<?xml version="1.0" encoding="UTF-8"?> <definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlns:omgdc="http://www.omg.org/spec/DD/20100524/DC" xmlns:omgdi="http://www.omg.org/spec/DD/20100524/DI" typeLanguage="http://www.w3.org/2001/XMLSchema" expressionLanguage="http://www.w3.org/1999/XPath" targetNamespace="http://www.activiti.org/test"> <process id="TrainingRequest" name="TrainingRequest"> <documentation>Place documentation for the 'TrainingRequest' process here.</documentation> <startEvent id="startevent1" name="Start"></startEvent> <userTask id="usertask1" name="User Task" activiti:assignee="ROLE_USER"> <multiInstanceLoopCharacteristics isSequential="false"></multiInstanceLoopCharacteristics> </userTask> <sequenceFlow id="flow1" name="" sourceRef="startevent1" targetRef="usertask1"></sequenceFlow> <subProcess id="subprocess1" name="Sub Process"> <multiInstanceLoopCharacteristics isSequential="false"> <loopCardinality>5</loopCardinality> </multiInstanceLoopCharacteristics> <userTask id="subprocess1usertask2" name="User Task" activiti:assignee="ROLE_USER"></userTask> <boundaryEvent id="subprocess1boundarytimer1" name="" cancelActivity="true" attachedToRef="subprocess1usertask2"> <timerEventDefinition> <timeDuration>PT1M</timeDuration> </timerEventDefinition> </boundaryEvent> <serviceTask id="subprocess1mailtask1" name="Mail Task" activiti:type="mail"> <extensionElements> <activiti:field name="to" expression="dave.woodbury@freescale.com"></activiti:field> <activiti:field name="from" expression="dave.woodbury@freescale.com"></activiti:field> <activiti:field name="subject" expression="test"></activiti:field> <activiti:field name="html"> <activiti:expression><![CDATA[test]]></activiti:expression> </activiti:field> </extensionElements> </serviceTask> <sequenceFlow id="subprocess1flow3" name="" sourceRef="subprocess1boundarytimer1" targetRef="subprocess1mailtask1"></sequenceFlow> <endEvent id="subprocess1endevent2" name="End"></endEvent> <sequenceFlow id="subprocess1flow5" name="" sourceRef="subprocess1mailtask1" targetRef="subprocess1endevent2"></sequenceFlow> <sequenceFlow id="subprocess1flow6" name="" sourceRef="subprocess1usertask2" targetRef="subprocess1endevent2"></sequenceFlow> <startEvent id="subprocess1startevent2" name="Start"></startEvent> <sequenceFlow id="subprocess1flow7" name="" sourceRef="subprocess1startevent2" targetRef="subprocess1usertask2"></sequenceFlow> </subProcess> <sequenceFlow id="flow2" name="" sourceRef="usertask1" targetRef="subprocess1"></sequenceFlow> <endEvent id="endevent1" name="End"></endEvent> <sequenceFlow id="flow4" name="" sourceRef="subprocess1" targetRef="endevent1"></sequenceFlow> </process> </definitions>
I've not done that before, but I can try. Can you point me to some instructions or examples? I checked the forums but didn't find a thread for newbies with respect to development.<br>
<br>Also, is it a fair assumption on my part that this is likely an issue with the engine? The sub-process runs autonomously in the engine, creating 5 user-tasks, each with a cancel timer. When the timers expire, the engine throws a concurrency exception.
Is there a way to define the sub-process such that the embedded timer and user tasks are assigned unique ID's?
