Hello everybody,this is my second post here.
I am pretty newbe in Activiti then I encountered soon some problems that I am not able to solve.I hope you could help me.I created an example process named Loan Process. In this, I have a script task with the following code creditCheckOk = false;
if((income / 2) > loanAmount) {
out:println "credit check is ok";
creditCheckOk = true;
else
out:println "credit check is not ok";
out:println "Checked credit for " + name + " outcome is " + creditCheckOK;running this process I receive the following exception
org.activiti.engine.ActivitiException: problem evaluating script: javax.script.ScriptException: groovy.lang.MissingPropertyException: No such property: creditCheckOK for class: Script1
very long stacktrace
Caused by: javax.script.ScriptException: javax.script.ScriptException: groovy.lang.MissingPropertyException: No such property: creditCheckOK for class: Script1
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:117)
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:216)
at org.activiti.engine.impl.scripting.ScriptingEngines.evaluate(ScriptingEngines.java:75)
… 86 more
Caused by: javax.script.ScriptException: groovy.lang.MissingPropertyException: No such property: creditCheckOK for class: Script1
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:318)
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:111)
… 88 more
Caused by: groovy.lang.MissingPropertyException: No such property: creditCheckOK for class: Script1
at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.unwrap(ScriptBytecodeAdapter.java:49)
at org.codehaus.groovy.runtime.callsite.PogoGetPropertySite.getProperty(PogoGetPropertySite.java:49)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callGroovyObjectGetProperty(AbstractCallSite.java:239)
at Script1.run(Script1.groovy:13)
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:315)
… 89 more
In my understanding, groovy script should create automatically process variables if def keyword is not used, then also creditCheckOk .I am quite confused, maybe you could help me. you can download the project from herehttps://www.dropbox.com/s/6q6hifz3rio0mms/LoanRequestFail.zip. The test to be runned is LoanRequestTest.Thank you very much for your help. :ugeek:
