I would like to customize Advanced Search to adding "My Search" option. I changed share-config-custom.xml (see below). But my customization doesn't work. I added a new item to search menu, but i get error "Form definition could not be found".
I use the definition from cm:folder, but it doesn't work. I use community edition 7.3 in Docker desktop.
Pls, do you see where is a problem?
Thanks, Martin
<config evaluator="model-type" condition="customContentModel">
<forms>
<form>
<field-visibility>
<show id="cm:name" />
<show id="cm:title" force="true" />
<show id="cm:description" force="true" />
</field-visibility>
<appearance>
<field id="cm:name">
<control template="/org/alfresco/components/form/controls/textfield.ftl" >
<control-param name="maxLength">255</control-param>
</control>
</field>
<field id="cm:title">
<control template="/org/alfresco/components/form/controls/textfield.ftl" />
</field>
</appearance>
</form>
<!-- Search form -->
<form id="search">
<field-visibility>
</field-visibility>
</form>
</forms>
</config>
<config evaluator="string-compare" condition="AdvancedSearch" replace="true">
<advanced-search>
<forms>
<!-- Standard out-of-the-box types -->
<form labelId="search.form.label.cm_content" descriptionId="search.form.desc.cm_content">cm:content</form>
<form labelId="search.form.label.cm_folder" descriptionId="search.form.desc.cm_folder">cm:folder</form>
<!-- Custom type -->
<form labelId="custom" label="My Search" descriptionId="customContent" description="My search description">customContentModel</form>
</forms>
</advanced-search>
</config>
