HelloI want to ask about how to know the area and the remainder of the stored database alfrescoThe second questionFor rules on folders should run it all over again the sense that you set up base between folders to transfer all of the items when the update .. Do be processed Qaeda one, and must be operated after each update .. or to stay effective and always how it's done ..As well as how you can edit metadata fields for records management.How to connect with the Office alfresco x optical scannerthank you very much
I'm not actually able to answer any of your questions - however, I would recommend that you maybe edit this question so that it has a more meaningful title and also split each question into it's own thread (rather than having multiple different questions in a single thread). This will definitely make it easier for Community members to help you and you're much more likely to get the assistance that you're looking for!
