Hi all,
I had set up an intelliJ alfresco sdk 4.0 enterprise project on local machine(eindows 64) and it used to run earlier with earlier versions like alfresco.platform.version as 6.1.0.2 and alfresco.share.version as 6.1.0.
With below configuration in ~proj/pom.xml and using the alfresco 6.1 license .
<!-- Properties used in dependency declarations, you don't need to change these -->
<alfresco.groupId>org.alfresco</alfresco.groupId>
<alfresco.bomDependencyArtifactId>acs-packaging</alfresco.bomDependencyArtifactId>
<alfresco.platform.version>6.1.0.2</alfresco.platform.version>
<alfresco.share.version>6.1.0</alfresco.share.version>
<!-- Docker images -->
<docker.acs.image>alfresco/alfresco-content-repository</docker.acs.image>
<docker.share.image>alfresco/alfresco-share</docker.share.image>
But , I just 2 days back started the project with command -
C:\github\acs> run.bat build_start
Get the below error:
2019-10-27 12:41:40.049 ERROR (org.alfresco.solr.AlfrescoCoreAdminHandler@59d4cd39_Worker-1) [ ] o.a.s.t.AbstractTracker Tracking failed for ModelTracker - alfresco
aio-ass_1 | org.alfresco.error.AlfrescoRuntimeException: 09270001 alfresco GetModelsDiff return status is 404
aio-ass_1 | at org.alfresco.solr.client.SOLRAPIClient.getModelsDiff(SOLRAPIClient.java:1181)aio-ass_1 | at org.alfresco.solr.tracker.ModelTracker.trackModelsImpl(ModelTracker.java:291)
aio-ass_1 | at org.alfresco.solr.tracker.ModelTracker.trackModels(ModelTracker.java:249)
aio-ass_1 | at org.alfresco.solr.tracker.ModelTracker.doTrack(ModelTracker.java:209)
aio-ass_1 | at org.alfresco.solr.tracker.AbstractTracker.track(AbstractTracker.java:215)
aio-ass_1 | at org.alfresco.solr.tracker.TrackerJob.execute(TrackerJob.java:47)
aio-ass_1 | at org.quartz.core.JobRunShell.run(JobRunShell.java:216)
aio-ass_1 | at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:563)
Can anyone suggest if he faced this issue and any possible fix.
