Bonjour,Après un redémarrage de ma VM WS03, mon Alfresco Labs 3 ne démarre plus.Lors du démarrage j'ai les erreurs suivantes:Jun 3, 2009 5:21:00 PM org.apache.coyote.http11.Http11Protocol init
Jun 3, 2009 5:21:00 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 2184 ms
Jun 3, 2009 5:21:01 PM org.apache.catalina.core.StandardService start
Jun 3, 2009 5:21:01 PM org.apache.catalina.core.StandardEngine start
Jun 3, 2009 5:21:01 PM org.apache.catalina.startup.HostConfig deployWAR
Jun 3, 2009 5:21:13 PM org.apache.catalina.core.StandardContext addApplicationLi
stener
INFO: The listener "org.apache.myfaces.webapp.StartupServletContextListener" is
already configured for this context. The duplicate definition has been ignored.
17:21:52,275 INFO [config.xml.XMLConfigService$PropertyConfigurer] Loading pro
perties file from class path resource [alfresco/file-servers.properties]
17:22:12,244 INFO [domain.schema.SchemaBootstrap] Schema managed by database d
ialect org.hibernate.dialect.MySQLInnoDBDialect.
17:22:17,619 INFO [domain.schema.SchemaBootstrap] No changes were made to the
schema.
17:22:22,369 User:System INFO [repo.admin.ConfigurationChecker] The Alfresco ro
ot data directory ('dir.root') is: C:\Alfresco\alf_data
17:22:22,494 User:System INFO [admin.patch.PatchExecuter] Checking for patches
to apply …
17:22:22,697 User:System INFO [admin.patch.PatchExecuter] No patches were requi
red.
17:22:22,728 User:System INFO [repo.module.ModuleServiceImpl] Found 1 module(s)
17:22:22,791 User:System INFO [repo.module.ModuleServiceImpl] Starting module '
org.alfresco.module.vti' version 1.0.
17:22:26,306 User:System WARN [alfresco.util.OpenOfficeConnectionTester] An ini
tial OpenOffice connection could not be established.
17:22:26,634 User:System INFO [service.descriptor.DescriptorService] Alfresco J
VM - v1.6.0_14-b08; maximum heap size 506.313MB
17:22:26,634 User:System INFO [service.descriptor.DescriptorService] Alfresco s
tarted (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed versi
2009-06-03 17:22:26.837::INFO: Logging to STDERR via org.mortbay.log.StdErrLog
2009-06-03 17:22:27.228::INFO: jetty-6.1.14
2009-06-03 17:22:27.494::INFO: Started SocketConnector@0.0.0.0:7070
17:22:27,556 User:System ERROR [web.context.ContextLoader] Context initializatio
n failed
java.lang.RuntimeException: No root found for :
root path: /app:company_home/st:sites
at org.alfresco.module.vti.handler.alfresco.VtiPathHelper$2.doWork(VtiPa
thHelper.java:502)
thHelper.java:484)
at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(Au
thenticationUtil.java:437)
at org.alfresco.module.vti.handler.alfresco.VtiPathHelper.onBootstrap(Vt
iPathHelper.java:482)
at org.alfresco.util.AbstractLifecycleBean.onApplicationEvent(AbstractLi
fecycleBean.java:62)
at org.springframework.context.event.SimpleApplicationEventMulticaster$1
.run(SimpleApplicationEventMulticaster.java:77)
at org.springframework.core.task.SyncTaskExecutor.execute(SyncTaskExecut
or.java:49)
at org.springframework.context.event.SimpleApplicationEventMulticaster.m
ulticastEvent(SimpleApplicationEventMulticaster.java:75)
at org.springframework.context.support.AbstractApplicationContext.publis
hEvent(AbstractApplicationContext.java:246)
at org.springframework.context.support.AbstractApplicationContext.refres
h(AbstractApplicationContext.java:355)
at org.springframework.web.context.ContextLoader.createWebApplicationCon
text(ContextLoader.java:244)
at org.springframework.web.context.ContextLoader.initWebApplicationConte
xt(ContextLoader.java:187)
at org.springframework.web.context.ContextLoaderListener.contextInitiali
zed(ContextLoaderListener.java:49)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContex
t.java:3843)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4
342)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase
.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:77
1)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:830)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:719
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:490
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java
:311)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(Lifecycl
eSupport.java:117)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443
at org.apache.catalina.core.StandardService.start(StandardService.java:5
16)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:710
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
Jun 3, 2009 5:22:27 PM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
log4j:ERROR LogMananger.repositorySelector was null likely due to error in class
reloading, using NOPLoggerRepository.
