Upgrading to lucene 1.9/2.0 is not recommended.We have some stabilty/scalability fixes in our 1.4.3 jar that have not gone into lucene for some reason. I have raised the issues. We also have some improvements for merging segments without continual index optimisation which is very expensive.We will migrate at some point.Only documents indexed/changed after you have set the indexer will be treated correctly. Searching an index with a tokeniser that does not match how the field was indexed will produce odd results. Note stop words may have been previously indexed or be valid for other data types. So files indexed previously will be wrong. Edit the text or an attribute to force a reindex.
<listener> <listener-class>org.apache.myfaces.webapp.StartupServletContextListener</listener-class> </listener> <listener> <listener-class>org.springframework.web.context.ContextLoaderListener</listener-class> </listener> <listener> <listener-class>org.alfresco.web.app.ContextListener</listener-class> </listener>
——————- WEB.XML ——————- <!– Start of Alfresco integration. Load up the Spring environment –> <context-param> <param-name>javax.faces.STATE_SAVING_METHOD</param-name> <param-value>server</param-value> </context-param> <context-param> <param-name>javax.faces.CONFIG_FILES</param-name> <param-value>/WEB-INF/faces-config-app.xml,/WEB-INF/faces-config-beans.xml,/WEB-INF/faces-config-navigation.xml,/WEB-INF/faces-config-common.xml,/WEB-INF/faces-config-repo.xml</param-value> </context-param> <context-param> <param-name>org.apache.myfaces.ALLOW_JAVASCRIPT</param-name> <param-value>true</param-value> </context-param> <context-param> <param-name>org.apache.myfaces.DETECT_JAVASCRIPT</param-name> <param-value>false</param-value> </context-param> <!– TODO: Change this to false for production –> <context-param> <param-name>org.apache.myfaces.PRETTY_HTML</param-name> <param-value>true</param-value> </context-param> <context-param> <param-name>org.apache.myfaces.AUTO_SCROLL</param-name> <param-value>false</param-value> </context-param> <context-param> <param-name>contextConfigLocation</param-name> <param-value> classpath:alfresco/web-client-application-context.xml classpath:web-services-application-context.xml classpath:alfresco/jcr-context.xml </param-value> </context-param> <listener> <listener-class>org.apache.myfaces.webapp.StartupServletContextListener</listener-class> </listener> <listener> <listener-class>org.springframework.web.context.ContextLoaderListener</listener-class> </listener> <listener> <listener-class>org.alfresco.web.app.ContextListener</listener-class> </listener> <!– End of Alfresco integration. –> ————————- JBOSS Server output ————————- 11:09:19,293 INFO [ContextLoader] Root WebApplicationContext: initialization started 11:09:19,794 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/web-client-application-context.xml] 11:09:19,874 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [web-services-application-context.xml] 11:09:20,235 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/application-context.xml] 11:09:20,255 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/core-services-context.xml] 11:09:20,775 INFO [CollectionFactory] JDK 1.4+ collections available 11:09:20,845 INFO [CollectionFactory] Commons Collections 3.x available 11:09:21,456 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/public-services-context.xml] 11:09:21,516 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/public-services-security-context.xml] 11:09:22,077 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/cache-context.xml] 11:09:22,438 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/model-specific-services-context.xml] 11:09:22,548 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/action-services-context.xml] 11:09:22,698 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/rule-services-context.xml] 11:09:22,738 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/node-services-context.xml] 11:09:22,888 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/scheduled-jobs-context.xml] 11:09:22,999 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/network-protocol-context.xml] 11:09:23,079 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/content-services-context.xml] 11:09:23,529 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/hibernate-context.xml] 11:09:23,619 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/ownable-services-context.xml] 11:09:23,639 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/template-services-context.xml] 11:09:23,770 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/index-recovery-context.xml] 11:09:23,950 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/authority-services-context.xml] 11:09:23,970 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/authentication-services-context.xml] 11:09:24,471 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [alfresco/bootstrap-context.xml] 11:09:24,661 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from URL [jar:file:/E:/_3_DAM/jboss_4/server/default/deploy/.ear/.war/WEB-INF/lib/alfresco-repository.jar!/alfresco/patch/patch-services-context.xml] 11:09:25,011 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from file [WEB-INF\classes\alfresco\extension\-custom-context.xml] 11:09:25,041 INFO [DefaultListableBeanFactory] Overriding bean definition for bean 'repository-properties': replacing [Root bean: class [org.springframework.beans.factory.config.PropertyPlaceholderConfigurer]; abstract=false; singleton=true; lazyInit=false; autowire=0; dependencyCheck=0; initMethodName=null; destroyMethodName=null; factoryMethodName=null; factoryBeanName=null; defined in class path resource [alfresco/core-services-context.xml]] with [Root bean: class [org.springframework.beans.factory.config.PropertyPlaceholderConfigurer]; abstract=false; singleton=true; lazyInit=false; autowire=0; dependencyCheck=0; initMethodName=null; destroyMethodName=null; factoryMethodName=null; factoryBeanName=null; defined in file [WEB-INF\classes\alfresco\extension\-custom-context.xml]] 11:09:25,041 INFO [DefaultListableBeanFactory] Overriding bean definition for bean 'hibernateConfigProperties': replacing [Root bean: class [org.springframework.beans.factory.config.PropertiesFactoryBean]; abstract=false; singleton=true; lazyInit=false; autowire=0; dependencyCheck=0; initMethodName=null; destroyMethodName=null; factoryMethodName=null; factoryBeanName=null; defined in class path resource [alfresco/hibernate-context.xml]] with [Root bean: class [org.springframework.beans.factory.config.PropertiesFactoryBean]; abstract=false; singleton=true; lazyInit=false; autowire=0; dependencyCheck=0; initMethodName=null; destroyMethodName=null; factoryMethodName=null; factoryBeanName=null; defined in file [WEB-INF\classes\alfresco\extension\-custom-context.xml]] 11:09:25,041 INFO [DefaultListableBeanFactory] Overriding bean definition for bean 'extension.dictionaryBootstrap': replacing [Child bean with parent 'dictionaryModelBootstrap': class [null]; abstract=false; singleton=true; lazyInit=false; autowire=0; dependencyCheck=0; initMethodName=null; destroyMethodName=null; factoryMethodName=null; factoryBeanName=null; defined in class path resource [alfresco/core-services-context.xml]] with [Child bean with parent 'dictionaryModelBootstrap': class [null]; abstract=false; singleton=true; lazyInit=false; autowire=0; dependencyCheck=0; initMethodName=null; destroyMethodName=null; factoryMethodName=null; factoryBeanName=null; defined in file [WEB-INF\classes\alfresco\extension\-custom-context.xml]] 11:09:25,041 INFO [XmlWebApplicationContext] Bean factory for application context [Root WebApplicationContext]: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [webClientConfigSource,webClientConfigService,dataDictionary,ticketCallbackHandler,querySessionCache,userQuerySessionCache,CMLUtil,authenticationWebService,repositoryWebService,contentWebService,authoringWebService,classificationWebService,actionWebService,accessControlWebService,administrationWebService,repository-properties,dataSource,transactionComponent,methodCallLogAdvice,resourceBundles,mailService,indexerComponent,indexerComponent_PerformanceMonitorAdvice,searchService,indexerAndSearcherFactory,categoryService,luceneIndexerAndSearcherFactory,luceneCategoryService,luceneIndexLock,lockService,versionService,versionNodeService,versionCounterDaoService,versionBootstrap,versionableAspect,namespaceDAO,dictionaryModelType,dictionaryDAO,dictionaryService,namespaceService,dictionaryModelBootstrap,dictionaryBootstrap,extension.dictionaryBootstrap,dictionaryRepositoryBootstrap,copyService,checkOutCheckInService,workingCopyAspect,discussableAspect,policyBehaviourFilter,policyComponent,LuceneFullTextSearchIndexer,luceneIndexBackupComponent,threadPoolExecutor,queryRegisterComponent,viewParser,importerComponent,storeImporter,userStoreImporter,systemStoreImporter,spacesStoreImporter,versionStoreImporter,exporterComponent,auditableAspect,referenceableAspect,configurableService,ehCacheManager,transactionalEHCacheManager,nullPermissionSharedCache,nullPermissionCache,userToAuthoritySharedCache,userToAuthorityCache,permissionsAccessSharedCache,permissionsAccessCache,nodeOwnerSharedCache,nodeOwnerCache,permissionService,permissionServiceImpl,ownerDynamicAuthority,lockOwnerDynamicAuthority,permissionsDAO,permissionsModelDAO,roleVoter,groupVoter,aclEntryVoter,accessDecisionManager,afterAcl,afterInvocationManager,NamespaceService_security,DictionaryService_security,NodeService_security,ContentService_security,MimetypeService_security,SearchService_security,CategoryService_security,CopyService_security,LockService_security,VersionService_security,CheckoutCheckinService_security,RuleService_security,ImporterService_security,ActionService_security,PermissionService_security,AuthorityService_security,AuthenticationService_security,OwnableService_security,PersonService_security,TemplateService_security,AlfrescoServiceDescriptor,ServiceRegistry,ServiceRegistry_descriptor,exceptionTranslator,DescriptorService,DescriptorService_descriptor,NamespaceService,NamespaceService_transaction,NamespaceService_descriptor,DictionaryService,DictionaryService_transaction,DictionaryService_descriptor,NodeService,NodeService_transaction,NodeService_descriptor,ContentService,ContentService_transaction,ContentService_descriptor,MimetypeService,MimetypeService_descriptor,SearchService,SearchService_transaction,SearchService_descriptor,CategoryService,CategoryService_transaction,CategoryService_descriptor,CopyService,CopyService_transaction,CopyService_descriptor,LockService,LockService_transaction,LockService_descriptor,VersionService,VersionService_transaction,VersionService_descriptor,CheckoutCheckinService,CheckoutCheckinService_transaction,CheckoutCheckinService_descriptor,RuleService,RuleService_transaction,RuleService_descriptor,ImporterService,ImporterService_transaction,ImporterService_descriptor,ExporterService,ExporterService_transaction,ExporterService_descriptor,ActionService,ActionService_transaction,ActionService_descriptor,PermissionService,PermissionService_transaction,PermissionService_descriptor,AuthorityService,AuthorityService_transaction,AuthorityService_descriptor,OwnableService,OwnableService_transaction,OwnableService_descriptor,PersonService,PersonService_transaction,PersonService_descriptor,AuthenticationService,AuthenticationService_transaction,AuthenticationService_descriptor,TemplateService,TemplateService_transaction,TemplateService_descriptor,FileFolderService,FileFolderService_transaction,fileFolderService,actionService,asynchronousActionExecutionQueue,actionsAspect,actionResourceBundles,action-condition-evaluator,no-condition,compare-property-value,compare-mime-type,in-category,is-subtype,has-aspect,has-version-history,action-executer,composite-action,create-version,add-features,specialise-type,link-category,simple-workflow,transform,transform-image,copy,move,check-in,check-out,mail,set-property-value,extract-metadata,import,export,ruleService,rulesAspect,ruleResourceBundles,rule-type-base,inbound,outbound,rule-trigger-base,on-create-node-trigger,on-update-node-trigger,on-property-update-trigger,on-delete-node-trigger,on-create-child-association-trigger,on-delete-child-association-trigger,on-create-association-trigger,on-delete-association-trigger,on-content-update-trigger,on-content-create-trigger,nodeDaoServiceImpl,dbNodeDaoServiceTxnRegistration,nodeDaoService,nodeService,dbNodeService,dbNodeService_PerformanceMonitorAdvice,nodeIndexer,integrityChecker,ftsIndexerTrigger,tempFileCleanerTrigger,contentStoreCleanerTrigger,indexRecoveryTrigger,indexBackupTrigger,ehCacheTracerJob,schedulerFactory,fileServersConfigSource,fileServersConfigService,fileServerConfigurationBase,contentDiskDriver,cifsHelper,fileContentStore,deletedContentStore,deletedContentBackupListener,contentStoreCleaner,contentService,mimetypeConfigService,mimetypeService,metadataExtracterRegistry,baseMetadataExtracter,org.alfresco.repo.content.metadata.PdfBoxMetadataExtracter,org.alfresco.repo.content.metadata.OfficeMetadataExtracter,org.alfresco.repo.content.metadata.HtmlMetadataExtracter,org.alfresco.repo.content.metadata.MP3MetadataExtracter,org.alfresco.repo.content.metadata.OpenDocumentMetadataExtracter,org.alfresco.repo.content.metadata.UnoMetadataExtracter,contentTransformerRegistry,baseContentTransformer,transformer.StringExtracter,transformer.BinaryPassThrough,transformer.PdfBox,transformer.Poi,transformer.TextMining,transformer.HtmlParser,transformer.OpenOffice,transformer.complex.OpenOffice.PdfBox,transformer.ImageMagick,hibernateConfigProperties,cacheStrategiesPlaceholderConfigurer,sessionFactory,transactionManager,ownableService,templateService,freeMarkerProcessor,indexRecoveryComponent,authorityService,authenticationManager,daoAuthenticationProvider,authenticatedAuthenticationPassthroughProvider,alfDaoImpl,authenticationDao,passwordEncoder,authenticationService,authenticationServiceImpl,authenticationComponent,authenticationComponentImpl,personService,ticketComponent,userBootstrap,systemBootstrap,spacesBootstrap,descriptorComponent,patchExecuter,fileServerConfiguration,cifsServer,ftpServer,startupLog,PatchService,PatchService_transaction,patchDaoComponent,patchComponent,basePatch,patch.sample.01,patch.sample.02,patch.savedSearches.Base,bootstrapSpacesMessageSource,patch.savedSearchesFolder,patch.savedSearchesPermission,patch.updatePermissionData,patch.guestUser,patch.fixNodeSerializableValues,patch.updateGuestPermission,patch.guestPersonPermission,patch.spacesRootPermission,patch.categoryRootPermission]; root