Hi,Well, we have our ldap users and groups sync'ing great!Now we want to get Client Side NTLM working so users areautomatically logged into the system. We are getting an exception thatis preventing the system from starting.Running 1.3.0 EnterpriseFollowed the instructions at: http://wiki.alfresco.com/wiki/Configuring_NTLMHere is the exception we get followed by our web.xml.Ideas?thanks!Chris16:01:46,608 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Enterprise Network): Current version 1.3.0 schema 14 - Installed version 1.3.0 schema 14
16:01:46,702 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception starting filter WebDAV Authentication Filter
javax.servlet.ServletException: Required authentication mode not available
at org.alfresco.repo.webdav.auth.NTLMAuthenticationFilter.init(NTLMAuthenticationFilter.java:160)
at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:223)
at org.apache.catalina.core.ApplicationFilterConfig.setFilterDef(ApplicationFilterConfig.java:304)
at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:77)
at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:3600)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4193)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:904)
at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:867)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:474)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:709)
16:01:46,718 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception starting filter Authentication Filter
at org.alfresco.web.app.servlet.NTLMAuthenticationFilter.init(NTLMAuthenticationFilter.java:180)
web.xml<?xml version='1.0' encoding='UTF-8'?>
<!DOCTYPE web-app PUBLIC
"-//Sun Microsystems, Inc.//DTD Web Application 2.3//EN"
"http://java.sun.com/dtd/web-app_2_3.dtd">
<web-app>
<display-name>Alfresco Web Client</display-name>
<description>Alfresco Web Client</description>
<context-param>
<param-name>javax.faces.STATE_SAVING_METHOD</param-name>
<param-value>server</param-value>
</context-param>
<context-param>
<param-name>javax.faces.CONFIG_FILES</param-name>
<param-value>/WEB-INF/faces-config-app.xml,/WEB-INF/faces-config-beans.xml,/WEB-INF/faces-config-navigation.xml,/WEB-INF/faces-config-common.xml,/WEB-INF/faces-config-repo.xml,WEB-INF/faces-config-custom.xml,/WEB-INF/faces-config-enterprise.xml</param-value>
</context-param>
<context-param>
<param-name>org.apache.myfaces.ALLOW_JAVASCRIPT</param-name>
<param-value>true</param-value>
</context-param>
<context-param>
<param-name>org.apache.myfaces.DETECT_JAVASCRIPT</param-name>
<param-value>false</param-value>
<description>This is an EXPERIMENTAL feature, so leave it off for now!</description>
</context-param>
<!– TODO: Change this to false for production –>
<context-param>
<param-name>org.apache.myfaces.PRETTY_HTML</param-name>
<description>
If true, rendered HTML code will be formatted, so that it is "human readable".
i.e. additional line separators and whitespace will be written, that do not
influence the HTML code.
Default: "true"
</description>
</context-param>
<context-param>
<param-name>org.apache.myfaces.AUTO_SCROLL</param-name>
<description>
If true, a javascript function will be rendered that is able to restore the
former vertical scroll on every request. Convenient feature if you have pages
with long lists and you do not want the browser page to always jump to the top
if you trigger a link or button action that stays on the same page.
Default: "false"
</description>
</context-param>
<context-param>
<param-name>contextConfigLocation</param-name>
<param-value>
classpath:alfresco/web-client-application-context.xml
classpath:web-services-application-context.xml
classpath:alfresco/application-context.xml
</param-value>
<description>Spring config file locations</description>
</context-param>
<filter>
<filter-name>Authentication Filter</filter-name>
<!–<filter-class>org.alfresco.web.app.servlet.AuthenticationFilter</filter-class>–>
<!– For Novell IChain support use the following filter –>
<!– (Enterprise version only) –>
<filter-class>org.alfresco.web.app.servlet.NovellIChainsHTTPRequestAuthenticationFilter</filter-class>
<!– For NTLM authentication support use the following filter –>
<filter-class>org.alfresco.web.app.servlet.NTLMAuthenticationFilter</filter-class>
</filter>
<filter>
<filter-name>WebDAV Authentication Filter</filter-name>
<!–<filter-class>org.alfresco.repo.webdav.auth.AuthenticationFilter</filter-class>–>
<filter-class>org.alfresco.repo.webdav.auth.NTLMAuthenticationFilter</filter-class>
</filter>
<filter-mapping>
<url-pattern>/faces/*</url-pattern>
</filter-mapping>
<!– For NTLM authentication support enable the following mapping –>
<filter-mapping>
<url-pattern>/navigate/*</url-pattern>
</filter-mapping>
<filter-mapping>
<url-pattern>/webdav/*</url-pattern>
</filter-mapping>
<listener>
<listener-class>org.apache.myfaces.webapp.StartupServletContextListener</listener-class>
</listener>
<listener>
<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
</listener>
<listener>
<listener-class>org.alfresco.web.app.ContextListener</listener-class>
</listener>
<!– Faces Servlet –>
<servlet>
<servlet-name>Faces Servlet</servlet-name>
<servlet-class>org.alfresco.web.app.servlet.AlfrescoFacesServlet</servlet-class>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet>
<servlet-name>uploadFile</servlet-name>
<servlet-class>org.alfresco.web.app.servlet.UploadFileServlet</servlet-class>
</servlet>
<servlet>
<servlet-name>downloadContent</servlet-name>
<servlet-class>org.alfresco.web.app.servlet.DownloadContentServlet</servlet-class>
</servlet>
<servlet>
<servlet-name>externalAccess</servlet-name>
<servlet-class>org.alfresco.web.app.servlet.ExternalAccessServlet</servlet-class>
</servlet>
<servlet>
<servlet-name>templateContent</servlet-name>
<servlet-class>org.alfresco.web.app.servlet.TemplateContentServlet</servlet-class>
</servlet>
<servlet>
<servlet-name>commandServlet</servlet-name>
<servlet-class>org.alfresco.web.app.servlet.CommandServlet</servlet-class>
</servlet>
<servlet>
<servlet-name>axis</servlet-name>
<servlet-class>org.apache.axis.transport.http.AxisServlet</servlet-class>
<load-on-startup>5</load-on-startup>
</servlet>
<servlet>
<servlet-name>WebDAV</servlet-name>
<servlet-class>org.alfresco.repo.webdav.WebDAVServlet</servlet-class>
<init-param>
<param-name>store</param-name>
<param-value>workspace://SpacesStore</param-value>
</init-param>
<init-param>
<param-name>rootPath</param-name>
<param-value>/app:company_home</param-value>
</init-param>
</servlet>
<servlet-mapping>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/uploadFileServlet</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/download/*</url-pattern>
</servlet-mapping>
<servlet-mapping>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/template/*</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/command/*</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/api/*</url-pattern>
</servlet-mapping>
<servlet-mapping>
</servlet-mapping>
<session-config>
<session-timeout>60</session-timeout>
</session-config>
<welcome-file-list>
<welcome-file>index.jsp</welcome-file>
</welcome-file-list>
</web-app>