Jun 3, 2009 5:22:37 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive share.war
Exception in thread "Win32HostAnnouncer_L0" java.lang.NullPointerException
at org.alfresco.jlan.debug.Debug.println(Debug.java:93)
at org.alfresco.jlan.smb.mailslot.HostAnnouncer.run(HostAnnouncer.java:3
15)
17:22:51,478 INFO [web.site.FrameworkHelper] Successfully Initialized Web Fram
ework
Jun 3, 2009 5:22:52 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive studio.war
log4j:WARN No appenders could be found for logger (org.quartz.core.QuartzSchedul
erThread).
log4j:WARN Please initialize the log4j system properly.
17:22:58,166 INFO [web.scripts.DeclarativeRegistry] Registered 67 Web Scripts
(+0 failed), 71 URLs
17:22:58,166 INFO [web.scripts.AbstractRuntimeContainer] Initialised Presentat
ion Web Script Container (in 1023.15015ms)
at org.jbpm.job.executor.JobExecutorThread.run(JobExecutorThread.java:84
Exception in thread "AlfrescoJbpmJobExector:192.168.14.129:1" java.lang.NullPoin
terException
at org.jbpm.job.executor.JobExecutorThread.run(JobExecutorThread.java:10
0)
17:24:00,212 INFO [web.scripts.DeclarativeRegistry] Registered 101 Web Scripts
(+0 failed), 105 URLs
17:24:00,212 INFO [web.scripts.AbstractRuntimeContainer] Initialised WebFramew
ork Web Script Container (in 61955.01ms)
17:24:00,306 INFO [web.site.FrameworkHelper] Successfully Initialized Web Fram
ework
Jun 3, 2009 5:24:00 PM org.apache.coyote.http11.Http11Protocol start
Jun 3, 2009 5:24:00 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 179871 ms
Voici mon Alfresco.log21:14:12,061 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
21:14:34,092 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
21:14:36,952 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaCreate-org.hibernate.dialect.MySQLInnoDBDialect-3678645788970821700.sql (Generated).
21:14:52,170 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-4478440066174716708.sql (Copied from classpath:alfresco/dbscripts/create/2.2/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoPostCreate-2.2-MappedFKIndexes.sql).
21:14:52,186 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-482492834673374335.sql (Copied from classpath:alfresco/dbscripts/create/2.2/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoPostCreate-2.2-Extra.sql).
21:14:52,592 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-6645491763084075457.sql (Copied from classpath:alfresco/dbscripts/create/2.2/org.hibernate.dialect.MySQLInnoDBDialect/post-create-indexes-04.sql).
21:14:52,717 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-168258686400236419.sql (Copied from classpath:alfresco/dbscripts/create/3.0/org.hibernate.dialect.MySQLInnoDBDialect/create-activities-extras.sql).
21:14:55,764 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] All executed statements written to file C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-All_Statements-786018991151606704.sql.
21:15:44,983 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
21:15:45,030 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
21:15:45,623 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Applying patch 'patch.wcmFolders' (Ensures the existance of the WCM specific 'Web Projects' and 'Web Forms' folders.).
21:15:45,905 INFO [org.alfresco.repo.admin.patch.PatchExecuter]
=== Applied patch ===
RESULT:
Script completed
RESULT:
The Web Projects folder was successfully created: workspace://SpacesStore/257add4e-e0c4-4206-9d44-0daab1ce776d
The Web Forms folder was successfully created: workspace://SpacesStore/257add4e-e0c4-4206-9d44-0daab1ce776d
21:15:45,920 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
21:15:46,077 INFO [org.alfresco.repo.module.ModuleServiceImpl] Installing module 'org.alfresco.module.vti' version 1.0.
21:15:52,702 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
21:15:52,795 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_14-b08; maximum heap size 506.313MB
21:15:52,795 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed version 3.0.0 (Stable 1526) schema 1002
21:17:22,113 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
21:17:54,332 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
21:17:54,347 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 401.8008ms)
21:18:00,426 INFO [org.alfresco.util.OpenOfficeConnectionTester] The OpenOffice connection was re-established.
21:18:55,660 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
21:18:55,660 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 61282.32ms)
21:18:55,769 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
21:54:28,097 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
21:54:44,910 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
21:54:48,988 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
21:54:52,004 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
21:54:52,051 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
21:54:52,301 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
21:54:52,316 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
21:54:52,363 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'org.alfresco.module.vti' version 1.0.
