We're using Nuxeo platform 7.4.
In context we're trying to push metadata comming from Ephesoft in Nuxeo using CMIS.
In CMIS I have this confifuration:
Cmis Root Folder Name:* default-domain/workspaces/Projets/Remboursement
Cmis Upload File Extension:* pdf
Cmis Server URL:* http://localhost:8090/nuxeo/atom/cmis
Cmis Server User Name:* Administrator
Cmis Server User Password:* ••••••••••••••••••••••••••••••••••••••••••••
Cmis Server Repository Id: default
Cmis Server Switch ON/OFF:* ON
Aspect Switch:* OFF
That is the trace of server.log of the Nuxeo platform:
ERROR [http-bio-127.0.0.1-8090-exec-31] [org.nuxeo.ecm.core.opencmis.bindings.DefaultErrorExtractor] Illegal path with empty component: /default-domain/workspaces/Projets/xxxReturn//BI42_DOC1.pdf
org.apache.chemistry.opencmis.commons.exceptions.CmisRuntimeException: Illegal path with empty component...
In the trace Nuxeo add "//" in the root path.
We're try to install this one https://github.com/nuxeo/nuxeo-platform-document-routing, when using command sudo mvn clean install, Nuxeo.API and Nuxeo.Parent passed the compilation; but Nuxeo.Core raise an error (cause by dependancies).
Thanks for your help.
