<xs:element name="test_form"> <xs:complexType> <xs:sequence> <xs:element name="spots" minOccurs="1" maxOccurs="unbounded"> <xs:complexType> <xs:sequence> <xs:element name="type" type="xs:normalizedString"/> <xs:element name="title" type="xs:normalizedString"/> <xs:element name="blurb" type="xs:string"/> <xs:element name="image" type="xs:anyURI"/> <xs:element name="url" type="xs:normalizedString"/> <xs:element name="target" default="_top"> <xs:simpleType> <xs:restriction base="xs:string"> <xs:enumeration value="_top"/> <xs:enumeration value="_blank"/> </xs:restriction> </xs:simpleType> </xs:element> </xs:sequence> </xs:complexType> </xs:element> </xs:sequence> </xs:complexType> </xs:element>
<xs:complexType name="abstract_url" abstract="true"> <xs:sequence> <xs:element name="some_property" type="xs:normalizedString"/> </xs:sequence> </xs:complexType> <xs:complexType name="external_url" abstract="false"> <xs:complexContent> <xs:extension base="abstract_url"> <xs:sequence> <xs:element name="some_other_property" type="xs:normalizedString"/> </xs:sequence> </xs:extension> </xs:complexContent> </xs:complexType> <xs:complexType> <xs:complexContent> <xs:extension base="abstract_url"> <xs:sequence> <xs:element name="some_other_other_property" type="xs:normalizedString"/> </xs:sequence> </xs:extension> </xs:complexContent> </xs:complexType>
<?xml version="1.0"?> <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:amm="http://alfresco/amm" targetNamespace="http://alfresco/amm" elementFormDefault="qualified"> <xs:complexType name="abstract_url" abstract="true"> <xs:sequence> <xs:element name="some_property" type="xs:normalizedString"/> </xs:sequence> </xs:complexType> <xs:complexType name="external_url" abstract="false"> <xs:complexContent> <xs:extension base="abstract_url"> <xs:sequence> <xs:element name="some_other_property" type="xs:normalizedString"/> </xs:sequence> </xs:extension> </xs:complexContent> </xs:complexType> <xs:complexType name="internal_url" abstract="false"> <xs:complexContent> <xs:extension base="abstract_url"> <xs:sequence> <xs:element name="some_other_other_property" type="xs:normalizedString"/> </xs:sequence> </xs:extension> </xs:complexContent> </xs:complexType> <xs:element name="test_form"> <xs:complexType> <xs:sequence> <xs:element name="spots" minOccurs="1" maxOccurs="unbounded"> <xs:complexType> <xs:sequence> <xs:element name="type" type="xs:normalizedString"/> <xs:element name="title" type="xs:normalizedString"/> <xs:element name="blurb" type="xs:string"/> <xs:element name="image" type="xs:anyURI"/> <xs:element name="url" type="abstract_url"/> <xs:element name="target" default="_top"> <xs:simpleType> <xs:restriction base="xs:string"> <xs:enumeration value="_top"/> <xs:enumeration value="_blank"/> </xs:restriction> </xs:simpleType> </xs:element> </xs:sequence> </xs:complexType> </xs:element> </xs:sequence> </xs:complexType> </xs:element> </xs:schema>
org.alfresco.web.forms.FormProcessor$ProcessingException: org.alfresco.web.forms.xforms.FormBuilderException: error parsing schema: at line 12 column 38: src-resolve.4.1: Error resolving component 'abstract_url'. It was detected that 'abstract_url' has no namespace, but components with no target namespace are not referenceable from schema document 'null'. If 'abstract_url' is intended to have a namespace, perhaps a prefix needs to be provided. If it is intended that 'abstract_url' has no namespace, then an 'import' without a "namespace" attribute should be added to 'null'.
org.alfresco.web.forms.FormProcessor$ProcessingException: org.alfresco.web.forms.xforms.FormBuilderException: error parsing schema: at line 40 column 56: src-resolve: Cannot resolve the name 'amm:abstract_url' to a(n) 'type definition' component.
<?xml version="1.0"?> <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:amm="http://alfresco/amm" targetNamespace="http://alfresco/amm" elementFormDefault="qualified"> <xs:complexType name="abstractUrl" abstract="true"/> <xs:complexType name="externalUrl" abstract="false"> <xs:complexContent> <xs:extension base="amm:abstractUrl"> <xs:sequence> <xs:element name="property_1" type="xs:normalizedString"/> </xs:sequence> </xs:extension> </xs:complexContent> </xs:complexType> <xs:complexType name="internalUrl" abstract="false"> <xs:complexContent> <xs:extension base="amm:abstractUrl"> <xs:sequence> <xs:element name="property_2" type="xs:normalizedString"/> </xs:sequence> </xs:extension> </xs:complexContent> </xs:complexType> <xs:element name="test_form"> <xs:complexType> <xs:sequence> <xs:element name="spots" minOccurs="1" maxOccurs="unbounded"> <xs:complexType> <xs:sequence> <xs:element name="type" type="xs:normalizedString"/> <xs:element name="title" type="xs:normalizedString"/> <xs:element name="blurb" type="xs:string"/> <xs:element name="image" type="xs:anyURI"/> <xs:element name="url" type="amm:abstractUrl"/> <xs:element name="target" default="_top"> <xs:simpleType> <xs:restriction base="xs:string"> <xs:enumeration value="_top"/> <xs:enumeration value="_blank"/> </xs:restriction> </xs:simpleType> </xs:element> </xs:sequence> </xs:complexType> </xs:element> </xs:sequence> </xs:complexType> </xs:element> </xs:schema>
Installed Schema 38 Installed Version 2.0.0 (build-23) Server Schema 38 Server Version 2.0.0 (build-23)