21:54:55,582 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
21:54:55,707 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_14-b08; maximum heap size 506.313MB
21:54:55,707 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed version 3.0.0 (Stable 1526) schema 1002
21:55:22,082 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
21:55:25,613 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
21:55:25,613 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 511.63654ms)
21:56:00,269 INFO [org.alfresco.util.OpenOfficeConnectionTester] The OpenOffice connection was re-established.
21:56:26,972 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
21:56:26,972 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 61387.785ms)
21:56:27,035 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
22:17:20,504 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
22:17:40,738 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
22:17:52,222 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
22:17:56,847 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
22:17:56,879 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
22:17:57,207 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
22:17:57,222 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
22:17:57,472 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'org.alfresco.module.vti' version 1.0.
22:18:00,941 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_14-b08; maximum heap size 506.313MB
22:18:00,941 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed version 3.0.0 (Stable 1526) schema 1002
22:18:20,754 ERROR [org.alfresco.config.BaseConfigService] Input stream invalid - skipped for source: classpath:alfresco/extension/web-client-config-custom.xml'
org.alfresco.config.ConfigException: Failed to parse config stream
at org.alfresco.config.xml.XMLConfigService.parse(XMLConfigService.java:177)
at org.alfresco.config.BaseConfigService.appendConfig(BaseConfigService.java:255)
at org.alfresco.config.BaseConfigService.parse(BaseConfigService.java:285)
at org.alfresco.config.xml.XMLConfigService.initConfig(XMLConfigService.java:111)
at org.alfresco.repo.config.xml.RepoXMLConfigService.initConfig(RepoXMLConfigService.java:152)
at org.alfresco.repo.config.xml.RepoXMLConfigService$1.doWork(RepoXMLConfigService.java:190)
at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:437)
at org.alfresco.repo.config.xml.RepoXMLConfigService.onBootstrap(RepoXMLConfigService.java:186)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:244)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:187)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:719)
Caused by: org.dom4j.DocumentException: Error on line 26 of document : Invalid byte 2 of 3-byte UTF-8 sequence. Nested exception: Invalid byte 2 of 3-byte UTF-8 sequence.
at org.dom4j.io.SAXReader.read(SAXReader.java:482)
at org.dom4j.io.SAXReader.read(SAXReader.java:343)
at org.alfresco.config.xml.XMLConfigService.parse(XMLConfigService.java:144)
… 40 more
22:18:29,863 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
22:18:37,269 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
22:18:37,285 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 533.78766ms)
22:19:39,910 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
22:19:39,926 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 62619.41ms)
22:19:39,988 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
22:24:27,254 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
22:24:43,597 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
22:24:44,801 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
22:24:47,472 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
22:24:47,504 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
22:24:47,707 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
22:24:47,707 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
22:24:47,754 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'org.alfresco.module.vti' version 1.0.
22:24:49,269 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
22:24:49,394 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_14-b08; maximum heap size 506.313MB
22:24:49,394 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed version 3.0.0 (Stable 1526) schema 1002
22:25:08,004 ERROR [org.alfresco.config.BaseConfigService] Input stream invalid - skipped for source: classpath:alfresco/extension/web-client-config-custom.xml'
Caused by: org.dom4j.DocumentException: Error on line 25 of document : Invalid byte 2 of 3-byte UTF-8 sequence. Nested exception: Invalid byte 2 of 3-byte UTF-8 sequence.
… 40 more
22:25:15,926 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
22:25:19,582 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
22:25:19,582 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 441.184ms)
22:26:00,316 INFO [org.alfresco.util.OpenOfficeConnectionTester] The OpenOffice connection was re-established.
22:26:21,691 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
22:26:21,691 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 62096.773ms)
22:26:21,754 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
22:28:05,691 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
22:28:22,035 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
22:28:23,144 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
22:28:26,238 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
22:28:26,269 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
22:28:26,488 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
22:28:26,488 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
22:28:26,582 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'org.alfresco.module.vti' version 1.0.
22:28:28,347 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
22:28:28,441 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_14-b08; maximum heap size 506.313MB
22:28:28,441 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed version 3.0.0 (Stable 1526) schema 1002
22:28:56,097 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
22:28:59,894 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
22:28:59,894 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 442.3294ms)
22:29:00,285 INFO [org.alfresco.util.OpenOfficeConnectionTester] The OpenOffice connection was re-established.
