I've just upgraded from 4.2.f to 5.0.d and am having problems with a very simple python script used to upload a file via CMISI've tried changing the service url from /alfresco/cmisatom to /alfresco/api/-default-/public/cmis/versions/1.0/atom but if anything that makes it more unhappy (firstly crashes because of an empty repository name, then if I hard code the name to '-default-' crashes again see below)The access log on the server seems to indicate a 401 for the POST (For GET there seems to be a 401 followed by a 200)With alfresco/cmisatom the script doesn't fail but it doesn't upload the file either Using cmislib==0.5.1The CMIS workbench uploads a file OK. (no 401)Has anybody got any thoughts on this?Thanks
File "/home/iwright/test/cmis/local/lib/python2.7/site-packages/cmislib/model.py", line 2758, in createDocument
contentEncoding)
File "/home/iwright/test/cmis/local/lib/python2.7/site-packages/cmislib/model.py", line 1187, in createDocument
result = self._cmisClient.post(postUrl.encode('utf-8'), xmlDoc.toxml(encoding='utf-8'), ATOM_XML_ENTRY_TYPE)
File "/home/iwright/test/cmis/local/lib/python2.7/site-packages/cmislib/model.py", line 260, in post
**kwargs)
File "/home/iwright/test/cmis/local/lib/python2.7/site-packages/cmislib/net.py", line 286, in post
return opener.open(request)
File "/usr/lib/python2.7/urllib2.py", line 404, in open
response = self._open(req, data)
File "/usr/lib/python2.7/urllib2.py", line 422, in _open
'_open', req)
File "/usr/lib/python2.7/urllib2.py", line 382, in _call_chain
result = func(*args)
File "/usr/lib/python2.7/urllib2.py", line 1214, in http_open
return self.do_open(httplib.HTTPConnection, req)
File "/usr/lib/python2.7/urllib2.py", line 1184, in do_open
raise URLError(err)
urllib2.URLError: <urlopen error [Errno 104] Connection reset by peer>
