Bonjour,à ce jour je récupère le nodeRef de mon Workflow comme ceci :public class Maclasse extends JBPMSpringActionHandler {
private static final long serialVersionUID = 5L;
private static final Logger logger = Logger.getLogger(Maclasse.class);
private BeanFactory factory;
private ServiceRegistry services;
private NodeService nodeService;
private AuthorityDAO authorityDAO;
private PermissionService permissionService;
private OwnableService ownableService;
@Override
protected void initialiseHandler(BeanFactory factory) {
this.factory = factory;
services = (ServiceRegistry)this.factory.getBean(ServiceRegistry.SERVICE_REGISTRY);
authorityDAO = (AuthorityDAO)this.factory.getBean("authorityDAO");
nodeService = (NodeService)this.factory.getBean("nodeService");
permissionService = (PermissionService)this.factory.getBean("permissionService");
ownableService = (OwnableService)this.factory.getBean("ownableService");
public void execute(ExecutionContext executionContext) throws Exception {
try {
Object res = executionContext.getContextInstance().getVariable("bpm_package");
if(res == null) {
//never enters here
logger.fatal("bpm_package is null");
return;
final NodeRef nodeRef = ((JBPMNode) res).getNodeRef();
if(nodeRef == null) {
//never enters here
logger.fatal("NodeRef is null");
return;
La nodeRef du Workflow a été récupéré à partir de la variable bpm_package qui a été récupérée de la manière suivante :Object res = executionContext.getContextInstance().getVariable("bpm_package");Le type retourné est de type Object. La valeur retournée par la variable bpm_package est celle-ci :Node Type: {http://www.alfresco.org/model/content/1.0}systemfolder, Node Aspects: [{http://www.alfresco.org/model/content/1.0}auditable, {http://www.alfresco.org/model/system/1.0}referenceable, {http://www.alfresco.org/model/bpm/1.0}workflowPackage]A partir de ce résultat, je récupère le nodeRef correspondant comme suit : final NodeRef nodeRef = ((JBPMNode) res).getNodeRef();
Maitenant comment faire la même chose mais en sens inverse pour pouvoir à partir d'un nodeRef, obtenir la valeur de type Object que je pourrai injecter dans la variable bpm_context par exemple.Merci pour votre aide précieuse.
