Dears
i am calling work flow from my app as api so how can i pass variable for Context["var"] or WorkflowVariables["rec"] for more details see my example below
http://localhost:8080/nuxeo/api/v1/id/de229144-4c2a-48c8-ab8c-7d5581c41f54/@workflow -request body { "workflowModelName":"DocsFlow" ,"entity-type":"workflow" }
response { "entity-type": "exception", "status": 500, "message": "Can not evaluate task assignees from Context["recieved"]" }
You have to use the automation operations with
You can have details on the parameters in https://explorer.nuxeo.com/nuxeo/site/distribution/Nuxeo%20Platform%20LTS%202019-10.10/listOperations
