I am new to the workflows and i am trying to do a simple private message workflow. The start task takes a name and a message. The problem is setting the data. When I iterate through the task variables I get this very weird problem:here it the model:
<type name="jiswf:privateMessage">
<parent>bpm:startTask</parent>
<properties>
<property name="jiswf:toName">
<type>d:text</type>
<mandatory>true</mandatory>
<multiple>false</multiple>
</property>
<property name="jiswf:privateMessage">
<type>d:text</type>
</property>
</properties>
</type>
it is launched by a java web script:
WorkflowDefinition wfDefinition = workflowService.getDefinitionByName("activiti$privateMessageProcess");
Map<QName, Serializable> vars = new HashMap<QName, Serializable>();
vars.put(QName.createQName(AlfrescoModel.WORKFLOW_NAMESPACE,"toName"),toName);
vars.put(QName.createQName(AlfrescoModel.WORKFLOW_NAMESPACE,"privateMessage"),message);
workflowService.startWorkflow(wfDefinition.getId(), vars);
and a simple iterator through the variables in the task listener (Java):
Map<String,Object> vars = task.getVariables();
Iterator<String> keys = vars.keySet().iterator();
while(keys.hasNext()) {
String key = keys.next();
System.out.println("Key:"+key+" Value:"+vars.get(key));
The output is the issue:
Key:jiswf_toName Value:joe
Key:jiswf:privateMessage Value:asdfasdf
Why oh why is one key "jiswf_toName" and the other "jiswf
rivateMessage"that difference between "_" and ":" makes it hard to get the variables out of the model as you can imagine. Using v4.2.d comm.Any help is appreciated.
