I have a problem with my automation chain I defined in Nuxeo Studio.
The automation chain is bound to an event handler which react on the "Document Created" event.
The automation chain should do the following:
If a document is created with a specific parent document, some property of the parent document should be added to the newly created document. But the property is a multi-valued string property.
I created the automation chain as described in one of the tutorials:
- Fetch > Context Document(s)
- Push & Pop > Push document
- Document > Get Parent
- Execution Context > Set Context Variable
- Push & Pop > Pop Document
- Document > Update Property
In "Set Context Variable" I retrieve the value of the property from the parent (expr:@{Document["schema:myProperty"]}) and store it in a context variable. In "Update Property" I set the value for the same property on the created document ().
This seems to work fine for single valued properties, but after I made the property multi-valued, I got exceptions when creating the new child document:
javax.el.ELException: org.nuxeo.ecm.core.api.ClientException: Failed to get document /default-domain/myWorkspace/ParentDocument/ChildDocument
Should this work the same way for multi-valued properties, or is there any other way to achieve this?
Dirk
