Any thoughts would be appreciated on this vexing problem. We are using Activiti-5.6 in our web application and it is configured with Spring. We are using MySQL 5.1.41 on Ubuntu (AWS). JDBC Connector is mysql-connector-java-5.1.6. Our process engine looses it's connection to the database connection pool, causing our process to fail. This seems to happen when the process engine has been at rest for some period of time – like overnight, and we try to start a process. The process fails on the first user task.The error is:
2:17:13,413 ERROR [extensions.webscripts.AbstractRuntime] Exception from executeScript - redirecting to status template error: Error configuring AutoCommit. Your dr$
org.apache.ibatis.transaction.TransactionException: Error configuring AutoCommit. Your driver may not support getAutoCommit() or setAutoCommit(). Requested setting: f$
at org.apache.ibatis.transaction.jdbc.JdbcTransaction.setDesiredAutoCommit(JdbcTransaction.java:47)
at org.apache.ibatis.transaction.jdbc.JdbcTransaction.<init>(JdbcTransaction.java:15)
at org.apache.ibatis.transaction.jdbc.JdbcTransactionFactory.newTransaction(JdbcTransactionFactory.java:15)
at org.apache.ibatis.session.defaults.DefaultSqlSessionFactory.openSessionFromDataSource(DefaultSqlSessionFactory.java:77)
at org.apache.ibatis.session.defaults.DefaultSqlSessionFactory.openSession(DefaultSqlSessionFactory.java:32)
at org.activiti.engine.impl.db.DbSqlSession.<init>(DbSqlSession.java:84)
at org.activiti.engine.impl.db.DbSqlSessionFactory.openSession(DbSqlSessionFactory.java:77)
at org.activiti.engine.impl.interceptor.CommandContext.getSession(CommandContext.java:177)
at org.activiti.engine.impl.persistence.AbstractManager.getSession(AbstractManager.java:56)
at org.activiti.engine.impl.persistence.AbstractManager.getDbSqlSession(AbstractManager.java:52)
at org.activiti.engine.impl.persistence.entity.UserManager.findUserById(UserManager.java:49)
at org.activiti.engine.impl.cmd.CheckPassword.execute(CheckPassword.java:35)
at org.activiti.engine.impl.cmd.CheckPassword.execute(CheckPassword.java:23)
at org.activiti.engine.impl.interceptor.CommandExecutorImpl.execute(CommandExecutorImpl.java:24)
at org.activiti.engine.impl.interceptor.CommandContextInterceptor.execute(CommandContextInterceptor.java:42)
at org.activiti.engine.impl.IdentityServiceImpl.checkPassword(IdentityServiceImpl.java:90)
at org.activiti.rest.auth.ActivitiBasicHttpAuthenticatorFactory.doAuthenticate(ActivitiBasicHttpAuthenticatorFactory.java:61)
at org.springframework.extensions.webscripts.AbstractBasicHttpAuthenticatorFactory$BasicHttpAuthenticator.authenticate(AbstractBasicHttpAuthenticatorFactory.ja$
at org.springframework.extensions.webscripts.PresentationContainer.executeScript(PresentationContainer.java:67)
at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:333)
at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:189)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:636)
Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: The last packet successfully received from the server was75159 seconds ago.The last packet sent suc$
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:406)
at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:1074)
at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:3246)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1917)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2060)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2536)
at com.mysql.jdbc.ConnectionImpl.setAutoCommit(ConnectionImpl.java:4874)
at sun.reflect.GeneratedMethodAccessor184.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.apache.ibatis.datasource.pooled.PooledConnection.invoke(PooledConnection.java:225)
at $Proxy20.setAutoCommit(Unknown Source)
at org.apache.ibatis.transaction.jdbc.JdbcTransaction.setDesiredAutoCommit(JdbcTransaction.java:42)
… 35 more
Caused by: java.net.SocketException: Broken pipe
The process engine is configured in Spring as such:
<bean id="dataSource" class="org.springframework.jndi.JndiObjectFactoryBean">
<property name="jndiName">
<value>java:/comp/env/jdbc/activiti</value>
</property>
</bean>
<bean id="wf-transactionManager"
</bean>
<property name="transactionManager" ref="wf-transactionManager" />
<property name="jobExecutorActivate" value="true" />
<property name="jobExecutor" ref="jobExecutor"/>
</bean>
<bean id="processEngine" class="org.activiti.spring.ProcessEngineFactoryBean">
</bean>
And the JNDI Connection is configured in Tomcat 6 as:
<Resource
name="jdbc/activiti"
auth="Container"
type="javax.sql.DataSource" driverClassName="com.mysql.jdbc.Driver"
url="jdbc:mysql://localhost:3306/activiti?autoReconnect=true"
username="root"
password=""
maxActive="200"
maxIdle="10"
testOnBorrow="true" maxWait="-1"/>
I've used Spring/JPA for many web applications using MySQL and never had this problem. Any ideas on how to debug/solve this DB connection error would be greatly appreciated.