of BeanFactory hierarchy 11:09:25,072 INFO [XmlWebApplicationContext] 319 beans defined in application context [Root WebApplicationContext] 11:09:25,152 INFO [PropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/repository.properties] 11:09:25,152 INFO [PropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/version.properties] 11:09:25,152 INFO [PropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/domain/transaction.properties] 11:09:25,152 INFO [PropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/extension/custom_.properties] 11:09:25,212 INFO [PropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/domain/cache-strategies.properties] 11:09:25,242 INFO [XmlWebApplicationContext] Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@df88d2] 11:09:25,242 INFO [XmlWebApplicationContext] Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@16e1ccd] 11:09:25,252 INFO [UiApplicationContextUtils] Unable to locate ThemeSource with name 'themeSource': using default [org.springframework.ui.context.support.ResourceBundleThemeSource@70cdd2] 11:09:25,422 INFO [PropertiesFactoryBean] Loading properties file from class path resource [alfresco/domain/hibernate-cfg.properties] 11:09:25,422 INFO [PropertiesFactoryBean] Loading properties file from class path resource [alfresco/extension/custom_.properties] 11:09:25,472 INFO [Environment] Hibernate 3.1.2 11:09:25,492 INFO [Environment] hibernate.properties not found 11:09:25,492 INFO [Environment] using CGLIB reflection optimizer 11:09:25,492 INFO [Environment] using JDK 1.4 java.sql.Timestamp handling 11:09:26,794 INFO [HbmBinder] Mapping class: org.alfresco.repo.domain.hibernate.NodeImpl -> node 11:09:27,255 INFO [HbmBinder] Mapping collection: org.alfresco.repo.domain.hibernate.NodeImpl.properties -> node_properties 11:09:27,265 INFO [HbmBinder] Mapping collection: org.alfresco.repo.domain.hibernate.NodeImpl.aspects -> node_aspects 11:09:27,265 INFO [HbmBinder] Mapping class: org.alfresco.repo.domain.hibernate.NodeStatusImpl -> node_status 11:09:27,265 INFO [HbmBinder] Mapping class: org.alfresco.repo.domain.hibernate.ChildAssocImpl -> child_assoc 11:09:27,275 INFO [HbmBinder] Mapping class: org.alfresco.repo.domain.hibernate.NodeAssocImpl -> node_assoc 11:09:27,315 INFO [HbmBinder] Mapping class: org.alfresco.repo.domain.hibernate.StoreImpl -> store 11:09:27,335 INFO [HbmBinder] Mapping class: org.alfresco.repo.domain.hibernate.VersionCountImpl -> version_count 11:09:27,495 INFO [HbmBinder] Mapping class: org.alfresco.repo.domain.hibernate.AppliedPatchImpl -> applied_patch 11:09:27,535 INFO [HbmBinder] Mapping class: org.alfresco.repo.security.permissions.impl.hibernate.NodePermissionEntryImpl -> node_permission 11:09:27,535 INFO [HbmBinder] Mapping class: org.alfresco.repo.security.permissions.impl.hibernate.PermissionEntryImpl -> node_perm_entry 11:09:27,555 INFO [HbmBinder] Mapping class: org.alfresco.repo.security.permissions.impl.hibernate.PermissionReferenceImpl -> permission_ref 11:09:27,555 INFO [HbmBinder] Mapping class: org.alfresco.repo.security.permissions.impl.hibernate.RecipientImpl -> recipient 11:09:27,555 INFO [HbmBinder] Mapping collection: org.alfresco.repo.security.permissions.impl.hibernate.RecipientImpl.externalKeys -> externalKeys 11:09:27,555 INFO [LocalSessionFactoryBean] Building new Hibernate SessionFactory 11:09:27,565 INFO [HbmBinder] Mapping collection: org.alfresco.repo.domain.hibernate.NodeImpl.parentAssocs -> child_assoc 11:09:27,575 INFO [HbmBinder] Mapping collection: org.alfresco.repo.domain.hibernate.NodeImpl.childAssocs -> child_assoc 11:09:27,575 INFO [HbmBinder] Mapping collection: org.alfresco.repo.domain.hibernate.NodeImpl.sourceNodeAssocs -> node_assoc 11:09:27,575 INFO [HbmBinder] Mapping collection: org.alfresco.repo.domain.hibernate.NodeImpl.targetNodeAssocs -> node_assoc 11:09:27,575 INFO [HbmBinder] Mapping collection: org.alfresco.repo.security.permissions.impl.hibernate.NodePermissionEntryImpl.permissionEntries -> node_perm_entry 11:09:28,076 INFO [ConnectionProviderFactory] Initializing connection provider: org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider 11:09:29,187 INFO [SettingsFactory] RDBMS: MySQL, version: 5.0.15 11:09:29,187 INFO [SettingsFactory] JDBC driver: MySQL-AB JDBC Driver, version: mysql-connector-java-3.1.10 ( $Date: 2005/05/19 15:52:23 $, $Revision: 1.1.2.2 $ ) 11:09:29,248 INFO [Dialect] Using dialect: org.hibernate.dialect.MySQLDialect 11:09:29,268 INFO [TransactionFactoryFactory] Using default transaction strategy (direct JDBC transactions) 11:09:29,278 INFO [TransactionManagerLookupFactory] No TransactionManagerLookup configured (in JTA environment, use of read-write or transactional second-level cache is not recommended) 11:09:29,278 INFO [SettingsFactory] Automatic flush during beforeCompletion(): disabled 11:09:29,278 INFO [SettingsFactory] Automatic session close at end of transaction: disabled 11:09:29,278 INFO [SettingsFactory] JDBC batch size: 32 11:09:29,278 INFO [SettingsFactory] JDBC batch updates for versioned data: disabled 11:09:29,278 INFO [SettingsFactory] Scrollable result sets: enabled 11:09:29,278 INFO [SettingsFactory] JDBC3 getGeneratedKeys(): enabled 11:09:29,278 INFO [SettingsFactory] Connection release mode: auto 11:09:29,278 INFO [SettingsFactory] Maximum outer join fetch depth: 10 11:09:29,278 INFO [SettingsFactory] Default batch fetch size: 1 11:09:29,278 INFO [SettingsFactory] Generate SQL with comments: disabled 11:09:29,278 INFO [SettingsFactory] Order SQL updates by primary key: disabled 11:09:29,278 INFO [SettingsFactory] Query translator: org.hibernate.hql.ast.ASTQueryTranslatorFactory 11:09:29,288 INFO [ASTQueryTranslatorFactory] Using ASTQueryTranslatorFactory 11:09:29,288 INFO [SettingsFactory] Query language substitutions: {} 11:09:29,288 INFO [SettingsFactory] Second-level cache: enabled 11:09:29,288 INFO [SettingsFactory] Query cache: enabled 11:09:29,288 INFO [SettingsFactory] Cache provider: org.hibernate.cache.EhCacheProvider 11:09:29,288 INFO [SettingsFactory] Optimize cache for minimal puts: disabled 11:09:29,288 INFO [SettingsFactory] Structured second-level cache entries: disabled 11:09:29,288 INFO [SettingsFactory] Query cache factory: org.hibernate.cache.StandardQueryCacheFactory 11:09:29,308 INFO [SettingsFactory] Statistics: disabled 11:09:29,308 INFO [SettingsFactory] Deleted entity synthetic identifier rollback: disabled 11:09:29,308 INFO [SettingsFactory] Default entity-mode: pojo 11:09:29,388 INFO [SessionFactoryImpl] building session factory 11:09:30,409 INFO [SessionFactoryObjectFactory] Not binding factory to JNDI, no JNDI name configured 11:09:30,419 INFO [SchemaUpdate] Running hbm2ddl schema