select * from alf_node_properties where qname = '{http://www.alfresco.org/model/user/1.0}username' order by string_value;ββ
index.recovery.mode=FULLββ
mysql> select * from alf_node_properties where qname = '{http://www.alfresco.org/model/user/1.0}username' order by string_value; +βββ+ββββ-+βββββ+βββββ-+βββββ+ββββ+ββββ-+βββββ+βββββ+βββββββ+βββββ ββββββββββββ+ | node_id | actual_type | multi_valued | persisted_type | boolean_value | long_value | float_value | double_value | string_value | serializable_value | qname | +βββ+ββββ-+βββββ+βββββ-+βββββ+ββββ+ββββ-+βββββ+βββββ+βββββββ+βββββ ββββββββββββ+ | 7 | STRING | 0 | STRING | 0 | 0 | 0 | 0 | admin | NULL | {http://www.a lfresco.org/model/user/1.0}username | +βββ+ββββ-+βββββ+βββββ-+βββββ+ββββ+ββββ-+βββββ+βββββ+βββββββ+βββββ ββββββββββββ+ 1 row in set (0.09 sec) ββββββββββββββ
@cm\:userName:"joe smith"β
function doIt() { str =Β ""+document.id+"<β-gone"; document.remove(); return str; } doIt(); ββββββββββββ