22:30:01,316 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
22:30:01,316 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 61408.875ms)
22:30:01,379 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
22:52:51,691 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
22:53:09,785 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
22:53:15,238 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
22:53:18,785 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
22:53:18,816 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
22:53:19,082 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
22:53:19,082 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
22:53:19,129 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'org.alfresco.module.vti' version 1.0.
22:53:21,535 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
22:53:21,644 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_14-b08; maximum heap size 506.313MB
22:53:21,644 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed version 3.0.0 (Stable 1526) schema 1002
22:53:24,238 INFO [org.alfresco.util.OpenOfficeConnectionTester] The OpenOffice connection was re-established.
22:53:42,394 ERROR [org.alfresco.config.BaseConfigService] Input stream invalid - skipped for source: classpath:alfresco/extension/web-client-config-custom.xml'
Caused by: org.dom4j.DocumentException: Error on line 16 of document : Invalid byte 2 of 3-byte UTF-8 sequence. Nested exception: Invalid byte 2 of 3-byte UTF-8 sequence.
… 40 more
22:53:51,222 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
22:53:55,051 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
22:53:55,051 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 511.2323ms)
22:54:56,426 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
22:54:56,441 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 61360.004ms)
22:54:56,504 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
23:00:03,832 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
23:00:21,238 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
23:00:22,394 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
23:00:24,879 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
23:00:24,910 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
23:00:25,144 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
23:00:25,160 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
23:00:25,207 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'org.alfresco.module.vti' version 1.0.
23:00:26,722 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
23:00:26,832 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_14-b08; maximum heap size 506.313MB
23:00:26,832 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed version 3.0.0 (Stable 1526) schema 1002
23:00:55,019 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
23:00:58,785 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
23:00:58,785 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 455.0897ms)
23:01:00,254 INFO [org.alfresco.util.OpenOfficeConnectionTester] The OpenOffice connection was re-established.
23:02:00,238 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
23:02:00,238 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 61432.53ms)
23:02:00,301 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
17:02:05,886 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
17:02:27,214 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
17:02:31,651 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
17:02:36,667 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
17:02:36,776 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
17:02:37,057 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
17:02:37,057 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
17:02:37,104 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'org.alfresco.module.vti' version 1.0.
17:02:41,714 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
17:02:41,854 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_14-b08; maximum heap size 506.313MB
17:02:41,854 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed version 3.0.0 (Stable 1526) schema 1002
17:02:42,698 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
at org.alfresco.module.vti.handler.alfresco.VtiPathHelper$2.doWork(VtiPathHelper.java:502)
at org.alfresco.module.vti.handler.alfresco.VtiPathHelper$2.doWork(VtiPathHelper.java:484)
at org.alfresco.module.vti.handler.alfresco.VtiPathHelper.onBootstrap(VtiPathHelper.java:482)
17:03:16,854 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
17:03:50,104 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
17:03:50,120 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 1239.2827ms)
17:04:52,370 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
17:04:52,370 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 62188.363ms)
17:04:52,464 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
17:07:58,261 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
17:08:18,057 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
17:08:19,589 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
17:08:22,620 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
17:08:22,651 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
17:08:22,901 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
17:08:22,932 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
17:08:22,995 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'org.alfresco.module.vti' version 1.0.
17:08:27,167 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
17:08:27,261 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_14-b08; maximum heap size 506.313MB
17:08:27,276 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed version 3.0.0 (Stable 1526) schema 1002
17:08:27,667 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
17:08:36,682 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
17:08:40,620 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
17:08:40,620 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 809.15424ms)
17:09:42,042 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
17:09:44,057 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 63441.598ms)
17:09:44,745 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
17:21:52,275 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
17:22:12,244 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
17:22:17,619 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
17:22:22,369 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
17:22:22,494 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
17:22:22,697 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
17:22:22,728 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
17:22:22,791 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'org.alfresco.module.vti' version 1.0.
17:22:26,306 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
17:22:26,634 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_14-b08; maximum heap size 506.313MB
17:22:26,634 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed version 3.0.0 (Stable 1526) schema 1002
17:22:27,556 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
17:22:51,478 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
17:22:58,166 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
17:22:58,166 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 1023.15015ms)
17:24:00,212 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
17:24:00,212 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 61955.01ms)
17:24:00,306 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
Merci de répondre au plus vite car j'ai une présentation du produits à faire Vendredi matin.Merci
