Jan 08, 2014 12:25:06 PM org.apache.catalina.core.AprLifecycleListener init INFO: Loaded APR based Apache Tomcat Native library 1.1.27 using APR version 1.4.6. Jan 08, 2014 12:25:06 PM org.apache.catalina.core.AprLifecycleListener init INFO: APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true]. Jan 08, 2014 12:25:06 PM org.apache.catalina.core.AprLifecycleListener initializeSSL INFO: OpenSSL successfully initialized (OpenSSL 0.9.8o 01 Jun 2010) Jan 08, 2014 12:25:06 PM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["http-apr-8080"] Jan 08, 2014 12:25:06 PM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["ajp-apr-8009"] Jan 08, 2014 12:25:06 PM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["http-bio-8443"] Jan 08, 2014 12:25:07 PM org.apache.catalina.startup.Catalina load INFO: Initialization processed in 1083 ms Jan 08, 2014 12:25:07 PM org.apache.catalina.core.StandardService startInternal INFO: Starting service Catalina Jan 08, 2014 12:25:07 PM org.apache.catalina.core.StandardEngine startInternal INFO: Starting Servlet Engine: Apache Tomcat/7.0.42 Jan 08, 2014 12:25:07 PM org.apache.catalina.startup.HostConfig deployDescriptor INFO: Deploying configuration descriptor /opt/alfresco-4.2.e/tomcat/conf/Catalina/localhost/solr.xml Jan 08, 2014 12:25:07 PM org.apache.catalina.startup.SetContextPropertiesRule begin WARNING: [SetContextPropertiesRule]{Context} Setting property 'debug' to '0' did not find a matching property. 2014-01-08 12:25:13,664 WARN [handler.component.SpellCheckComponent] [localhost-startStop-1] No queryConverter defined, using default converter 2014-01-08 12:25:15,286 WARN [handler.component.SpellCheckComponent] [localhost-startStop-1] No queryConverter defined, using default converter Jan 08, 2014 12:25:15 PM org.apache.catalina.startup.HostConfig deployWAR INFO: Deploying web application archive /opt/alfresco-4.2.e/tomcat/webapps/share.war 2014-01-08 12:25:24,426 INFO [extensions.webscripts.TemplateProcessorRegistry] [localhost-startStop-1] Registered template processor freemarker for extension ftl 2014-01-08 12:25:24,504 INFO [extensions.webscripts.ScriptProcessorRegistry] [localhost-startStop-1] Registered script processor javascript for extension js 2014-01-08 12:25:24,505 INFO [extensions.webscripts.TemplateProcessorRegistry] [localhost-startStop-1] Registered template processor freemarker for extension ftl 2014-01-08 12:25:24,509 INFO [extensions.webscripts.ScriptProcessorRegistry] [localhost-startStop-1] Registered script processor javascript for extension js 2014-01-08 12:25:28,161 INFO [extensions.webscripts.DeclarativeRegistry] [localhost-startStop-1] Registered 356 Web Scripts (+0 failed), 371 URLs 2014-01-08 12:25:28,162 INFO [extensions.webscripts.DeclarativeRegistry] [localhost-startStop-1] Registered 8 Package Description Documents (+0 failed) 2014-01-08 12:25:28,162 INFO [extensions.webscripts.DeclarativeRegistry] [localhost-startStop-1] Registered 0 Schema Description Documents (+0 failed) 2014-01-08 12:25:28,411 INFO [extensions.webscripts.AbstractRuntimeContainer] [localhost-startStop-1] Initialised Spring Surf Container Web Script Container (in 3890.1978ms) 2014-01-08 12:25:28,419 INFO [extensions.webscripts.TemplateProcessorRegistry] [localhost-startStop-1] Registered template processor freemarker for extension ftl 2014-01-08 12:25:28,423 INFO [extensions.webscripts.ScriptProcessorRegistry] [localhost-startStop-1] Registered script processor javascript for extension js 2014-01-08 12:25:28,641 INFO [site.servlet.SSOAuthenticationFilter] [localhost-startStop-1] SSOAuthenticationFilter initialised. Jan 08, 2014 12:25:28 PM org.apache.catalina.startup.HostConfig deployWAR INFO: Deploying web application archive /opt/alfresco-4.2.e/tomcat/webapps/alfresco.war Jan 08, 2014 12:25:28 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory /opt/alfresco-4.2.e/tomcat/webapps/ROOT Jan 08, 2014 12:25:28 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory /opt/alfresco-4.2.e/tomcat/webapps/host-manager Jan 08, 2014 12:25:28 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory /opt/alfresco-4.2.e/tomcat/webapps/manager Jan 08, 2014 12:25:28 PM org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["http-apr-8080"] Jan 08, 2014 12:25:28 PM org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["ajp-apr-8009"] Jan 08, 2014 12:25:28 PM org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["http-bio-8443"] Jan 08, 2014 12:25:28 PM org.apache.catalina.startup.Catalina start INFO: Server startup in 21800 ms 2014-01-08 12:25:30,403 ERROR [solr.tracker.CoreTracker] [SolrTrackerScheduler_Worker-2] Tracking failed org.alfresco.error.AlfrescoRuntimeException: 00080000 GetModelsDiff return status is 404 at org.alfresco.solr.client.SOLRAPIClient.getModelsDiff(SOLRAPIClient.java:1059) at org.alfresco.solr.tracker.CoreTracker.trackModels(CoreTracker.java:1897) at org.alfresco.solr.tracker.CoreTracker.trackRepository(CoreTracker.java:1227) at org.alfresco.solr.tracker.CoreTracker.updateIndex(CoreTracker.java:513) at org.alfresco.solr.tracker.CoreTrackerJob.execute(CoreTrackerJob.java:45) at org.quartz.core.JobRunShell.run(JobRunShell.java:216) at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:563) 2014-01-08 12:25:30,403 ERROR [solr.tracker.CoreTracker] [SolrTrackerScheduler_Worker-3] Tracking failed org.alfresco.error.AlfrescoRuntimeException: 00080001 GetModelsDiff return status is 404 at org.alfresco.solr.client.SOLRAPIClient.getModelsDiff(SOLRAPIClient.java:1059) at org.alfresco.solr.tracker.CoreTracker.trackModels(CoreTracker.java:1897) at org.alfresco.solr.tracker.CoreTracker.trackRepository(CoreTracker.java:1227) at org.alfresco.solr.tracker.CoreTracker.updateIndex(CoreTracker.java:513) at org.alfresco.solr.tracker.CoreTrackerJob.execute(CoreTrackerJob.java:45) at org.quartz.core.JobRunShell.run(JobRunShell.java:216)
