I am trying to upgrade. I installed a fresh copy of 4.2. It works fine. * Then i dumped the 4.0d db and copied over the contentstore * Set index recovery to FULL. * Copied over mysql connector * Updated model changes changes. When I start 4.2 I get the following errors.
2012-10-16 10:40:48,047 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
2012-10-16 10:40:48,965 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-1901032616294705151.txt
2012-10-16 10:40:49,061 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-144186641307414255.txt
2012-10-16 10:40:49,426 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-6587253562823937764.txt
2012-10-16 10:40:49,601 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-5051847405582929104.txt
2012-10-16 10:40:51,082 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-4441020199277219028.xml.
2012-10-16 10:40:51,082 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-7407757886001663288.xml.
2012-10-16 10:40:51,082 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-169640830830436110.xml.
2012-10-16 10:40:51,082 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-7418666214664859087.xml.
2012-10-16 10:40:56,465 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-973539863669221460.txt
2012-10-16 10:40:56,506 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-8079099217599195880.txt
2012-10-16 10:40:56,638 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-196840763009725396.txt
2012-10-16 10:40:56,859 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-6060820816640886193.txt
2012-10-16 10:40:57,777 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-8353803699483914542.xml.
2012-10-16 10:40:57,777 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-685616141179835752.xml.
2012-10-16 10:40:57,777 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-770184416112829890.xml.
2012-10-16 10:40:57,777 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-6818437909555641512.xml.
2012-10-16 10:41:03,114 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-8892281545133316901.txt
2012-10-16 10:41:03,152 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-3555455046979469323.txt
2012-10-16 10:41:03,274 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-2421028245061831464.txt
2012-10-16 10:41:03,341 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-903538781104959923.txt
2012-10-16 10:41:04,188 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-229547706854174481.xml.
2012-10-16 10:41:04,188 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-2627328977418332551.xml.
2012-10-16 10:41:04,188 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-6305154847947330787.xml.
2012-10-16 10:41:04,188 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-60587866862770285.xml.
2012-10-16 10:41:09,518 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-7719217870124101233.txt
2012-10-16 10:41:09,550 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-8351748748544343562.txt
2012-10-16 10:41:09,657 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-236896132303646877.txt
2012-10-16 10:41:09,722 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-3348501020915325557.txt
2012-10-16 10:41:10,411 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-8179380355386946268.xml.
2012-10-16 10:41:10,412 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-4017511668206467565.xml.
2012-10-16 10:41:10,412 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-4137757804855256810.xml.
2012-10-16 10:41:10,412 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-2290960420337404520.xml.
2012-10-16 10:41:15,748 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-2014875907789881554.txt
2012-10-16 10:41:15,785 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-4751287392608969102.txt
2012-10-16 10:41:15,893 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-548416166739300151.txt
2012-10-16 10:41:15,956 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-8768097277867708853.txt
2012-10-16 10:41:16,801 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-8907968411928576920.xml.
2012-10-16 10:41:16,801 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-5257503617506663897.xml.
2012-10-16 10:41:16,801 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-916157706684663196.xml.
2012-10-16 10:41:16,801 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-4245479163447593190.xml.
2012-10-16 10:41:22,107 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-5432105718735418769.txt
2012-10-16 10:41:22,153 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-9133066700806593196.txt
2012-10-16 10:41:22,257 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-2531269882650078095.txt
2012-10-16 10:41:22,330 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-1223988719340966838.txt
2012-10-16 10:41:23,033 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-523059565076503930.xml.
2012-10-16 10:41:23,033 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-4594748366417771454.xml.
2012-10-16 10:41:23,033 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-7072007569084534043.xml.
2012-10-16 10:41:23,033 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-8016389854003497322.xml.
2012-10-16 10:41:28,330 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-6390324644794552188.txt
2012-10-16 10:41:28,362 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-6212158092518164278.txt
2012-10-16 10:41:28,467 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-6395997103630383305.txt
2012-10-16 10:41:28,530 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-3577134073308696320.txt
2012-10-16 10:41:29,364 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-4825709154927178375.xml.
2012-10-16 10:41:29,364 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-1551507202047302834.xml.
2012-10-16 10:41:29,365 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-8112182290582780771.xml.
2012-10-16 10:41:29,365 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-1419625140210874743.xml.
2012-10-16 10:41:34,647 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-1062533942415034874.txt
2012-10-16 10:41:34,679 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-6901106006407108331.txt
2012-10-16 10:41:34,782 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-5804015005040025602.txt
2012-10-16 10:41:34,842 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-1378327559934495067.txt
2012-10-16 10:41:35,607 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-7241310501624090458.xml.
2012-10-16 10:41:35,607 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-4917507117382375109.xml.
2012-10-16 10:41:35,607 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-5027109839001847666.xml.
2012-10-16 10:41:35,607 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-2879525834296275366.xml.
