When trying to build the Designer trunk (http://svn.codehaus.org/activiti/projects/designer/trunk/) I'm all of a sudden getting this error.Unable to satisfy dependency from
org.eclipse.jdt.core 3.7.3.v_OTDT_r202_201202051448
to
org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).
No solution found because the problem is unsatisfiable.
(Full Maven output below.)I suspect this is the same problem reported here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=350133Does anyone know of a workaround?Thanks!-Max
[INFO] Scanning for projects…
[INFO] Computing target platform for MavenProject: org.activiti.designer:org.activiti.designer.model:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.model/pom.xml
[INFO] Fetching p2.index (0B of 96B at 0B/s) from http://download.eclipse.org/releases/indigo/
[INFO] Fetching p2.index (128B of 96B at 0B/s) from http://download.eclipse.org/releases/indigo/
[INFO] 1 operation remaining.
[INFO] Adding repository http://download.eclipse.org/releases/indigo
[INFO] Fetching p2.index (0B of 98B at 0B/s) from http://download.eclipse.org/technology/epp/packages/indigo/
[INFO] Fetching p2.index (131B of 98B at 0B/s) from http://download.eclipse.org/technology/epp/packages/indigo/
[INFO] Fetching p2.index (0B of 93B at 0B/s) from http://download.eclipse.org/releases/indigo/201202240900/
[INFO] Fetching p2.index (119B of 93B at 0B/s) from http://download.eclipse.org/releases/indigo/201202240900/
[INFO] Fetching p2.index (0B of 93B at 0B/s) from http://download.eclipse.org/releases/indigo/201109230900/
[INFO] Fetching p2.index (119B of 93B at 0B/s) from http://download.eclipse.org/releases/indigo/201109230900/
[INFO] Fetching p2.index (0B of 93B at 0B/s) from http://download.eclipse.org/releases/indigo/201106220900/
[INFO] Fetching p2.index (119B of 93B at 0B/s) from http://download.eclipse.org/releases/indigo/201106220900/
[INFO] Adding repository http://download.eclipse.org/graphiti/updates/milestones/
[INFO] Adding repository http://download.eclipse.org/tools/orbit/downloads/drops/R20120119162704/repository
[INFO] Resolving dependencies of MavenProject: org.activiti.designer:org.activiti.designer.model:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.model/pom.xml
[INFO] Resolving class path of MavenProject: org.activiti.designer:org.activiti.designer.model:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.model/pom.xml
[INFO] Computing target platform for MavenProject: org.activiti.designer:org.activiti.designer.eclipse:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.eclipse/pom.xml
[INFO] Resolving dependencies of MavenProject: org.activiti.designer:org.activiti.designer.eclipse:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.eclipse/pom.xml
[INFO] Resolving class path of MavenProject: org.activiti.designer:org.activiti.designer.eclipse:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.eclipse/pom.xml
[INFO] Computing target platform for MavenProject: org.activiti.designer:org.activiti.designer.gui:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.gui/pom.xml
[INFO] Resolving dependencies of MavenProject: org.activiti.designer:org.activiti.designer.gui:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.gui/pom.xml
[INFO] Resolving class path of MavenProject: org.activiti.designer:org.activiti.designer.gui:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.gui/pom.xml
[WARNING] Dependency from /scratch/jenkow/activiti2/org.activiti.designer.gui to nested classpath entry /scratch/jenkow/activiti2/org.activiti.designer.eclipse/jdi.jar can not be represented in Maven model and will not be visible to non-OSGi aware Maven plugins
[WARNING] Dependency from /scratch/jenkow/activiti2/org.activiti.designer.gui to nested classpath entry /scratch/jenkow/activiti2/org.activiti.designer.eclipse/jdimodel.jar can not be represented in Maven model and will not be visible to non-OSGi aware Maven plugins
[INFO] Computing target platform for MavenProject: org.activiti.designer:org.activiti.designer.util:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.util/pom.xml
[INFO] Resolving dependencies of MavenProject: org.activiti.designer:org.activiti.designer.util:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.util/pom.xml
[INFO] Resolving class path of MavenProject: org.activiti.designer:org.activiti.designer.util:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.util/pom.xml
[INFO] Computing target platform for MavenProject: org.activiti.designer:org.activiti.designer.help:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.help/pom.xml
[INFO] Resolving dependencies of MavenProject: org.activiti.designer:org.activiti.designer.help:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.help/pom.xml
[INFO] Resolving class path of MavenProject: org.activiti.designer:org.activiti.designer.help:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.help/pom.xml
[INFO] Computing target platform for MavenProject: org.activiti.designer:org.activiti.designer.feature:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.feature/pom.xml
[INFO] Resolving dependencies of MavenProject: org.activiti.designer:org.activiti.designer.feature:5.9.3 @ /scratch/jenkow/activiti2/org.activiti.designer.feature/pom.xml
[INFO] Cannot complete the request. Generating details.
