ['$event'])
onContextMenuEvent(event: MouseEvent) {
if (event) {
event.preventDefault();
if (this.enabled) {
const target = this.getTarget(event);
if (target) {
this.execute(event, target);
I tried by putting click event HostListener - @HostListener('click', ['$event']), but it is not working properly.
It opens context menu but it blocks the multiselect feature of file / folder selection because it's listen click event and prevents the checkbox events.
It also sometimes opens contextmenu but it takes the wrong row / node reference and opens context menu of other nodes.
I also tried with mousedown event as well but none of them are working properly.
onContextMenuClickEvent(event: MouseEvent) {
if (event.which !== 3) {
if (this.enabled) {
const target = this.getTargetFromEvent(event);
if (target) {
if (this.isEmptyTable(target)) {
return null;
this.execute$.next(event);
I wanted to implement the same behaviour of conext menu as we got the menu items on right click by doing a click.
Please help / suggest the customization or changes required to achieve this solution.
Vikash
