I download a virtual machine from bitnami and followed this https://docs.bitnami.com/general/apps/alfresco/administration/upgrade/ to transfert my data from the current virtual machine to a new VM, with the new realease of alfresco.
after doing the transfert, alfresco will not start properly. The interface is displaying for my credentials but I cannot log in.
here is the content of alfresco.log
I see some errors but have no clue on how to solve it
I's talking about another cluster while there is only one VM
I wish I could publish the entire content of the logs but it seems to be to long so here is only the end of alfresco.log
2023-04-06 07:32:40,628 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] [main] Bootstrap marker still present in the DB.
2023-04-06 07:32:40,628 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] [main] Another Alfresco cluster node is updating the DB
2023-04-06 07:32:40,628 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] [main] The current Alfresco cluster node is waiting for another chance to bootstrap the DB schema. Attempt: 24 of 24
2023-04-06 07:32:45,630 ERROR [org.alfresco.repo.domain.schema.SchemaBootstrap] [main] Schema auto-update failed
org.alfresco.error.AlfrescoRuntimeException: 03060000 A long running upgrade was found to be running on another node of the cluster. This node is shutting down.
at org.alfresco.repo.domain.schema.SchemaBootstrap.onBootstrap(SchemaBootstrap.java:1694)
at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEventInternal(SafeApplicationEventMulticaster.java:232)
at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:197)
at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:217)
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:421)
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:378)
at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:938)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:586)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:401)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:292)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:103)
at org.alfresco.web.app.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:70)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4493)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4939)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:683)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:658)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:662)
at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:689)
at org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1888)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118)
at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:582)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1617)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:318)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:898)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:795)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1332)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1322)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:140)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:871)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:249)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:428)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:917)
at org.apache.catalina.startup.Catalina.start(Catalina.java:772)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:347)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:478)
2023-04-06 07:32:45,634 ERROR [org.springframework.web.context.ContextLoader] [main] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: 03060001 Schema auto-update failed
at org.alfresco.repo.domain.schema.SchemaBootstrap.onBootstrap(SchemaBootstrap.java:1739)
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03060000 A long running upgrade was found to be running on another node of the cluster. This node is shutting down.
... 53 more
2023-04-06 07:32:45,669 WARN [org.springframework.web.context.support.XmlWebApplicationContext] [main] Exception thrown from ApplicationListener handling ContextClosedEvent
at org.alfresco.repo.workflow.activiti.ActivitiEngineInitializer.onShutdown(ActivitiEngineInitializer.java:65)
at org.springframework.extensions.surf.util.AbstractLifecycleBean.onApplicationEvent(AbstractLifecycleBean.java:67)
at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:202)
at org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:1058)
at org.springframework.context.support.AbstractApplicationContext.close(AbstractApplicationContext.java:1021)
at org.springframework.web.context.ContextLoader.closeWebApplicationContext(ContextLoader.java:517)
at org.springframework.web.context.ContextLoaderListener.contextDestroyed(ContextLoaderListener.java:112)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4539)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5172)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:257)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:187)
2023-04-06 07:32:45,858 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] [main] Stopping 'ContentStore' subsystem, ID: [ContentStore, managed, unencrypted]
2023-04-06 07:32:45,859 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] [main] Stopped 'ContentStore' subsystem, ID: [ContentStore, managed, unencrypted]
2023-04-06 07:32:46,233 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] [main] Stopping 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
2023-04-06 07:32:46,234 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] [main] Stopped 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
Can someone help ?
