Document object = (Document) cmisSession.getObjectByPath(path2Object); if (object != null) { log.info("\tName [" + object.getName() + "]"); log.info("\tDescription [" + object.getDescription() + "]"); List<Property<?>> properties = object.getProperties(); if (properties != null) { for (int index=0; index<properties.size(); index++) { Property aProperty = properties.get(index); log.info("/t P QueryName [" + aProperty.getQueryName() + "]"); log.info("/t P Value [" + aProperty.getValueAsString() + "]"); } } List<SecondaryType> aspects = object.getSecondaryTypes(); if (aspects != null) { for (int index=0; index<aspects.size(); index++) { SecondaryType aspect = aspects.get(index); log.info("/t P QueryName [" + aspect.getQueryName()); log.info("/t P Discription [" + aspect.getDescription()); } } }
String cmisQuery = "SELECT doc.*, salo.* FROM cmis:document AS doc JOIN salo:documentProperties AS salo ON doc.cmis:objectId = salo.cmis:objectId "; String cmisQueryWhereClause = "WHERE"; // add where clause cmisQueryWhereClause += "(salo.salo:lo_id = 1867) AND (salo.salo:lo_category = 'Type1')" ItemIterable<QueryResult> queryResults = cmisSession.query(cmisQuery, false); for (QueryResult queryResult:queryResults) { PropertyData<?> abcProperty = queryResult.getPropertyByOd("abc"); String abcValue = abcProperty.getFirstValue().toString() //… }