update 11:09:30,419 INFO [SchemaUpdate] fetching database metadata 11:09:30,429 INFO [SchemaUpdate] updating schema 11:09:30,579 INFO [TableMetadata] table found: alfresco.applied_patch 11:09:30,579 INFO [TableMetadata] columns: [succeeded, target_schema, fixes_to_schema, applied_on_date, fixes_from_schema, was_executed, applied_to_schema, applied_to_server, report, description, id] 11:09:30,579 INFO [TableMetadata] foreign keys: [] 11:09:30,579 INFO [TableMetadata] indexes: [primary] 11:09:30,640 INFO [TableMetadata] table found: alfresco.child_assoc 11:09:30,640 INFO [TableMetadata] columns: [isprimary, type_qname, child_protocol, assoc_index, parent_guid, qname, child_guid, child_identifier, parent_identifier, id, parent_protocol] 11:09:30,640 INFO [TableMetadata] foreign keys: [fkc6efff32a0f28d72, fkc6efff3294135688] 11:09:30,640 INFO [TableMetadata] indexes: [primary, fkc6efff32a0f28d72, fkc6efff3294135688] 11:09:30,690 INFO [TableMetadata] table found: alfresco.externalkeys 11:09:30,690 INFO [TableMetadata] columns: [externalkey, id] 11:09:30,690 INFO [TableMetadata] foreign keys: [fkad60285faadd7239] 11:09:30,690 INFO [TableMetadata] indexes: [fkad60285faadd7239, primary] 11:09:30,750 INFO [TableMetadata] table found: alfresco.node 11:09:30,750 INFO [TableMetadata] columns: [type_qname, protocol, guid, identifier] 11:09:30,750 INFO [TableMetadata] foreign keys: [fk33ae021c9053b, fk33ae02d24add25] 11:09:30,750 INFO [TableMetadata] indexes: [primary, fk33ae021c9053b, fk33ae02d24add25] 11:09:30,840 INFO [TableMetadata] table found: alfresco.node_aspects 11:09:30,840 INFO [TableMetadata] columns: [protocol, qname, guid, identifier] 11:09:30,840 INFO [TableMetadata] foreign keys: [fk2b91a9de65e86569] 11:09:30,840 INFO [TableMetadata] indexes: [fk2b91a9de65e86569] 11:09:30,920 INFO [TableMetadata] table found: alfresco.node_assoc 11:09:30,920 INFO [TableMetadata] columns: [target_guid, source_identifier, source_protocol, type_qname, target_protocol, target_identifier, source_guid, id] 11:09:30,920 INFO [TableMetadata] foreign keys: [fk5baef398b9dee1b3, fk5baef3984e68a555] 11:09:30,920 INFO [TableMetadata] indexes: [primary, fk5baef398b9dee1b3, fk5baef3984e68a555] 11:09:31,260 INFO [TableMetadata] table found: alfresco.node_perm_entry 11:09:31,260 INFO [TableMetadata] columns: [protocol, typeuri, guid, identifier, name, typename, id, allowed, recipient] 11:09:31,260 INFO [TableMetadata] foreign keys: [fkcfe31cc0dbbed737, fkcfe31cc05a6a54c3, fkcfe31cc026f66010] 11:09:31,260 INFO [TableMetadata] indexes: [fkcfe31cc0dbbed737, primary, fkcfe31cc05a6a54c3, fkcfe31cc026f66010] 11:09:31,341 INFO [TableMetadata] table found: alfresco.node_permission 11:09:31,341 INFO [TableMetadata] columns: [protocol, inherits, guid, identifier] 11:09:31,341 INFO [TableMetadata] foreign keys: [] 11:09:31,341 INFO [TableMetadata] indexes: [primary] 11:09:31,411 INFO [TableMetadata] table found: alfresco.node_properties 11:09:31,411 INFO [TableMetadata] columns: [protocol, multi_valued, persisted_type, qname, long_value, string_value, double_value, boolean_value, serializable_value, actual_type, guid, float_value, identifier] 11:09:31,411 INFO [TableMetadata] foreign keys: [fkc962bf9065e86569] 11:09:31,411 INFO [TableMetadata] indexes: [primary, fkc962bf9065e86569] 11:09:31,481 INFO [TableMetadata] table found: alfresco.node_status 11:09:31,481 INFO [TableMetadata] columns: [deleted, protocol, guid, identifier, change_txn_id] 11:09:31,481 INFO [TableMetadata] foreign keys: [] 11:09:31,481 INFO [TableMetadata] indexes: [primary] 11:09:31,531 INFO [TableMetadata] table found: alfresco.permission_ref 11:09:31,531 INFO [TableMetadata] columns: [type_uri, type_name, name] 11:09:31,531 INFO [TableMetadata] foreign keys: [] 11:09:31,531 INFO [TableMetadata] indexes: [primary] 11:09:31,591 INFO [TableMetadata] table found: alfresco.recipient 11:09:31,591 INFO [TableMetadata] columns: [recipient] 11:09:31,591 INFO [TableMetadata] foreign keys: [] 11:09:31,591 INFO [TableMetadata] indexes: [primary] 11:09:31,641 INFO [TableMetadata] table found: alfresco.store 11:09:31,641 INFO [TableMetadata] columns: [protocol, root_identifier, root_guid, root_protocol, identifier] 11:09:31,641 INFO [TableMetadata] foreign keys: [fk68af8e11f473ce0] 11:09:31,641 INFO [TableMetadata] indexes: [primary, fk68af8e11f473ce0] 11:09:31,701 INFO [TableMetadata] table found: alfresco.version_count 11:09:31,701 INFO [TableMetadata] columns: [protocol, version_count, identifier] 11:09:31,701 INFO [TableMetadata] foreign keys: [] 11:09:31,701 INFO [TableMetadata] indexes: [primary] 11:09:31,711 INFO [SchemaUpdate] schema update complete 11:09:31,711 INFO [UpdateTimestampsCache] starting update timestamps cache at region: org.hibernate.cache.UpdateTimestampsCache 11:09:31,721 INFO [StandardQueryCache] starting query cache at region: org.hibernate.cache.StandardQueryCache 11:09:34,095 INFO [HibernateTransactionManager] Using DataSource [org.apache.commons.dbcp.BasicDataSource@1628303] of Hibernate SessionFactory for HibernateTransactionManager 11:09:34,125 INFO [DefaultAopProxyFactory] CGLIB2 available: proxyTargetClass feature enabled 11:09:34,936 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}beforeCreateStore (interface org.alfresco.repo.node.NodeServicePolicies$BeforeCreateStorePolicy) 11:09:34,946 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}onCreateStore (interface org.alfresco.repo.node.NodeServicePolicies$OnCreateStorePolicy) 11:09:34,946 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}beforeCreateNode (interface org.alfresco.repo.node.NodeServicePolicies$BeforeCreateNodePolicy) 11:09:34,946 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}onCreateNode (interface org.alfresco.repo.node.NodeServicePolicies$OnCreateNodePolicy) 11:09:34,946 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}beforeUpdateNode (interface org.alfresco.repo.node.NodeServicePolicies$BeforeUpdateNodePolicy) 11:09:34,946 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}onUpdateNode (interface org.alfresco.repo.node.NodeServicePolicies$OnUpdateNodePolicy) 11:09:34,946 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}onUpdateProperties (interface org.alfresco.repo.node.NodeServicePolicies$OnUpdatePropertiesPolicy) 11:09:34,946 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}beforeDeleteNode (interface org.alfresco.repo.node.NodeServicePolicies$BeforeDeleteNodePolicy) 11:09:34,956 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}onDeleteNode (interface org.alfresco.repo.node.NodeServicePolicies$OnDeleteNodePolicy) 11:09:34,966 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}beforeAddAspect (interface org.alfresco.repo.node.NodeServicePolicies$BeforeAddAspectPolicy) 11:09:34,966 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}onAddAspect (interface org.alfresco.repo.node.NodeServicePolicies$OnAddAspectPolicy) 11:09:34,966 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}beforeRemoveAspect (interface org.alfresco.repo.node.NodeServicePolicies$BeforeRemoveAspectPolicy) 11:09:34,966 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}onRemoveAspect (interface org.alfresco.repo.node.NodeServicePolicies$OnRemoveAspectPolicy) 11:09:34,966 INFO [PolicyComponentImpl] Registered association policy {http://www.alfresco.org}beforeCreateChildAssociation (interface org.alfresco.repo.node.NodeServicePolicies$BeforeCreateChildAssociationPolicy) 11:09:34,966 INFO [PolicyComponentImpl] Registered association policy {http://www.alfresco.org}onCreateChildAssociation (interface org.alfresco.repo.node.NodeServicePolicies$OnCreateChildAssociationPolicy) 11:09:34,976 INFO [PolicyComponentImpl] Registered association policy {http://www.alfresco.org}beforeDeleteChildAssociation (interface org.alfresco.repo.node.NodeServicePolicies$BeforeDeleteChildAssociationPolicy) 11:09:34,976 INFO [PolicyComponentImpl] Registered association policy {http://www.alfresco.org}onDeleteChildAssociation (interface org.alfresco.repo.node.NodeServicePolicies$OnDeleteChildAssociationPolicy) 11:09:34,976 INFO [PolicyComponentImpl] Registered association policy {http://www.alfresco.org}onCreateAssociation (interface org.alfresco.repo.node.NodeServicePolicies$OnCreateAssociationPolicy) 11:09:34,976 INFO [PolicyComponentImpl] Registered association policy {http://www.alfresco.org}onDeleteAssociation (interface org.alfresco.repo.node.NodeServicePolicies$OnDeleteAssociationPolicy) 11:09:35,376 INFO [PolicyComponentImpl] Bound Java method[class=org.alfresco.repo.content.RoutingContentService, method=onUpdateProperties] to policy {http://www.alfresco.org}onUpdateProperties for service org.alfresco.repo.content.RoutingContentService@1e4e6db 11:09:35,376 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}onContentUpdate (interface org.alfresco.repo.content.ContentServicePolicies$OnContentUpdatePolicy) 11:09:35,386 INFO [PolicyComponentImpl] Registered class policy {http://www.alfresco.org}onContentRead (interface org.alfresco.repo.content.ContentServicePolicies$OnContentReadPolicy) 11:09:35,547 INFO [EhCacheFactoryBean] Using default EHCache CacheManager for cache region 'nullPermissionCache' 11:09:35,547 INFO [EhCacheFactoryBean] Creating new EHCache cache region 'nullPermissionCache' 11:09:35,557 INFO [EhCacheManagerFactoryBean] Initializing EHCache CacheManager 11:09:35,637 INFO [EhCacheFactoryBean] Using default EHCache CacheManager for cache region 'permissionsAccessCache' 11:09:35,637 INFO [EhCacheFactoryBean] Creating new EHCache cache region 'permissionsAccessCache' 11:09:35,697 INFO [EhCacheFactoryBean] Using default EHCache CacheManager for cache region 'nodeOwnerCache' 11:09:35,697 INFO [EhCacheFactoryBean] Creating new EHCache cache region 'nodeOwnerCache' 11:09:35,717 INFO [PolicyComponentImpl] Behaviour Java method[class=org.alfresco.repo.lock.LockServiceImpl, method=checkForLock] is binding (ClassBinding[class={http://www.alfresco.org/model/content/1.0}lockable]) to policy {http://www.alfresco.org}beforeCreateVersion before the policy is registered 11:09:35,717 INFO [PolicyComponentImpl] Bound Java method[class=org.alfresco.repo.lock.LockServiceImpl, method=checkForLock] to policy {http://www.alfresco.org}beforeCreateVersion for class {http://www.alfresco.org/model/content/1.0}lockable 11:09:35,717 INFO [PolicyComponentImpl] Bound Java method[class=org.alfresco.repo.lock.LockServiceImpl, method=checkForLock] to policy {http://www.alfresco.org}beforeUpdateNode for class {http://www.alfresco.org/model/content/1.0}lockable 11:09:35,717 INFO [PolicyComponentImpl] Bound Java method[class=org.alfresco.repo.lock.LockServiceImpl, method=checkForLock] to policy {http://www.alfresco.org}beforeDeleteNode for class {http://www.alfresco.org/model/content/1.0}lockable 11:09:35,717 INFO [PolicyComponentImpl] Behaviour Java method[class=org.alfresco.repo.lock.LockServiceImpl, method=onCopy] is binding (ClassBinding[class={http://www.alfresco.org/model/content/1.0}lockable]) to policy {http://www.alfresco.org}onCopyNode before the policy is registered 11:09:35,717 INFO [PolicyComponentImpl] Bound Java method[class=org.alfresco.repo.lock.LockServiceImpl, method=onCopy] to policy {http://www.alfresco.org}onCopyNode for class {http://www.alfresco.org/model/content/1.0}lockable 11:09:35,717 INFO [PolicyComponentImpl] Behaviour Java method[class=org.alfresco.repo.lock.LockServiceImpl, method=onCreateVersion] is binding (ClassBinding[class={http://www.alfresco.org/model/content/1.0}lockable]) to policy {http://www.alfresco.org}onCreateVersion before the policy is registered 11:09:35,717 INFO [PolicyComponentImpl] Bound Java method[class=org.alfresco.repo.lock.LockServiceImpl, method=onCreateVersion] to policy {http://www.alfresco.org}onCreateVersion for class {http://www.alfresco.org/model/content/1.0}lockable 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract void org.alfresco.service.cmr.repository.NodeService.setProperties(org.alfresco.service.cmr.repository.NodeRef,java.util.Map) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.WriteProperties]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.List org.alfresco.service.cmr.repository.NodeService.getStores()] with attributes [[AFTER_ACL_NODE.sys:base.Read]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract void org.alfresco.service.cmr.repository.NodeService.addAspect(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName,java.util.Map) throws org.alfresco.service.cmr.repository.InvalidNodeRefException,org.alfresco.service.cmr.dictionary.InvalidAspectException] with attributes [[ACL_NODE.0.sys:base.Write]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract void org.alfresco.service.cmr.repository.NodeService.removeAssociation(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ROLE_AUTHENTICATED]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.List org.alfresco.service.cmr.repository.NodeService.getChildAssocs(org.alfresco.service.cmr.repository.NodeRef) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.ReadChildren, AFTER_ACL_NODE.sys:base.Read]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.List org.alfresco.service.cmr.repository.NodeService.getChildAssocs(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QNamePattern,org.alfresco.service.namespace.QNamePattern) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.ReadChildren, AFTER_ACL_NODE.sys:base.Read]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract void org.alfresco.service.cmr.repository.NodeService.removeChild(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.cmr.repository.NodeRef) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.1.sys:base.Delete]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract void org.alfresco.service.cmr.repository.NodeService.removeAspect(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName) throws org.alfresco.service.cmr.repository.InvalidNodeRefException,org.alfresco.service.cmr.dictionary.InvalidAspectException] with attributes [[ACL_NODE.0.sys:base.Write]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract void org.alfresco.service.cmr.repository.NodeService.setType(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.Write]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract void org.alfresco.service.cmr.repository.NodeService.deleteNode(org.alfresco.service.cmr.repository.NodeRef) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.Delete]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract void org.alfresco.service.cmr.repository.NodeService.setChildAssociationIndex(org.alfresco.service.cmr.repository.ChildAssociationRef,int) throws org.alfresco.service.cmr.repository.InvalidChildAssociationRefException] with attributes [[ACL_PARENT.0.sys:base.WriteProperties]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.Set org.alfresco.service.cmr.repository.NodeService.getAspects(org.alfresco.service.cmr.repository.NodeRef) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.ReadProperties]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.ChildAssociationRef org.alfresco.service.cmr.repository.NodeService.moveNode(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName,org.alfresco.service.namespace.QName) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.WriteProperties, ACL_PARENT.0.sys:base.DeleteChildren, ACL_NODE.1.sys:base.CreateChildren]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.AssociationRef org.alfresco.service.cmr.repository.NodeService.createAssociation(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName) throws org.alfresco.service.cmr.repository.InvalidNodeRefException,org.alfresco.service.cmr.repository.AssociationExistsException] with attributes [[ROLE_AUTHENTICATED]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.namespace.QName org.alfresco.service.cmr.repository.NodeService.getType(org.alfresco.service.cmr.repository.NodeRef) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.Read]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.StoreRef org.alfresco.service.cmr.repository.NodeService.createStore(java.lang.String,java.lang.String) throws org.alfresco.service.cmr.repository.StoreExistsException] with attributes [[ACL_METHOD.ROLE_ADMINISTRATOR]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract boolean org.alfresco.service.cmr.repository.NodeService.exists(org.alfresco.service.cmr.repository.NodeRef)] with attributes [[ACL_NODE.0.sys:base.Read]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract boolean org.alfresco.service.cmr.repository.NodeService.exists(org.alfresco.service.cmr.repository.StoreRef)] with attributes [[ACL_NODE.0.sys:base.Read]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.ChildAssociationRef org.alfresco.service.cmr.repository.NodeService.getPrimaryParent(org.alfresco.service.cmr.repository.NodeRef) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.ReadProperties, AFTER_ACL_PARENT.sys:base.Read]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.ChildAssociationRef org.alfresco.service.cmr.repository.NodeService.addChild(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName,org.alfresco.service.namespace.QName) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.CreateChildren, ACL_NODE.1.sys:base.ReadProperties]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.List org.alfresco.service.cmr.repository.NodeService.getParentAssocs(org.alfresco.service.cmr.repository.NodeRef) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.ReadProperties, AFTER_ACL_PARENT.sys:base.Read]] 11:09:35,767 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.List org.alfresco.service.cmr.repository.NodeService.getParentAssocs(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QNamePattern,org.alfresco.service.namespace.QNamePattern) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.ReadProperties, AFTER_ACL_PARENT.sys:base.Read]] 11:09:35,777 INFO [MethodDefinitionMap] Adding secure method [public abstract java.io.Serializable org.alfresco.service.cmr.repository.NodeService.getProperty(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.ReadProperties]] 11:09:35,777 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.List org.alfresco.service.cmr.repository.NodeService.getSourceAssocs(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QNamePattern) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ROLE_AUTHENTICATED]] 11:09:35,777 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.NodeRef org.alfresco.service.cmr.repository.NodeService.getRootNode(org.alfresco.service.cmr.repository.StoreRef) throws org.alfresco.service.cmr.repository.InvalidStoreRefException] with attributes [[ACL_NODE.0.sys:base.Read]] 11:09:35,777 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.ChildAssociationRef org.alfresco.service.cmr.repository.NodeService.createNode(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName,org.alfresco.service.namespace.QName,org.alfresco.service.namespace.QName,java.util.Map) throws org.alfresco.service.cmr.repository.InvalidNodeRefException,org.alfresco.service.cmr.dictionary.InvalidTypeException] with attributes [[ACL_NODE.0.sys:base.CreateChildren]] 11:09:35,777 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.ChildAssociationRef org.alfresco.service.cmr.repository.NodeService.createNode(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName,org.alfresco.service.namespace.QName,org.alfresco.service.namespace.QName) throws org.alfresco.service.cmr.repository.InvalidNodeRefException,org.alfresco.service.cmr.dictionary.InvalidTypeException] with attributes [[ACL_NODE.0.sys:base.CreateChildren]] 11:09:35,777 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.List org.alfresco.service.cmr.repository.NodeService.getTargetAssocs(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QNamePattern) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ROLE_AUTHENTICATED]] 11:09:35,777 INFO [MethodDefinitionMap] Adding secure method [public abstract void org.alfresco.service.cmr.repository.NodeService.setProperty(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName,java.io.Serializable) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.WriteProperties]] 11:09:35,777 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.Map org.alfresco.service.cmr.repository.NodeService.getProperties(org.alfresco.service.cmr.repository.NodeRef) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.ReadProperties]] 11:09:35,777 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.Path org.alfresco.service.cmr.repository.NodeService.getPath(org.alfresco.service.cmr.repository.NodeRef) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.ReadProperties]] 11:09:35,777 INFO [MethodDefinitionMap] Adding secure method [public abstract boolean org.alfresco.service.cmr.repository.NodeService.hasAspect(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName) throws org.alfresco.service.cmr.repository.InvalidNodeRefException,org.alfresco.service.cmr.dictionary.InvalidAspectException] with attributes [[ACL_NODE.0.sys:base.ReadProperties]] 11:09:35,777 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.List org.alfresco.service.cmr.repository.NodeService.getPaths(org.alfresco.service.cmr.repository.NodeRef,boolean) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.ReadProperties]] 11:09:35,777 