<?xml version="1.0" encoding="UTF-8"?><br><!– Published by JAX-WS RI at <a href="http://jax-ws.dev.java.net" rel="nofollow noopener noreferrer">http://jax-ws.dev.java.net</a>. RI's version is JAX-WS RI 2.1.6 in JDK 6. –><br><!– Generated by JAX-WS RI at <a href="http://jax-ws.dev.java.net" rel="nofollow noopener noreferrer">http://jax-ws.dev.java.net</a>. RI's version is JAX-WS RI 2.1.6 in JDK 6. –><br><definitions xmlns:soap="<a href="http://schemas.xmlsoap.org/wsdl/soap/" rel="nofollow noopener noreferrer">http://schemas.xmlsoap.org/wsdl/soap/</a>"<br> xmlns:tns="<a href="http://webservice.impl.engine.activiti.org/" rel="nofollow noopener noreferrer">http://webservice.impl.engine.activiti.org/</a>"<br> xmlns:xsd="<a href="http://www.w3.org/2001/XMLSchema" rel="nofollow noopener noreferrer">http://www.w3.org/2001/XMLSchema</a>"<br> xmlns="<a href="http://schemas.xmlsoap.org/wsdl/" rel="nofollow noopener noreferrer">http://schemas.xmlsoap.org/wsdl/</a>"<br> targetNamespace="<a href="http://webservice.impl.engine.activiti.org/" rel="nofollow noopener noreferrer">http://webservice.impl.engine.activiti.org/</a>" name="Counter"><br> <types><br> <xsd:schema><br> <xsd:import namespace="<a href="http://webservice.impl.engine.activiti.org/" rel="nofollow noopener noreferrer">http://webservice.impl.engine.activiti.org/</a>"<br> schemaLocation="<a href="http://localhost:63081/counter?xsd=1" rel="nofollow noopener noreferrer">http://localhost:63081/counter?xsd=1</a>"></xsd:import><br> </xsd:schema><br> </types><br> …
private Element getRootTypes() {<br> try {<br> DOMParser parser = new DOMParser();<br> parser.parse(this.wsdlLocation);<br> …
DocumentBuilderFactory dbf = DocumentBuilderFactory.newInstance();<br> dbf.setNamespaceAware(true);<br> DocumentBuilder db = dbf.newDocumentBuilder();<br> Document doc = db.parse(this.wsdlLocation);<br> …
private Element getRootTypes() {<br> Element schemaElement = null;<br> try {<br> WSDLFactory wsdlFactory = WSDLFactory.newInstance();<br> WSDLReader reader = wsdlFactory.newWSDLReader();<br> Definition definition = reader.readWSDL(this.wsdlLocation);<br> Types types = definition.getTypes();<br> for (Object object : types.getExtensibilityElements()) {<br> Schema schema = (Schema) object;<br> if (schema.getImports().isEmpty()) {<br> schemaElement = schema.getElement();<br> } else {<br> for (Object value : schema.getImports().values()) {<br> for (Object si : ((List)value)) {<br> schemaElement = ((SchemaImport)si).getReferencedSchema().getElement();<br> }<br> }<br> }<br><br> }<br> } catch (WSDLException e) {<br> throw new ActivitiException(e.getMessage(), e);<br> }<br> return schemaElement;<br> }
