<alfresco-config> <config evaluator="node-type" condition="content"> <property-sheet> <show-property name="name" /> <show-property name="mimetype" display-label-id="content_type" component-generator="MimeTypeSelectorGenerator" /> <!– NOTE: The following 3 properties are defined here to cover –> <!– the scenario where content is added via CIFS or FTP –> <!– and so the properties are missing –> <show-property name="title" display-label-id="title" ignore-if-missing="false" /> <show-property name="description" display-label-id="description" ignore-if-missing="false" component-generator="TextAreaGenerator" /> <show-property name="author" display-label-id="author" ignore-if-missing="false" /> <show-property name="size" display-label-id="size" converter="org.alfresco.faces.ByteSizeConverter" show-in-edit-mode="false" /> <show-property name="ndoc" display-label-id="ndoc" ignore-if-missing="false"/> <show-property name="nif" display-label-id="nif" ignore-if-missing="false"/> <show-property name="napell" display-label-id="napell" ignore-if-missing="false"/> <show-property name="lemis" display-label-id="lemis" ignore-if-missing="false"/> <show-property name="femis" display-label-id="femis" ignore-if-missing="false"/> <show-property name="cterr" display-label-id="cterr" ignore-if-missing="false"/> <show-property name="est" display-label-id="est" ignore-if-missing="false"/> <show-property name="fest" display-label-id="fest" ignore-if-missing="false"/> </property-sheet> </config>
<show-property name="custom:ndoc" display-label-id="ndoc" ignore-if-missing="false"/>
