Hi all, am not sure where am going wrong, my app is using 5.7. Which worked fine, until i restarted tomcat. Am using spring with the following config:
<!– Configure process engine –>
<bean id="processEngineConfiguration" class="org.activiti.spring.SpringProcessEngineConfiguration"
lazy-init="true">
<property name="databaseType" value="mysql" />
</bean>
when restarting tomcat, i see this in the logs:
19 Aug 2011 12:33:28 PM org.activiti.engine.impl.db.DbSqlSession dbSchemaUpgrade
INFO: upgrading activiti engine schema from 5.7 to 5.6
This looks suspicious to me.Which then results in
INFO: upgrading activiti engine schema from 5.6 to 5.7
19 Aug 2011 12:33:38 PM org.activiti.engine.impl.db.DbSqlSession dbSchemaUpgrade
INFO: upgrading activiti history schema from 5.6 to 5.7
19 Aug 2011 12:33:38 PM org.activiti.engine.impl.db.DbSqlSession executeSchemaResource
INFO: performing upgrade on history with resource org/activiti/db/upgrade/activiti.mysql.upgradestep.56.to.57.history.sql
SEVERE: problem during schema upgrade, statement 'alter table ACT_HI_PROCINST
add SUPER_PROCESS_INSTANCE_ID_ varchar(64)
com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Duplicate column name 'SUPER_PROCESS_INSTANCE_ID_'
Am not sure why it is 'upgrading' from 5.7 to 5.6 when i restart tomcat.Cheers.
