i just install AAAR today but AAAR_Extract.sh doesn't work :
david@david-ThinkPad-X230-Tablet:/opt/pentaho/biserver-ce/pentaho-solutions/system/AAAR/endpoints/kettle/script$ ./AAAR_Extract.sh
A.A.A.R. - Alfresco Audit Analysis and Reporting
Import procedure version 2.0.
Author: Francesco Corti (all rights reserved)
Date: 01 January, 2014
Disclaimer:
We can't be responsible for any damage done to your system,
which hopefully will not happen.
Tip:
Want to reduce the time of execution?
Edit this script and change 'JOB_NAME' and 'GET_PARENTS' variables.
If you don't know how, look at the FAQ at http://fcorti.com.
You are going to execute this command:
./kitchen.sh /rep:"AAAR_Kettle" /job:"Get all" /dir:/Alfresco /user:admin /pass:admin /param:get_parents=false /log="/opt/pentaho/biserver-ce/pentaho-solutions/system/AAAR/endpoints/kettle/script/../logs/AAAR.log" /level:Basic
Press <enter> to start import.
/opt/pentaho/data-integration
2014/10/18 20:01:35 - Kitchen - Niveau de trace : Niveau de base
2014/10/18 20:01:35 - Kitchen - Démarrage.
ERREUR: Impossible de charger la tâche car aucun référentiel n'a été renseigné.
ERREUR: Impossible de poursuivre l'opération car la tâche ne peut être chargée.
Extraction complete!
Log file has been generated in the file below:
Check for ERRORS in the log.
If you can't find them, everything has gone alright.
Please, remember to schedule the command periodically or to execute it manually.
Tip:
You can schedule this command using the silent execution with the command below:
/opt/pentaho/biserver-ce/pentaho-solutions/system/AAAR/endpoints/kettle/script/./AAAR_Extract.sh silent
Want to save the reports in pdf format directly in Alfresco?
It's time to execute the 'AAAR_Publish' script.
Enjoy A.A.A.R.!
I try to resolve it but can't find a solution : I launch spoon, add repository/database, verify repositories.xml and now i have got this message : Unable to find Get all job
david@david-ThinkPad-X230-Tablet:/opt/pentaho/data-integration$ ./kitchen.sh /rep:"AAAR_Kettle" /job:"Get all" /dir:/Alfresco /user:admin /pass:admin /param:get_parents=true /level:Basic
2014/10/18 22:22:00 - Kitchen - Niveau de trace : Niveau de base
2014/10/18 22:22:00 - Kitchen - Démarrage.
2014/10/18 22:22:00 - RepositoriesMeta - Lecture du fichier XML : /home/david/.kettle/repositories.xml
Le traitement a été arrêté suite à une erreur :
PDI a rencontré une erreur durant la lecture de la tâche [Get all] depuis le référentiel
Impossible de trouver la tâche : Get all
Alfresco enterprise 4.2.0PostgreSQLbiserver-ce-5.2.0.0-209pdi-ce-5.2.0.0-209Ubuntu 14.04ThanksDavid
