Hi guys i have a problem with my ldap connection via java, i'm using debian herethis is my reference http://techpubs.spinlocksolutions.com/dklar/ldap.htmli have following this as reference for installing ldap and configuring it, and it work perfectly on terminal, but i cant connect it to java.
package com.irvankosini;
import java.util.Hashtable;
import javax.naming.AuthenticationException;
import javax.naming.AuthenticationNotSupportedException;
import javax.naming.Context;
import javax.naming.NamingException;
import javax.naming.directory.DirContext;
import javax.naming.directory.InitialDirContext;
public class ldap {
public static void main(String[] args) {
String url = "ldap://192.168.1.1:389";
Hashtable env = new Hashtable();
env.put(Context.INITIAL_CONTEXT_FACTORY, "com.sun.jndi.ldap.LdapCtxFactory");
env.put(Context.PROVIDER_URL, url);
env.put(Context.SECURITY_AUTHENTICATION, "simple");
env.put(Context.SECURITY_PRINCIPAL, "uid=mirko,ou=people");
env.put(Context.SECURITY_CREDENTIALS, "kosini");
try {
DirContext ctx = new InitialDirContext(env);
System.out.println("connected");
System.out.println(ctx.getEnvironment());
// do something useful with the context…
ctx.close();
} catch (AuthenticationNotSupportedException ex) {
System.out.println("The authentication is not supported by the server");
} catch (AuthenticationException ex) {
ex.printStackTrace();
} catch (NamingException ex) {
System.out.println("error when trying to create the context");
this is the error logrun:javax.naming.AuthenticationException: [LDAP: error code 49 - Invalid Credentials] at com.sun.jndi.ldap.LdapCtx.mapErrorCode(LdapCtx.java:3135) at com.sun.jndi.ldap.LdapCtx.mapErrorCode(LdapCtx.java:3135) at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:3081) at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2883) at com.sun.jndi.ldap.LdapCtx.connect(LdapCtx.java:2797) at com.sun.jndi.ldap.LdapCtx.<init>(LdapCtx.java:319) at com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(LdapCtxFactory.java:192) at com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(LdapCtxFactory.java:210) at com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(LdapCtxFactory.java:153) at com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(LdapCtxFactory.java:83) at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:684) at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:313) at javax.naming.InitialContext.init(InitialContext.java:244) at javax.naming.InitialContext.<init>(InitialContext.java:216) at javax.naming.directory.InitialDirContext.<init>(InitialDirContext.java:101) at com.irvankosini.ldap.main(ldap.java:25) at com.sun.jndi.ldap.LdapCtx.mapErrorCode(LdapCtx.java:3135)BUILD SUCCESSFUL (total time: 3 seconds)
