Hi,I have a production server alfresco 5.0.c. Yesterday the disk space was saturated, which caused an authentication problem, after release of disk space and server restart the authentication problem is solved. But I had another problem: several site don't opens more. and I was in alfresco.log this error when I try to open a site:
09:27:57,188 ERROR [freemarker.runtime] [http-apr-8080-exec-63] Error executing FreeMarker template
FreeMarker template error:
Method public org.alfresco.repo.jscript.ScriptableHashMap org.alfresco.repo.site.script.Site.listMembers(java.lang.String,java.lang.String,int,boolean) threw an exception when invoked on org.alfresco.repo.site.script.Site object "org.alfresco.repo.site.script.Site@3cbedd58" with arguments of types [java.lang.String,java.lang.String,java.lang.Integer,java.lang.Boolean,]. See cause exception.
The failing instruction (FTL stack trace):
==> #assign managers = site.listMembers("… [in template "org/alfresco/repository/site/site.lib.ftl" in macro "siteJSONManagers" at line 48, column 17]
#elseif roles = "managers" [in template "org/alfresco/repository/site/site.lib.ftl" in macro "siteJSONManagers" at line 45, column 9]
@siteJSONManagers site=site roles="ma… [in template "org/alfresco/repository/site/site.lib.ftl" in macro "siteJSON" at line 2, column 1]
@siteLib.siteJSON site=site [in template "org/alfresco/repository/site/site.get.json.ftl" at line 2, column 1]
Java stack trace (for programmers):
freemarker.template.TemplateModelException: [… Exception message was already printed; see it above …]
at freemarker.ext.beans.OverloadedMethodsModel.exec(OverloadedMethodsModel.java:133)
at freemarker.core.MethodCall._eval(MethodCall.java:98)
at freemarker.core.Expression.eval(Expression.java:111)
at freemarker.core.HashBuiltins$HashExBuiltin._eval(HashBuiltins.java:21)
at freemarker.core.Assignment.accept(Assignment.java:106)
at freemarker.core.Environment.visit(Environment.java:265)
at freemarker.core.MixedContent.accept(MixedContent.java:93)
at freemarker.core.IfBlock.accept(IfBlock.java:84)
at freemarker.core.EscapeBlock.accept(EscapeBlock.java:85)
at freemarker.core.Macro$Context.runMacro(Macro.java:209)
at freemarker.core.Environment.visit(Environment.java:694)
at freemarker.core.UnifiedCall.accept(UnifiedCall.java:116)
at freemarker.core.Environment.process(Environment.java:243)
at org.alfresco.repo.template.FreeMarkerProcessor.process(FreeMarkerProcessor.java:217)
at org.springframework.extensions.webscripts.AbstractWebScript.renderTemplate(AbstractWebScript.java:955)
at org.springframework.extensions.webscripts.DeclarativeWebScript.renderFormatTemplate(DeclarativeWebScript.java:267)
at org.springframework.extensions.webscripts.DeclarativeWebScript.execute(DeclarativeWebScript.java:147)
at org.alfresco.repo.web.scripts.RepositoryContainer$3.execute(RepositoryContainer.java:463)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:454)
at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecute(RepositoryContainer.java:532)
at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecuteAs(RepositoryContainer.java:600)
at org.alfresco.repo.web.scripts.RepositoryContainer.executeScriptInternal(RepositoryContainer.java:380)
at org.alfresco.repo.web.scripts.RepositoryContainer.executeScript(RepositoryContainer.java:261)
at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:378)
at org.springframework.extensions.webscripts.servlet.WebScriptServlet.service(WebScriptServlet.java:132)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2441)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2430)
Caused by: org.alfresco.repo.security.authority.UnknownAuthorityException: 06240706 An authority was not found for GROUP_site_sifast-tn_SiteManager
at org.alfresco.repo.security.authority.AuthorityDAOImpl.getContainedAuthorities(AuthorityDAOImpl.java:765)
at org.alfresco.repo.security.authority.AuthorityServiceImpl.getContainedAuthorities(AuthorityServiceImpl.java:549)
at org.alfresco.repo.site.SiteServiceImpl.listMembersInfoImpl(SiteServiceImpl.java:2013)
at org.alfresco.repo.site.SiteServiceImpl.listMembersImpl(SiteServiceImpl.java:1961)
at org.alfresco.repo.site.SiteServiceImpl.listMembers(SiteServiceImpl.java:1924)
at sun.reflect.GeneratedMethodAccessor818.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317)
at org.alfresco.repo.transaction.CheckTransactionAdvice.invoke(CheckTransactionAdvice.java:47)
at org.alfresco.repo.transaction.RetryingTransactionAdvice$1.execute(RetryingTransactionAdvice.java:64)
at org.alfresco.repo.transaction.RetryingTransactionAdvice.invoke(RetryingTransactionAdvice.java:67)
at com.sun.proxy.$Proxy96.listMembers(Unknown Source)
at org.alfresco.repo.site.script.Site.listMembers(Site.java:407)
at freemarker.ext.beans.BeansWrapper.invokeMethod(BeansWrapper.java:912)
at freemarker.ext.beans.OverloadedMethodsModel.exec(OverloadedMethodsModel.java:103)
… 64 more
ServletException root cause:
09:27:57,191 ERROR [org.springframework.extensions.webscripts.AbstractRuntime] [http-apr-8080-exec-63] Exception from executeScript - redirecting to status template error: 06240229 Wrapped Exception (with status template): 06240707 Erreur lors du traitement du mod?le 'Method public org.alfresco.repo.jscript.ScriptableHashMap org.alfresco.repo.site.script.Site.listMembers(java.lang.String,java.lang.String,int,boolean) threw an exception when invoked on org.alfresco.repo.site.script.Site object "org.alfresco.repo.site.script.Site@3cbedd58" with arguments of types [java.lang.String,java.lang.String,java.lang.Integer,java.lang.Boolean,]. See cause exception.
