-Duser.language=en -Duser.country=GB
export JAVA_OPTS="$JAVA_OPTS -Duser.language=en -Duser.country=GB"
09:37:31,316 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'wcm_deployment_receiver' subsystem, ID: [wcm_deployment_receiver, default] complete 09:37:38,174 INFO [extensions.webscripts.DeclarativeRegistry] Registered 313 Web Scripts (+0 failed), 321 URLs 09:37:38,176 INFO [extensions.webscripts.DeclarativeRegistry] Registered 8 Package Description Documents (+0 failed) 09:37:38,176 INFO [extensions.webscripts.DeclarativeRegistry] Registered 0 Schema Description Documents (+0 failed) 09:37:38,330 INFO [extensions.webscripts.AbstractRuntimeContainer] Initialised Spring Surf Container Web Script Container (in 2062.2886ms) 09:37:38,374 INFO [extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl 09:37:38,428 INFO [extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js 09:37:38,695 INFO [extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl 09:37:38,699 INFO [extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js 09:37:38,959 INFO [extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl 09:37:38,962 INFO [extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js WARN : org.springframework.beans.GenericTypeAwarePropertyDescriptor - Invalid JavaBean property 'baseUrl' being accessed! Ambiguous write methods found next to actually used [public void org.alfresco.wcm.client.impl.WebScriptCallerImpl.setBaseUrl(java.net.URI)]: [public void org.alfresco.wcm.client.impl.WebScriptCallerImpl.setBaseUrl(java.lang.String) throws java.net.URISyntaxException]
import java.util.Locale; public class OutputLocale { public static void main(String[] args) { System.out.println(Locale.getDefault()); } }
import java.util.Locale; import javax.servlet.http.HttpServletRequest; import javax.servlet.http.HttpServletResponse; import org.apache.commons.logging.LogFactory; import org.springframework.web.servlet.handler.HandlerInterceptorAdapter; public class LocaleLoggerInterceptor extends HandlerInterceptorAdapter { @Override public boolean preHandle(HttpServletRequest request, HttpServletResponse response, Object handler) throws Exception { LogFactory.getLog(LocaleLoggerInterceptor.class).error("Default locale = " + Locale.getDefault()); return true; } }
javac -classpath .;..\..\..\..\lib\servlet-api.jar;..\lib\org.springframework.webmvc-3.0.0.jar;..\lib\commons-logging-1.1.1.jar LocaleLoggerInterceptor.java
<!– Override list of interceptors defined in webframeworkHandlerMappings so that we can add our own. –> <property name="interceptors"> <list> <ref bean="requestContextInterceptor"/> <!– <ref bean="themeInterceptor"/> <ref bean="previewContextInterceptor"/> –> <!– Interceptors added to apply application-wide processing to requests. See also quickstart-request.xml –> <ref bean="cmisSessionInterceptor"/> <ref bean="applicationDataInterceptor"/> </list> </property>
<!– Override list of interceptors defined in webframeworkHandlerMappings so that we can add our own. –> <property name="interceptors"> <list> <bean class="LocaleLoggerInterceptor" /> <ref bean="requestContextInterceptor"/> <!– <ref bean="themeInterceptor"/> <ref bean="previewContextInterceptor"/> –> <!– Interceptors added to apply application-wide processing to requests. See also quickstart-request.xml –> <ref bean="cmisSessionInterceptor"/> <ref bean="applicationDataInterceptor"/> </list> </property>
08:33:29,898 ERROR [LocaleLoggerInterceptor] Default locale = en_GB
