<config evaluator="model-type" condition="cm:content"> <forms> <form id="search"> <field-visibility> <show id="cm:name" /> <show id="cm:title" force="true" /> <show id="cm:description" force="true" /> <show id="mimetype" /> <show id="cm:modified" /> <show id="cm:modifier" /> <!– New fields: the search works well for these –> <show id="cm:created" /> <show id="cm:creator" /> <!– New fields: the search does not work at all –> <show id="cm:categories" force="true" /> <show id="cm:locale" force="true" /> <show id="model:folderType" force="true" /> <show id="model:folderEtat" force="true" /> </field-visibility> <appearance> <field id="mimetype"> <control template="/org/alfresco/components/form/controls/mimetype.ftl" /> </field> <field id="cm:modifier"> <control> <control-param name="forceEditable">true</control-param> </control> </field> <field id="cm:modified"> <control template="/org/alfresco/components/form/controls/daterange.ftl" /> </field> <field id="cm:created"> <control template="/org/alfresco/components/form/controls/daterange.ftl" /> </field> <field id="cm:creator"> <control> <control-param name="forceEditable">true</control-param> </control> </field> <field id="cm:categories"> <control> <control-param name="compactMode">true</control-param> <control-param name="showSubCategoriesOption">true</control-param> </control> </field> <field id="cm:locale"> <!– custom template: work well –> <control template="/org/alfresco/components/form/controls/space.ftl" > </control> </field> <field id="model:folderType"> <control template="/org/alfresco/components/form/controls/number.ftl"> </control> </field> <field id="model:folderEtat"> <control template="/org/alfresco/components/form/controls/number.ftl" > </control> </field> </appearance> </form> </forms> </config>
