The latest trunk; At revision 131451, is failing to build due to a missing dependency; org/alfrescolabs/alfresco-technical-validation/org.alfrescolabs.alfresco-technical-validation/0.6.0/
I can only see version 0.4.0 in the alfresco maven repo.
Compiled from sources (GitHub - AlfrescoLabs/technical-validation: Tool for the technical validation of custom code that extends or integrates … ) and deployed to my local repo