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.NodeRef$Status org.alfresco.service.cmr.repository.NodeService.getNodeStatus(org.alfresco.service.cmr.repository.NodeRef)] with attributes [[ACL_NODE.0.sys:base.Read]] 11:09:35,777 INFO [AbstractSecurityInterceptor] Validated configuration attributes 11:09:35,787 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.List org.alfresco.service.cmr.search.SearchService.selectProperties(org.alfresco.service.cmr.repository.NodeRef,java.lang.String,org.alfresco.service.cmr.search.QueryParameterDefinition[],org.alfresco.service.namespace.NamespacePrefixResolver,boolean) throws org.alfresco.service.cmr.repository.InvalidNodeRefException,org.alfresco.service.cmr.repository.XPathException] with attributes [[ACL_NODE.0.sys:base.Read]] 11:09:35,787 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.List org.alfresco.service.cmr.search.SearchService.selectProperties(org.alfresco.service.cmr.repository.NodeRef,java.lang.String,org.alfresco.service.cmr.search.QueryParameterDefinition[],org.alfresco.service.namespace.NamespacePrefixResolver,boolean,java.lang.String) throws org.alfresco.service.cmr.repository.InvalidNodeRefException,org.alfresco.service.cmr.repository.XPathException] with attributes [[ACL_NODE.0.sys:base.Read]] 11:09:35,797 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.search.ResultSet org.alfresco.service.cmr.search.SearchService.query(org.alfresco.service.cmr.repository.StoreRef,java.lang.String,java.lang.String,org.alfresco.service.cmr.repository.Path[])] with attributes [[AFTER_ACL_NODE.sys:base.Read]] 11:09:35,797 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.search.ResultSet org.alfresco.service.cmr.search.SearchService.query(org.alfresco.service.cmr.repository.StoreRef,org.alfresco.service.namespace.QName,org.alfresco.service.cmr.search.QueryParameter[])] with attributes [[AFTER_ACL_NODE.sys:base.Read]] 11:09:35,797 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.search.ResultSet org.alfresco.service.cmr.search.SearchService.query(org.alfresco.service.cmr.search.SearchParameters)] with attributes [[AFTER_ACL_NODE.sys:base.Read]] 11:09:35,797 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.search.ResultSet org.alfresco.service.cmr.search.SearchService.query(org.alfresco.service.cmr.repository.StoreRef,java.lang.String,java.lang.String,org.alfresco.service.cmr.search.QueryParameterDefinition[])] with attributes [[AFTER_ACL_NODE.sys:base.Read]] 11:09:35,797 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.search.ResultSet org.alfresco.service.cmr.search.SearchService.query(org.alfresco.service.cmr.repository.StoreRef,java.lang.String,java.lang.String)] with attributes [[AFTER_ACL_NODE.sys:base.Read]] 11:09:35,797 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.search.ResultSet org.alfresco.service.cmr.search.SearchService.query(org.alfresco.service.cmr.repository.StoreRef,java.lang.String,java.lang.String,org.alfresco.service.cmr.repository.Path[],org.alfresco.service.cmr.search.QueryParameterDefinition[])] with attributes [[AFTER_ACL_NODE.sys:base.Read]] 11:09:35,797 INFO [MethodDefinitionMap] Adding secure method [public abstract boolean org.alfresco.service.cmr.search.SearchService.contains(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName,java.lang.String,org.alfresco.service.cmr.search.SearchParameters$Operator) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.Read]] 11:09:35,797 INFO [MethodDefinitionMap] Adding secure method [public abstract boolean org.alfresco.service.cmr.search.SearchService.contains(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName,java.lang.String) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.Read]] 11:09:35,797 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.List org.alfresco.service.cmr.search.SearchService.selectNodes(org.alfresco.service.cmr.repository.NodeRef,java.lang.String,org.alfresco.service.cmr.search.QueryParameterDefinition[],org.alfresco.service.namespace.NamespacePrefixResolver,boolean) throws org.alfresco.service.cmr.repository.InvalidNodeRefException,org.alfresco.service.cmr.repository.XPathException] with attributes [[AFTER_ACL_NODE.sys:base.Read]] 11:09:35,797 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.List org.alfresco.service.cmr.search.SearchService.selectNodes(org.alfresco.service.cmr.repository.NodeRef,java.lang.String,org.alfresco.service.cmr.search.QueryParameterDefinition[],org.alfresco.service.namespace.NamespacePrefixResolver,boolean,java.lang.String) throws org.alfresco.service.cmr.repository.InvalidNodeRefException,org.alfresco.service.cmr.repository.XPathException] with attributes [[AFTER_ACL_NODE.sys:base.Read]] 11:09:35,797 INFO [MethodDefinitionMap] Adding secure method [public abstract boolean org.alfresco.service.cmr.search.SearchService.like(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName,java.lang.String,boolean) throws org.alfresco.service.cmr.repository.InvalidNodeRefException] with attributes [[ACL_NODE.0.sys:base.Read]] 11:09:35,797 INFO [AbstractSecurityInterceptor] Validated configuration attributes 11:09:35,817 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.ContentReader org.alfresco.service.cmr.repository.ContentService.getReader(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName) throws org.alfresco.service.cmr.repository.InvalidNodeRefException,org.alfresco.service.cmr.dictionary.InvalidTypeException] with attributes [[ACL_NODE.0.cm:content.ReadContent]] 11:09:35,817 INFO [MethodDefinitionMap] Adding secure method [public abstract void org.alfresco.service.cmr.repository.ContentService.transform(org.alfresco.service.cmr.repository.ContentReader,org.alfresco.service.cmr.repository.ContentWriter) throws org.alfresco.service.cmr.repository.NoTransformerException,org.alfresco.service.cmr.repository.ContentIOException] with attributes [[ACL_ALLOW]] 11:09:35,817 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.ContentWriter org.alfresco.service.cmr.repository.ContentService.getTempWriter()] with attributes [[ACL_ALLOW]] 11:09:35,817 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.repository.ContentWriter org.alfresco.service.cmr.repository.ContentService.getWriter(org.alfresco.service.cmr.repository.NodeRef,org.alfresco.service.namespace.QName,boolean) throws org.alfresco.service.cmr.repository.InvalidNodeRefException,org.alfresco.service.cmr.dictionary.InvalidTypeException] with attributes [[ACL_NODE.0.cm:content.WriteContent]] 11:09:35,817 INFO [MethodDefinitionMap] Adding secure method [public abstract boolean org.alfresco.service.cmr.repository.ContentService.isTransformable(org.alfresco.service.cmr.repository.ContentReader,org.alfresco.service.cmr.repository.ContentWriter)] with attributes [[ACL_ALLOW]] 11:09:35,817 INFO [AbstractSecurityInterceptor] Validated configuration attributes 11:09:35,897 INFO [MethodDefinitionMap] Adding secure method [public abstract void org.alfresco.service.cmr.security.PermissionService.clearPermission(org.alfresco.service.cmr.repository.NodeRef,java.lang.String)] with attributes [[ACL_NODE.0.sys:base.ChangePermissions]] 11:09:35,897 