2012-10-16 10:41:40,914 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-4053896755395668128.txt
2012-10-16 10:41:40,947 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-6656953298997122291.txt
2012-10-16 10:41:41,045 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-1865379591265104705.txt
2012-10-16 10:41:41,107 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-6353429899702807925.txt
2012-10-16 10:41:41,864 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-7650249229927231319.xml.
2012-10-16 10:41:41,864 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-1051473380135801964.xml.
2012-10-16 10:41:41,864 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-3466890018247555035.xml.
2012-10-16 10:41:41,864 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-5532813753585549114.xml.
2012-10-16 10:41:47,150 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-9143460167675009196.txt
2012-10-16 10:41:47,184 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-4482162310145850636.txt
2012-10-16 10:41:47,286 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-4497607146318623659.txt
2012-10-16 10:41:47,342 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-4627416461990670667.txt
2012-10-16 10:41:47,984 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-8913362526707576381.xml.
2012-10-16 10:41:47,984 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-7895888051350672583.xml.
2012-10-16 10:41:47,984 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-7858817266359024887.xml.
2012-10-16 10:41:47,985 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-1875903222607889811.xml.
2012-10-16 10:41:53,267 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-5284559595915747737.txt
2012-10-16 10:41:53,299 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-3677821858694610323.txt
2012-10-16 10:41:53,401 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-2152601783698634693.txt
2012-10-16 10:41:53,462 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-2036283415218280530.txt
2012-10-16 10:41:54,213 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-7314119473617384953.xml.
2012-10-16 10:41:54,213 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-2302633385049615758.xml.
2012-10-16 10:41:54,213 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-3223891925629284590.xml.
2012-10-16 10:41:54,214 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-887933376650222551.xml.
2012-10-16 10:41:59,486 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-6984099792475697216.txt
2012-10-16 10:41:59,516 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-7616127798734835533.txt
2012-10-16 10:41:59,610 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-5560553872868802544.txt
2012-10-16 10:41:59,667 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-3744657318791906006.txt
2012-10-16 10:42:00,332 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-1728586167967653780.xml.
2012-10-16 10:42:00,332 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-3462131148095775806.xml.
2012-10-16 10:42:00,333 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-2727384187793612400.xml.
2012-10-16 10:42:00,333 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-6799101435265752287.xml.
2012-10-16 10:42:05,594 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-2166426941231069404.txt
2012-10-16 10:42:05,625 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-1172541010312314237.txt
2012-10-16 10:42:05,827 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-3137283596132999632.txt
2012-10-16 10:42:05,885 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-6778218571894594492.txt
2012-10-16 10:42:06,544 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-1575962030158331389.xml.
2012-10-16 10:42:06,544 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-2037237686839920717.xml.
2012-10-16 10:42:06,544 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-2214029115068398434.xml.
2012-10-16 10:42:06,544 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-144950833017071946.xml.
2012-10-16 10:42:11,827 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-5951358421120932917.txt
2012-10-16 10:42:11,857 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-3431624522616702089.txt
2012-10-16 10:42:11,952 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-7375993897839795031.txt
2012-10-16 10:42:12,013 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-462867294150674347.txt
2012-10-16 10:42:12,656 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-1857757139230810598.xml.
2012-10-16 10:42:12,656 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-3635191232778576918.xml.
2012-10-16 10:42:12,657 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-816478489441571822.xml.
2012-10-16 10:42:12,657 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-2168319450253074235.xml.
2012-10-16 10:42:18,030 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-1289158618815367521.txt
2012-10-16 10:42:18,062 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-627378620249482895.txt
2012-10-16 10:42:18,163 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-138144714296676286.txt
2012-10-16 10:42:18,223 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-5924404776353226924.txt
2012-10-16 10:42:18,869 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-4524943588154917561.xml.
2012-10-16 10:42:18,870 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-8399039067827634114.xml.
2012-10-16 10:42:18,870 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-7895997160011851980.xml.
2012-10-16 10:42:18,870 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-2310432601022389050.xml.
2012-10-16 10:42:24,138 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-3126620445660252030.txt
2012-10-16 10:42:24,168 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-4514155735033354131.txt
2012-10-16 10:42:24,266 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-4690502477028700815.txt
2012-10-16 10:42:24,322 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-851987716217179472.txt
2012-10-16 10:42:25,079 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-1008773785157931179.xml.
2012-10-16 10:42:25,079 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-701843066051912970.xml.
2012-10-16 10:42:25,079 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-112914368542579265.xml.
2012-10-16 10:42:25,079 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-7905144886690944623.xml.
2012-10-16 10:42:30,358 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-1983345905082315071.txt
2012-10-16 10:42:30,389 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-8686925396303772503.txt
2012-10-16 10:42:30,490 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-2752966318525216087.txt
2012-10-16 10:42:30,549 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-7609922553694266967.txt
2012-10-16 10:42:31,196 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-3287865377349641747.xml.
2012-10-16 10:42:31,197 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-660683501631071057.xml.
