Hello, I would like to do something like this: For every user task you create call my custom method (1).
Actually I could write additional code in our logic at two points to almost accomplish this: After creating a new process instance, look if the execution was stopped by a user task. And after completing a user task, do the same. But this only works from within our logic, so timer started process instances won't be handled by this (2).
So, are there hooks to do something like (1), or is there a general way to handle the special case of timer started process instances (2)?
Thank you!