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.Set org.alfresco.service.cmr.security.PermissionService.getSettablePermissions(org.alfresco.service.cmr.repository.NodeRef)] with attributes [[ACL_ALLOW]] 11:09:35,897 INFO [MethodDefinitionMap] Adding secure method [public abstract java.util.Set org.alfresco.service.cmr.security.PermissionService.getSettablePermissions(org.alfresco.service.namespace.QName)] with attributes [[ACL_ALLOW]] 11:09:35,897 INFO [MethodDefinitionMap] Adding secure method [public abstract java.lang.String org.alfresco.service.cmr.security.PermissionService.getOwnerAuthority()] with attributes [[ACL_ALLOW]] 11:09:35,897 INFO [MethodDefinitionMap] Adding secure method [public abstract org.alfresco.service.cmr.security.AccessStatus org.alfresco.service.cmr.security.PermissionService.hasPermission(org.alfresco.service.cmr.repository.NodeRef,java.lang.String)] with attributes [[ACL_ALLOW]] 11:09:35,897 INFO [MethodDefinitionMap] Adding secure method [public abstract boolean org.alfresco.service.cmr.security.PermissionService.getInheritParentPermissions(org.alfresco.service.cmr.repository.NodeRef)] with attributes [[ACL_ALLOW]] 11:09:35,897 INFO [MethodDefinitionMap] Adding secure method [public abstract java.lang.String org.alfresco.service.cmr.security.PermissionService.getAllAuthorities()] with attributes [[ACL_ALLOW]] 11:09:35,897 INFO [MethodDefinitionMap] Adding secure method [public abstract void org.alfresco.service.cmr.security.PermissionService.setPermission(org.alfresco.service.cmr.repository.NodeRef,java.lang.String,java.lang.String,boolean)] with attributes [[ACL_NODE.0.sys:base.ChangePermissions]] 11:0
11:09:40,904 INFO [RAMJobStore] RAMJobStore initialized. 11:09:40,914 INFO [StdSchedulerFactory] Quartz scheduler 'QuartzScheduler' initialized from an externally provided properties instance. 11:09:40,914 INFO [StdSchedulerFactory] Quartz scheduler version: 1.4.5 11:09:40,914 INFO [SchedulerFactoryBean] Starting Quartz scheduler now 11:09:40,914 INFO [QuartzScheduler] Scheduler QuartzScheduler_$_NON_CLUSTERED started. 11:09:41,936 INFO [STDOUT] Mar 9, 2006 11:09:41 AM net.sf.joott.uno.UnoConnection connect INFO: connecting using "socket,host=localhost,port=8100,tcpNoDelay=1"… 11:09:43,138 INFO [STDOUT] Mar 9, 2006 11:09:43 AM net.sf.joott.uno.UnoConnection connect SEVERE: connection failed: com.sun.star.connection.NoConnectException: java.net.ConnectException: Connection refused: connect 11:09:43,338 INFO [STDOUT] Mar 9, 2006 11:09:43 AM net.sf.joott.uno.UnoConnection connect INFO: connecting using "socket,host=localhost,port=8100,tcpNoDelay=1"… 11:09:44,349 INFO [STDOUT] Mar 9, 2006 11:09:44 AM net.sf.joott.uno.UnoConnection connect SEVERE: connection failed: com.sun.star.connection.NoConnectException: java.net.ConnectException: Connection refused: connect
<root> <priority value="INFO" /> <appender-ref ref="CONSOLE"/> <appender-ref ref="FILE"/> </root>
<context-param> <description>Spring config file locations</description> <param-name>contextConfigLocation</param-name> <param-value> classpath:alfresco/web-client-application-context.xml classpath:alfresco/jcr-context.xml </param-value> </context-param> <listener> <listener-class>org.springframework.web.context.ContextLoaderListener</listener-class> </listener> <listener> <listener-class>org.alfresco.web.app.ContextListener</listener-class> </listener>
<?xml version='1.0' encoding='UTF-8'?> <!DOCTYPE beans PUBLIC '-//SPRING//DTD BEAN//EN' 'http://www.springframework.org/dtd/spring-beans.dtd'> <beans> <bean id="repository-properties" class="org.springframework.beans.factory.config.PropertyPlaceholderConfigurer"> <property name="ignoreUnresolvablePlaceholders"> <value>true</value> </property> <property name="locations"> <list> <value>classpath:alfresco/repository.properties</value> <value>classpath:alfresco/version.properties</value> <value>classpath:alfresco/domain/transaction.properties</value> <!– override default core properties –> <value>classpath:alfresco/extension/custom.properties</value> </list> </property> </bean> <bean id="hibernateConfigProperties" class="org.springframework.beans.factory.config.PropertiesFactoryBean"> <property name="locations"> <list> <value>classpath:alfresco/domain/hibernate-cfg.properties</value> <!– override default hibernate properties –> <value>classpath:alfresco/extension/custom.properties</value> </list> </property> </bean> <bean id="extension.dictionaryBootstrap" parent="dictionaryModelBootstrap" depends-on="dictionaryBootstrap"> <property name="models"> <list> <value>alfresco/extension/customModel.xml</value> </list> </property> </bean> </beans>
# Folder where Alfresco stores lucene indexes and some store metadata dir.root=C:/Alfresco_datastore #DB settings db.driver=com.mysql.jdbc.Driver db.name=alfresco db.url=jdbc:mysql://localhost:3306/${db.name} db.username=alfresco db.password=alfresco # hibernate settings hibernate.dialect=org.hibernate.dialect.MySQLDialect hibernate.show_sql=false
<?xml version="1.0" encoding="UTF-8"?> <!– Custom Model –> <!– Note: This model is pre-configured to load at startup of the Repository. So, all custom –> <!– types and aspects added here will automatically be registered –> <model name="cust:customModel" xmlns="http://www.alfresco.org/model/dictionary/1.0"> <!– Optional meta-data about the model –> <description>Custom Model</description> <author></author> <version>1.0</version> <imports> <!– Import Alfresco Dictionary Definitions –> <import uri="http://www.alfresco.org/model/dictionary/1.0" prefix="d"/> <!– Import Alfresco Content Domain Model Definitions –> <import uri="http://www.alfresco.org/model/content/1.0" prefix="cm"/> </imports> <!– Introduction of new namespaces defined by this model –> <!– NOTE: The following namespace custom.model should be changed to reflect your own namespace –> <namespaces> <namespace uri="custom.model" prefix="cust"/> </namespaces> </model>
public class AlfrescoUtils { private static ServletContext context=null; private static WebApplicationContext webAppCtx = null; public static ServiceRegistry getServiceRegistry() { assert (getServletContext()!=null) : "The ServletContext is not available in Utils. Please set this during Application startup."; return (ServiceRegistry) webAppCtx.getBean(ServiceRegistry.SERVICE_REGISTRY); } public static Repository getJCRRepository() { assert (getServletContext()!=null) : "The ServletContext is not available in Utils. Please set this during Application startup."; return (Repository) webAppCtx.getBean(RepositoryFactory.REPOSITORY_BEAN); } /** * @return Returns the context. */ public static ServletContext getServletContext() { return context; } /** * @param context The context to set. */ public static void setServletContext(ServletContext context) { AlfrescoUtils.context = context; webAppCtx = WebApplicationContextUtils.getRequiredWebApplicationContext(context); } public static Object getAlfrescoBean(String beanName) { assert (getServletContext()!=null) : "The ServletContext is not available in Utils. Please set this during Application startup."; return webAppCtx.getBean(beanName); } }
