I am having a problem with Nuxeo workflow design and implementation in Nuxeo Studio. I am following the Simple workflow example and I have the workflow created (with no errors), however, when I import a document in Nuxeo, my workflow doesn't show up. I see it in the Admin Center Tab under workflows, so I'm not sure what is going on. Thank you.
You need to configure the ability of your workflow on this the availability tab. Did you do it ? http://doc.nuxeo.com/display/Studio/Availability+tab
Thank you. I finally figured that out. It works now.
