Hello!When I'm importing Activiti Engine 5.8 into mi Eclipse Helios I find this error (and project not compile, old versions of activiti always works fine)24/10/11 10:19:26 CEST: Maven Builder: FULL_BUILD requireFullBuild
24/10/11 10:19:26 CEST: [WARN]
24/10/11 10:19:26 CEST: [WARN] Some problems were encountered while building the effective model for org.activiti:activiti-engine:jar:5.8
24/10/11 10:19:26 CEST: [WARN] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-compiler-plugin is missing. @ org.activiti:activiti-root:5.8, C:\workspaces\activiti58\activiti-5.8\pom.xml, line 470, column 15
24/10/11 10:19:26 CEST: [WARN] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-jar-plugin is missing. @ line 152, column 15
24/10/11 10:19:26 CEST: [WARN] The expression ${version} is deprecated. Please use ${project.version} instead.
24/10/11 10:19:26 CEST: [WARN] It is highly recommended to fix these problems because they threaten the stability of your build.
24/10/11 10:19:26 CEST: [WARN] For this reason, future Maven versions might no longer support building such malformed projects.
24/10/11 10:19:26 CEST: [WARN] Using platform encoding (Cp1252 actually) to copy filtered resources, i.e. build is platform dependent!
24/10/11 10:19:26 CEST: [INFO] Copying 135 resources
24/10/11 10:19:46 CEST: [INFO] Nothing to compile - all classes are up to date
24/10/11 10:20:05 CEST: [WARN] Warning in manifest for org.activiti:activiti-engine:jar:5.8 : Did not find matching referal for com.sun*
24/10/11 10:20:05 CEST: [WARN] Warning in manifest for org.activiti:activiti-engine:jar:5.8 : Did not find matching referal for javax.persistence*
24/10/11 10:20:05 CEST: [WARN] Warning in manifest for org.activiti:activiti-engine:jar:5.8 : Did not find matching referal for junit*
24/10/11 10:20:05 CEST: [WARN] Warning in manifest for org.activiti:activiti-engine:jar:5.8 : Did not find matching referal for org.activiti.*
24/10/11 10:20:05 CEST: [WARN] Warning in manifest for org.activiti:activiti-engine:jar:5.8 : Did not find matching referal for org.activiti.osgi*
24/10/11 10:20:05 CEST: [WARN] Warning in manifest for org.activiti:activiti-engine:jar:5.8 : Did not find matching referal for org.apache.tools.ant*
24/10/11 10:20:05 CEST: [WARN] Warning in manifest for org.activiti:activiti-engine:jar:5.8 : Did not find matching referal for org.apache.xerces*
24/10/11 10:20:05 CEST: [WARN] Warning in manifest for org.activiti:activiti-engine:jar:5.8 : Did not find matching referal for org.junit*
24/10/11 10:20:05 CEST: [ERROR] Error in manifest for org.activiti:activiti-engine:jar:5.8 : The default package '.' is not permitted by the Import-Package syntax.
This can be caused by compile errors in Eclipse because Eclipse creates
valid class files regardless of compile errors.
The following package(s) import from the default package [org.activiti.engine.impl.ant, org.activiti.engine.impl.bpmn.behavior, org.activiti.engine.impl.cfg, org.activiti.engine.impl.db, org.activiti.engine.impl.interceptor, org.activiti.engine.impl.mail, org.activiti.engine.impl.persistence, org.activiti.engine.impl.rules, org.activiti.engine.impl.test, org.activiti.engine.impl.variable, org.activiti.engine.test]
24/10/11 10:20:05 CEST: [ERROR] Error(s) found in manifest configuration
24/10/11 10:20:18 CEST: Build errors for activiti-engine; org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.felix:maven-bundle-plugin:2.1.0:manifest (bundle-manifest) on project activiti-engine: Error(s) found in manifest configuration
24/10/11 10:20:19 CEST: Maven Builder: AUTO_BUILD
Can you help me?