[INFO] {osgi.ws=cocoa, osgi.os=macosx, osgi.arch=x86_64, org.eclipse.update.install.features=true}
[ERROR] Cannot resolve project dependencies:
[ERROR] Software being installed: org.activiti.designer.feature.feature.group 5.9.3
[ERROR] Missing requirement: org.activiti.designer.feature.feature.group 5.9.3 requires 'org.eclipse.graphiti.feature.feature.group [0.9.0,0.9.1)' but it could not be found
[ERROR]
[ERROR] Internal error: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from org.activiti.designer.feature.feature.group 5.9.3 to org.eclipse.graphiti.feature.feature.group [0.9.0,0.9.1).", "Unable to satisfy dependency from org.eclipse.jdt.core 3.7.0.v_OTDT_r200_201106070730 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).", "Unable to satisfy dependency from org.eclipse.jdt.core 3.7.1.v_OTDT_r201_201109101025 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).", "Unable to satisfy dependency from org.eclipse.jdt.core 3.7.3.v_OTDT_r202_201202051448 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).", "No solution found because the problem is unsatisfiable."] -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from org.activiti.designer.feature.feature.group 5.9.3 to org.eclipse.graphiti.feature.feature.group [0.9.0,0.9.1).", "Unable to satisfy dependency from org.eclipse.jdt.core 3.7.0.v_OTDT_r200_201106070730 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).", "Unable to satisfy dependency from org.eclipse.jdt.core 3.7.1.v_OTDT_r201_201109101025 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).", "Unable to satisfy dependency from org.eclipse.jdt.core 3.7.3.v_OTDT_r202_201202051448 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).", "No solution found because the problem is unsatisfiable."]
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:168)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
Caused by: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from org.activiti.designer.feature.feature.group 5.9.3 to org.eclipse.graphiti.feature.feature.group [0.9.0,0.9.1).", "Unable to satisfy dependency from org.eclipse.jdt.core 3.7.0.v_OTDT_r200_201106070730 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).", "Unable to satisfy dependency from org.eclipse.jdt.core 3.7.1.v_OTDT_r201_201109101025 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).", "Unable to satisfy dependency from org.eclipse.jdt.core 3.7.3.v_OTDT_r202_201202051448 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).", "No solution found because the problem is unsatisfiable."]
at org.eclipse.tycho.p2.impl.resolver.AbstractResolutionStrategy.newResolutionException(AbstractResolutionStrategy.java:79)
at org.eclipse.tycho.p2.impl.resolver.ProjectorResolutionStrategy.resolve(ProjectorResolutionStrategy.java:83)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveProject(P2ResolverImpl.java:118)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveProject(P2ResolverImpl.java:76)
at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.doResolvePlatform(P2TargetPlatformResolver.java:448)
at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.resolveDependencies(P2TargetPlatformResolver.java:425)
at org.eclipse.tycho.core.resolver.DefaultTychoDependencyResolver.resolveProject(DefaultTychoDependencyResolver.java:98)
at org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead(TychoMavenLifecycleParticipant.java:64)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:273)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
… 11 more
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/InternalErrorException
