Hi,I try to create a process diagram with highlighted active activities using the code posted in this forum:String processDefinitionId = activitiTaskService.createTaskQuery().taskId(activitiTaskId).singleResult()
.getProcessDefinitionId();
String processInstanceId = activitiTaskService.createTaskQuery().taskId(activitiTaskId).singleResult()
.getProcessInstanceId();
ProcessDefinitionEntity processDefinitionEntity = (ProcessDefinitionEntity) ((RepositoryServiceImpl) activitiRepositoryService)
.getDeployedProcessDefinition(processDefinitionId);
List<String> activeActivityIds = activitiRuntimeService.getActiveActivityIds(processInstanceId);
InputStream imageStream = ProcessDiagramGenerator.generateDiagram(processDefinitionEntity, "jpg",
activeActivityIds);
try{
BufferedImage is = ImageIO.read(imageStream);
ImageIO.write(is, "jpg", new File("C:\\Users\\user\\tescht.jpg"));
}catch(Exception e){
e.printStackTrace();
}My bpmn.xml:<?xml version="1.0" encoding="UTF-8"?>
<definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlns:omgdc="http://www.omg.org/spec/DD/20100524/DC" xmlns:omgdi="http://www.omg.org/spec/DD/20100524/DI" typeLanguage="http://www.w3.org/2001/XMLSchema" expressionLanguage="http://www.w3.org/1999/XPath" targetNamespace="http://www.test.org/processes">
<process id="CreatePersonProcess" name="Person erstellen">
<startEvent id="start" name=""></startEvent>
<exclusiveGateway id="exclusivegateway1" name="Exclusive Gateway"></exclusiveGateway>
<sequenceFlow id="flow1" name="" sourceRef="start" targetRef="exclusivegateway1"></sequenceFlow>
<userTask id="createPerson" name="Person erfassen" activiti:candidateGroups="AD-MA,AD-Kader"></userTask>
<sequenceFlow id="flow2" name="" sourceRef="exclusivegateway1" targetRef="createPerson"></sequenceFlow>
<userTask id="verifyPerson" name="Person prüfen und ergänzen" activiti:candidateGroups="BO-MA"></userTask>
<sequenceFlow id="flow3" name="" sourceRef="createPerson" targetRef="verifyPerson"></sequenceFlow>
<exclusiveGateway id="exclusivegateway2" name="Exclusive Gateway"></exclusiveGateway>
<sequenceFlow id="flow4" name="" sourceRef="verifyPerson" targetRef="exclusivegateway2"></sequenceFlow>
<sequenceFlow id="flow5" name="" sourceRef="exclusivegateway2" targetRef="exclusivegateway1">
<conditionExpression xsi:type="tFormalExpression"><![CDATA[${processControl == 'reject'}]]></conditionExpression>
</sequenceFlow>
<sequenceFlow id="flow6" name="" sourceRef="exclusivegateway2" targetRef="servicetask1">
<conditionExpression xsi:type="tFormalExpression"><![CDATA[${processControl == 'release'}]]></conditionExpression>
</sequenceFlow>
<serviceTask id="servicetask1" name="Person speichern" activiti:expression="#{defaultPersonService.createPerson(payload)}"></serviceTask>
<sequenceFlow id="flow7" name="" sourceRef="servicetask1" targetRef="parallelgateway1"></sequenceFlow>
<parallelGateway id="parallelgateway1" name="Parallel Gateway"></parallelGateway>
<serviceTask id="informResponsible" name="Verantwortlichen informieren" activiti:expression="#{defaultInformationService.createInformationMessageForUser(payload.id, payload.responsibleEmployeeId.employeeId, 'Adress-Freigabe')}"></serviceTask>
<sequenceFlow id="flow8" name="" sourceRef="parallelgateway1" targetRef="informResponsible"></sequenceFlow>
<serviceTask id="informAdCadre" name="AD-Kader informieren" activiti:expression="#{defaultInformationService.createInformationMessageForUser(payload.id, 'AD-Kader', 'Adress-Freigabe')}"></serviceTask>
<sequenceFlow id="flow9" name="" sourceRef="parallelgateway1" targetRef="informAdCadre"></sequenceFlow>
<sequenceFlow id="flow10" name="" sourceRef="informAdCadre" targetRef="parallelgateway2"></sequenceFlow>
<parallelGateway id="parallelgateway2" name="Parallel Gateway"></parallelGateway>
<sequenceFlow id="flow11" name="" sourceRef="informResponsible" targetRef="parallelgateway2"></sequenceFlow>
<sequenceFlow id="flow12" name="" sourceRef="parallelgateway2" targetRef="endevent1"></sequenceFlow>
</process>
<bpmndi:BPMNDiagram id="BPMNDiagram_CreatePersonProcess">
<bpmndi:BPMNPlane bpmnElement="CreatePersonProcess" id="BPMNPlane_CreatePersonProcess">
