I have the following Automation Chain:
I want to cancel this workflow, but I've got the following error:
Not allowed to follow transition from state ... Caused by: org.nuxeo.ecm.core.api.ClientException: Unable to follow transition for document : aad41be2-cca4-4e02-9342-becce2c22333 ___ at org.nuxeo.ecm.core.api.AbstractSession.followTransition(AbstractSession.java:2774)___ ___ at org.nuxeo.ecm.core.api.impl.DocumentModelImpl$7.run(DocumentModelImpl.java:1023)___ ___ at org.nuxeo.ecm.core.api.impl.DocumentModelImpl$7.run(DocumentModelImpl.java:1020)___ ___ at org.nuxeo.ecm.core.api.impl.DocumentModelImpl$RunWithCoreSession.execute(DocumentModelImpl.java:427)___ ___ at org.nuxeo.ecm.core.api.impl.DocumentModelImpl.followTransition(DocumentModelImpl.java:1020)___ ___ at org.nuxeo.ecm.platform.routing.core.impl.GraphNodeImpl.setState(GraphNodeImpl.java:173)___ ___ ... 160 more___ Caused by: org.nuxeo.ecm.core.lifecycle.LifeCycleException: Not allowed to follow transition from state ___ at org.nuxeo.ecm.core.lifecycle.impl.LifeCycleServiceImpl.followTransition(LifeCycleServiceImpl.java:138)___ ___ at org.nuxeo.ecm.core.storage.sql.coremodel.SQLDocumentLive.followTransition(SQLDocumentLive.java:326)___ ___ at org.nuxeo.ecm.core.api.AbstractSession.followTransition(AbstractSession.java:2745)___ ___ ... 165 more___ securityError : false org.jboss.seam.faces.validation : org.jboss.seam.faces.Validation@5b9649f1 org.jboss.seam.transaction.synchronizations : org.jboss.seam.transaction.SeSynchronizations@67d09c30 org.jboss.seam.web.requestContextPath : /nuxeo btn_action : done org.nuxeo.ecm.platform.ui.web.binding.alias.AliasVariableMapper_MARKER : {} nuxeo.disable.redirect.wrapper : true org.jboss.seam.core.conversationPropagation : org.jboss.seam.core.ConversationPropagation@30be488f userManager : org.nuxeo.ecm.platform.computedgroups.UserManagerWithComputedGroups@5b91d2b3 org.ajax4jsf.application.AjaxStateManager.AJAX_VIEW_SEQUENCE : j_id7 currentServerLocation : org.nuxeo.ecm.platform.util.RepositoryLocation@5c13d641 user_message : ocorreu um erro inesperado currentDocument : DocumentModelImpl(3acc11a2-34db-45bd-a146-b5447d79a90c, path=/default-domain/media-container/Deletar, title=Deletar) NuxeoExceptionHandlerMarker : true org.jboss.seam.transaction.transaction : org.jboss.seam.transaction.Transaction@1c8dbd49 lockActions : org.nuxeo.ecm.webapp.edit.lock.LockActionsBean@1d861244 exception_message : Not allowed to follow transition from state org.jboss.seam.web.servletContexts : org.jboss.seam.web.ServletContexts@4d193d80 org.jboss.seam.web.requestServletPath : /view_documents.faces org.jboss.seam.core.events : org.jboss.seam.core.Events@3414c60b
Hello Sergio,
Yes, this Automation Chain was called by a workflow node (the first node).
