I am using Nuxeo 7.10 with Drive Package 1.5.4 and Drive client 2.1.106. When I synchronize folders, I am no more able to edit with Drive Edit (.docx document). I can only edit the files in the synchronized folders. The synchcronization works well.
To reproduce the problem, I suspend the synchronization and add a new document through the web browser.
I can Drive edit without problem.
I then reactivate the synchronization.
At the first attempt to Drive Edit, the document opens. But when I want to save, the "save as" dialog box appears because the file is read only in \AppData\Roaming\SPB_Data.nuxeo-drive\edit....
I cancel the operation and quit without saving.
For each other attempts to Drive Edit, nothing happens.
Logs are attached.
Is that a problem of configuration on my side?
Thanks !
