Hi I am trying to install Alfresco Buisness reporting add one, I have downloaded "alfresco-business-reporting-0.6.5.jar " and copied it on "/opt/alfresco/tomcat/webapps/alfresco/WEB-INF/lib/" did the necessary changes in alfresco-global.properties
reporting.db.name=alfrescoreporting
reporting.db.username=root
reporting.db.password=mypassword
reporting.db.host=localhost
reporting.db.port=3306
reporting.db.driver=org.gjt.mm.mysql.Driver
reporting.cron.filldatabase=0 0/5 * * * ?
reporting.cron.generatereports=0 0/30 * * * ?
reporting.enabled=true
#reporting.db.url=jdbc:mysql://${reporting.db.host}:${reporting.db.port}/${reporting.db.name}
reporting.db.url=jdbc:mysql://localhost/alfrescoreporting
I have mysql library jar files in the lib directory refered advanced installation steps at"https://code.google.com/p/alfresco-business-reporting/wiki/AdvancedInstallation" and followed the steps, did necessary changesRestarted the service and I am not getting any tables created in 'alfrescoreporting' and I am getting the following error message in the log files
3-04-14 15:35:00,074 ERROR [quartz.core.JobRunShell] [DefaultScheduler_Worker-1] Job DEFAULT.scheduledFillReportingDatabaseJob threw an unhandled Exception:
org.alfresco.scripts.ScriptException: 03140011 Failed to execute script 'alfresco/extension/scripts/fillReportingDatabase.js': 03140010 Unable to load included script repository resource: /Company Home/Data Dictionary/Scripts/reporting/alfresco-business-reporting.lib.js
at org.alfresco.repo.jscript.RhinoScriptProcessor.execute(RhinoScriptProcessor.java:202)
at org.alfresco.repo.processor.ScriptServiceImpl.execute(ScriptServiceImpl.java:212)
at org.alfresco.repo.processor.ScriptServiceImpl.executeScript(ScriptServiceImpl.java:164)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:309)
at org.alfresco.repo.security.permissions.impl.AlwaysProceedMethodInterceptor.invoke(AlwaysProceedMethodInterceptor.java:34)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:110)
at $Proxy144.executeScript(Unknown Source)
at org.alfresco.repo.jscript.ExecuteScriptJob.execute(ExecuteScriptJob.java:80)
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03140010 Unable to load included script repository resource: /Company Home/Data Dictionary/Scripts/reporting/alfresco-business-reporting.lib.js
at org.alfresco.repo.jscript.RhinoScriptProcessor.loadScriptResource(RhinoScriptProcessor.java:389)
at org.alfresco.scripts.ScriptResourceHelper.recurseScriptImports(ScriptResourceHelper.java:144)
at org.alfresco.scripts.ScriptResourceHelper.resolveScriptImports(ScriptResourceHelper.java:60)
at org.alfresco.repo.jscript.RhinoScriptProcessor.resolveScriptImports(RhinoScriptProcessor.java:305)
at org.alfresco.repo.jscript.RhinoScriptProcessor.execute(RhinoScriptProcessor.java:167)
… 22 more
2013-04-14 15:35:00,095 ERROR [quartz.core.ErrorLogger] [DefaultScheduler_Worker-1] Job (DEFAULT.scheduledFillReportingDatabaseJob threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.scripts.ScriptException: 03140011 Failed to execute script 'alfresco/extension/scripts/fillReportingDatabase.js': 03140010 Unable to load included script repository resource: /Company Home/Data Dictionary/Scripts/reporting/alfresco-business-reporting.lib.js]
at org.quartz.core.JobRunShell.run(JobRunShell.java:227)
Caused by: org.alfresco.scripts.ScriptException: 03140011 Failed to execute script 'alfresco/extension/scripts/fillReportingDatabase.js': 03140010 Unable to load included script repository resource: /Company Home/Data Dictionary/Scripts/reporting/alfresco-business-reporting.lib.js
… 1 more
… 22 more
Please guide me Advice requestedthanks