<bpmndi:BPMNShape bpmnElement="start" id="BPMNShape_start">
<omgdc:Bounds height="35" width="35" x="40" y="100"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="exclusivegateway1" id="BPMNShape_exclusivegateway1">
<omgdc:Bounds height="40" width="40" x="120" y="97"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="createPerson" id="BPMNShape_createPerson">
<omgdc:Bounds height="55" width="105" x="205" y="90"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="verifyPerson" id="BPMNShape_verifyPerson">
<omgdc:Bounds height="55" width="105" x="365" y="90"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="exclusivegateway2" id="BPMNShape_exclusivegateway2">
<omgdc:Bounds height="40" width="40" x="525" y="97"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="servicetask1" id="BPMNShape_servicetask1">
<omgdc:Bounds height="55" width="105" x="610" y="90"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="parallelgateway1" id="BPMNShape_parallelgateway1">
<omgdc:Bounds height="40" width="40" x="770" y="97"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="informResponsible" id="BPMNShape_informResponsible">
<omgdc:Bounds height="55" width="105" x="850" y="36"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="informAdCadre" id="BPMNShape_informAdCadre">
<omgdc:Bounds height="55" width="105" x="850" y="144"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="parallelgateway2" id="BPMNShape_parallelgateway2">
<omgdc:Bounds height="40" width="40" x="1000" y="97"></omgdc:Bounds>
</bpmndi:BPMNShape>
<omgdc:Bounds height="35" width="35" x="1085" y="100"></omgdc:Bounds>
</bpmndi:BPMNShape>
<omgdi:waypoint x="75" y="117"></omgdi:waypoint>
<omgdi:waypoint x="120" y="117"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<omgdi:waypoint x="160" y="117"></omgdi:waypoint>
<omgdi:waypoint x="205" y="117"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow3" id="BPMNEdge_flow3">
<omgdi:waypoint x="310" y="117"></omgdi:waypoint>
<omgdi:waypoint x="365" y="117"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow4" id="BPMNEdge_flow4">
<omgdi:waypoint x="470" y="117"></omgdi:waypoint>
<omgdi:waypoint x="525" y="117"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow5" id="BPMNEdge_flow5">
<omgdi:waypoint x="545" y="137"></omgdi:waypoint>
<omgdi:waypoint x="545" y="190"></omgdi:waypoint>
<omgdi:waypoint x="344" y="190"></omgdi:waypoint>
<omgdi:waypoint x="140" y="190"></omgdi:waypoint>
<omgdi:waypoint x="140" y="137"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow6" id="BPMNEdge_flow6">
<omgdi:waypoint x="565" y="117"></omgdi:waypoint>
<omgdi:waypoint x="610" y="117"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow7" id="BPMNEdge_flow7">
<omgdi:waypoint x="715" y="117"></omgdi:waypoint>
<omgdi:waypoint x="770" y="117"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow8" id="BPMNEdge_flow8">
<omgdi:waypoint x="790" y="97"></omgdi:waypoint>
<omgdi:waypoint x="790" y="63"></omgdi:waypoint>
<omgdi:waypoint x="850" y="63"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow9" id="BPMNEdge_flow9">
<omgdi:waypoint x="790" y="137"></omgdi:waypoint>
<omgdi:waypoint x="790" y="171"></omgdi:waypoint>
<omgdi:waypoint x="850" y="171"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow10" id="BPMNEdge_flow10">
<omgdi:waypoint x="955" y="171"></omgdi:waypoint>
<omgdi:waypoint x="1020" y="171"></omgdi:waypoint>
<omgdi:waypoint x="1020" y="137"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow11" id="BPMNEdge_flow11">
<omgdi:waypoint x="955" y="63"></omgdi:waypoint>
<omgdi:waypoint x="1020" y="63"></omgdi:waypoint>
<omgdi:waypoint x="1020" y="97"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow12" id="BPMNEdge_flow12">
<omgdi:waypoint x="1040" y="117"></omgdi:waypoint>
<omgdi:waypoint x="1085" y="117"></omgdi:waypoint>
</bpmndi:BPMNEdge>
</bpmndi:BPMNPlane>
</bpmndi:BPMNDiagram>
</definitions>see the image I get attached.Any hints, why this is happening? There is nothing to see in the logs. It doesn't matter, which file tiype I use.Diagram modelled with latest Activiti Designer, runtime Activiti 6.5Regards,michael
