\WhiteRoom\activiti\activiti-5.0.alpha4\setup>antBuildfile: \WhiteRoom\activiti\activiti-5.0.alpha4\setup\build.xml [echo] Activiti home = .. [echo] Activiti version = 5.0.alpha4h2.install: [mkdir] Created dir: \WhiteRoom\activiti\activiti-5.0.alpha4\apps\h2 [copy] Copying 5 files to \WhiteRoom\activiti\activiti-5.0.alpha4\apps\h2internal.classpath.libs:internal.taskdef.launch:h2.start: [launch] launching cmd 'D:\WhiteRoom\activiti\activiti-5.0.alpha4\apps\h2\h2.start.bat ' in dir 'D:\WhiteRoom\activiti\activiti-5.0.alpha4\apps\h2' [launch] waiting for launch completion msg 'TCP server running on'… [launch] TCP server running on tcp://192.168.1.34:9092 (others can connect)db.create: [sql] Executing resource: org/activiti/db/create/activiti.mysql.create.sql [sql] 29 of 29 SQL statements executed successfullytomcat.install: [echo] Activiti home = .. [echo] Activiti version = 5.0.alpha4internal.download.tomcat: [unzip] Expanding: \WareHouse\apache\tomcat\6.0.29\apache-tomcat-6.0.29.zip into \WhiteRoom\activiti\activiti-5.0.alpha4\apps [echo] Activiti home = .. [echo] Activiti version = 5.0.alpha4tomcat.copy.users: [echo] Activiti home = .. [echo] Activiti version = 5.0.alpha4tomcat.enable.debug:cfg.create: [mkdir] Created dir: \WhiteRoom\activiti\activiti-5.0.alpha4\setup\build\activiti-cfg [copy] Copying 1 file to \WhiteRoom\activiti\activiti-5.0.alpha4\setup\build\activiti-cfg [jar] Building jar: \WhiteRoom\activiti\activiti-5.0.alpha4\setup\build\activiti-cfg.jardeploy.activiti.engine.into.tomcat: [copy] Warning: activiti-cfg.jar modified in the future. [copy] Copying 6 files to \WhiteRoom\activiti\activiti-5.0.alpha4\apps\apache-tomcat-6.0.29\lib [delete] Deleting: \WhiteRoom\activiti\activiti-5.0.alpha4\apps\apache-tomcat-6.0.29\lib\el-api.jardb.demo.data: [sql] Executing resource: \WhiteRoom\activiti\activiti-5.0.alpha4\setup\files\demo\mysql.data.sql [sql] 23 of 23 SQL statements executed successfully [zip] Building zip: \WhiteRoom\activiti\activiti-5.0.alpha4\setup\build\activiti-examples.bar[deploy-bar] Initializing process engine default[deploy-bar] 21/08/2010 02:44:15 PM org.activiti.ProcessEngines initProcessEnginFromResource[deploy-bar] INFO: initializing process engine for resource jar:file:/D:/WhiteRoom/activiti/activiti-5.0.alpha4/setup/build/activiti-cfg.jar!/activiti.properties[deploy-bar] 21/08/2010 02:44:15 PM org.activiti.ProcessEngines initProcessEnginFromResource[deploy-bar] INFO: Exception while initializing process engine : Error setting driver on UnpooledDataSource. Cause: java.lang.ClassNotFoundException: com.mysql.jdbc.DriverBUILD FAILED\WhiteRoom\activiti\activiti-5.0.alpha4\setup\build.xml:195: org.activiti.ActivitiException: Could not find a process engine with name 'default' at org.activiti.impl.ant.DeployBarTask.execute(DeployBarTask.java:73) at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291) at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106) at org.apache.tools.ant.Task.perform(Task.java:348) at org.apache.tools.ant.Target.execute(Target.java:390) at org.apache.tools.ant.Target.performTasks(Target.java:411) at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1397) at org.apache.tools.ant.Project.executeTarget(Project.java:1366) at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41) at org.apache.tools.ant.Project.executeTargets(Project.java:1249) at org.apache.tools.ant.Main.runBuild(Main.java:801) at org.apache.tools.ant.Main.startAnt(Main.java:218) at org.apache.tools.ant.launch.Launcher.run(Launcher.java:280) at org.apache.tools.ant.launch.Launcher.main(Launcher.java:109)Total time: 10 seconds\WhiteRoom\activiti\activiti-5.0.alpha4\setup>
<target name="internal.classpath.libs"> <path id="classpath.libs"> <fileset dir="${activiti.home}/lib"> <include name="*.jar" /> </fileset> </path></target>
<taskdef name="deploy-bar" classname="org.activiti.impl.ant.DeployBarTask"> <classpath> <pathelement path="files/demo"/> <fileset dir="build"> <include name="activiti-cfg.jar"/> </fileset> <fileset dir="${activiti.home}/lib"> <include name="activiti-engine-${activiti.version}.jar"/> <include name="mybatis-*.jar"/> <include name="h2-*.jar"/> <include name="freemarker-*.jar" /> <include name="juel*.jar" /> </fileset> </classpath> </taskdef> <deploy-bar file="${activiti.home}/setup/build/activiti-examples.bar" /> </target>
<taskdef name="deploy-bar" classname="org.activiti.impl.ant.DeployBarTask"> <classpath> <pathelement path="files/demo"/> <fileset dir="build"> <include name="activiti-cfg.jar"/> </fileset> <fileset dir="${activiti.home}/lib"> <include name="activiti-engine-${activiti.version}.jar"/> <include name="mybatis-*.jar"/> <include name="h2-*.jar"/> <include name="mysql-*.jar"/> <include name="freemarker-*.jar" /> <include name="juel*.jar" /> </fileset> </classpath> </taskdef> <deploy-bar file="${activiti.home}/setup/build/activiti-examples.bar" /> </target>
the exception is thrown while executing the deploy-bar task, I would guess you have to add the mysql-connector-*.jar to your fileset.
As you use mysql you can comment the h2 related tasks and delete the <include name="h2-*.jar"/> from your taskdef.
If you comment the h2 tasks dont forget to remove them from your build dependencies.