The failing instruction (print stack trace for 3 more):
==> #assign managers = site.listMembers("… [in template "org/alfresco/repository/site/site.lib.ftl" in macro "siteJSONManagers" at line 48, column 17]'. Veuillez contacter votre administrateur syst?me.
org.springframework.extensions.webscripts.WebScriptException: 06240229 Wrapped Exception (with status template): 06240707 Erreur lors du traitement du mod?le 'Method public org.alfresco.repo.jscript.ScriptableHashMap org.alfresco.repo.site.script.Site.listMembers(java.lang.String,java.lang.String,int,boolean) threw an exception when invoked on org.alfresco.repo.site.script.Site object "org.alfresco.repo.site.script.Site@3cbedd58" with arguments of types [java.lang.String,java.lang.String,java.lang.Integer,java.lang.Boolean,]. See cause exception.
at org.springframework.extensions.webscripts.AbstractWebScript.createStatusException(AbstractWebScript.java:1126)
Caused by: org.alfresco.service.cmr.repository.TemplateException: 06240707 Erreur lors du traitement du mod?le 'Method public org.alfresco.repo.jscript.ScriptableHashMap org.alfresco.repo.site.script.Site.listMembers(java.lang.String,java.lang.String,int,boolean) threw an exception when invoked on org.alfresco.repo.site.script.Site object "org.alfresco.repo.site.script.Site@3cbedd58" with arguments of types [java.lang.String,java.lang.String,java.lang.Integer,java.lang.Boolean,]. See cause exception.
at org.alfresco.repo.template.FreeMarkerProcessor.process(FreeMarkerProcessor.java:221)
… 33 more
Caused by: freemarker.template.TemplateModelException: Method public org.alfresco.repo.jscript.ScriptableHashMap org.alfresco.repo.site.script.Site.listMembers(java.lang.String,java.lang.String,int,boolean) threw an exception when invoked on org.alfresco.repo.site.script.Site object "org.alfresco.repo.site.script.Site@3cbedd58" with arguments of types [java.lang.String,java.lang.String,java.lang.Integer,java.lang.Boolean,]. See cause exception.
I try with an admin account to access to the menu "Admin Tools">"Site Manager" I have the following error:06230189 Wrapped Exception (with status template): 062306600 An authority was not found for GROUP_site_[site-name]_SiteManager
This is the error I receive in alfresco.log : 17:57:38,238 ERROR [org.springframework.extensions.webscripts.AbstractRuntime] [http-apr-8080-exec-49] Exception from executeScript - redirecting to status template error: 06230192 Wrapped Exception (with status template): 06230603 An authority was not found for GROUP_site_administration-sifast_SiteManager
org.springframework.extensions.webscripts.WebScriptException: 06230192 Wrapped Exception (with status template): 06230603 An authority was not found for GROUP_site_administration-sifast_SiteManager
Caused by: org.alfresco.repo.security.authority.UnknownAuthorityException: 06230603 An authority was not found for GROUP_site_administration-sifast_SiteManager
at org.alfresco.repo.site.SiteServiceImpl.listMembers(SiteServiceImpl.java:1900)
at sun.reflect.GeneratedMethodAccessor1655.invoke(Unknown Source)
at org.alfresco.repo.web.scripts.site.SiteAdminSitesGet.executeImpl(SiteAdminSitesGet.java:116)
at org.springframework.extensions.webscripts.DeclarativeWebScript.execute(DeclarativeWebScript.java:64)
… 33 more
I think it is Due to the to the system crash caused by the saturaion of the disc.I just can not find the cause of the problemHas anyone an idea what is causing this error and how I can solve this?Thanksregards,Youmarva