2012-10-16 10:42:31,197 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-2857316146786264575.xml.
2012-10-16 10:42:31,197 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-8587730933394531575.xml.
2012-10-16 10:42:36,471 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-6636425762416430107.txt
2012-10-16 10:42:36,503 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-185326783381656322.txt
2012-10-16 10:42:36,600 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-7175282734453289733.txt
2012-10-16 10:42:36,660 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-2685151235236768175.txt
2012-10-16 10:42:37,409 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-7825236989740330710.xml.
2012-10-16 10:42:37,409 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-1884070687997626609.xml.
2012-10-16 10:42:37,410 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-4448610962127872541.xml.
2012-10-16 10:42:37,410 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-2542750236759461977.xml.
2012-10-16 10:42:42,688 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-6782892288256812744.txt
2012-10-16 10:42:42,719 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-8772379124702161132.txt
2012-10-16 10:42:42,820 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-6166058132195159233.txt
2012-10-16 10:42:42,879 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-4714795186358002187.txt
2012-10-16 10:42:43,511 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-6781551550666661367.xml.
2012-10-16 10:42:43,511 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-479000947014408224.xml.
2012-10-16 10:42:43,512 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-465945363266756892.xml.
2012-10-16 10:42:43,512 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-4046681670662724163.xml.
2012-10-16 10:42:48,789 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-6301396022091593253.txt
2012-10-16 10:42:48,821 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-5972262087345957112.txt
2012-10-16 10:42:48,921 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-3911728870693792984.txt
2012-10-16 10:42:49,078 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-3842600611014502275.txt
2012-10-16 10:42:49,697 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-4416322468160009030.xml.
2012-10-16 10:42:49,697 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-2619093084529195236.xml.
2012-10-16 10:42:49,697 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-4320306702958338725.xml.
2012-10-16 10:42:49,698 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-4439714857342625667.xml.
2012-10-16 10:42:54,971 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-7835327487247669980.txt
2012-10-16 10:42:55,002 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-5425552234501811940.txt
2012-10-16 10:42:55,103 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-8482545140452652831.txt
2012-10-16 10:42:55,163 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-6491187120080825100.txt
2012-10-16 10:42:55,815 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-3381976320355263367.xml.
2012-10-16 10:42:55,815 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-7536678798062208653.xml.
2012-10-16 10:42:55,815 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-3512124158227227100.xml.
2012-10-16 10:42:55,815 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-4079737631860599743.xml.
2012-10-16 10:43:01,085 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-912447283641570448.txt
2012-10-16 10:43:01,215 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-2836157252681544528.txt
2012-10-16 10:43:01,312 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-6265568587370609124.txt
2012-10-16 10:43:01,371 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-1325967192744591875.txt
2012-10-16 10:43:01,975 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-5738538951594796646.xml.
2012-10-16 10:43:01,975 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-4273992847476738369.xml.
2012-10-16 10:43:01,975 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-5822960954417892831.xml.
2012-10-16 10:43:01,975 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-2098363262134382724.xml.
2012-10-16 10:43:07,253 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-3832297177388812999.txt
2012-10-16 10:43:07,282 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-1270948862894619462.txt
2012-10-16 10:43:07,382 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-4029591954890663837.txt
2012-10-16 10:43:07,439 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-1400714542533723978.txt
2012-10-16 10:43:08,095 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-3409988545784542881.xml.
2012-10-16 10:43:08,095 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-626742913197903148.xml.
2012-10-16 10:43:08,095 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-2993962093509947071.xml.
2012-10-16 10:43:08,095 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-529292781385313517.xml.
2012-10-16 10:43:13,472 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 15 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-alf_-7522015592399813695.txt
2012-10-16 10:43:13,503 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 5 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-avm_-8780059740359294124.txt
2012-10-16 10:43:13,600 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 1 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-jbpm_-5934986710216584011.txt
2012-10-16 10:43:13,657 WARN [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema validation found 29 potential problems, results written to: /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-act_-5972198135401962840.txt
2012-10-16 10:43:14,272 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-alf_-8095757721325201349.xml.
2012-10-16 10:43:14,272 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-avm_-3136261699740415914.xml.
2012-10-16 10:43:14,272 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-jbpm_-5434314784187412036.xml.
2012-10-16 10:43:14,272 INFO [domain.schema.SchemaBootstrap] [localhost-startStop-1] Normalized schema dumped to file /opt/alfresco-4.2.a/tomcat/temp/Alfresco/Alfresco-schema-MySQLInnoDBDialect-pre-upgrade-act_-8573582817180813801.xml.
2012-10-16 10:43:19,276 ERROR [domain.schema.SchemaBootstrap] [localhost-startStop-1] Schema auto-update failed
org.alfresco.error.AlfrescoRuntimeException: 09160000 A previous schema upgrade failed or was not completed. Revert to the original database before attempting the upgrade again.
at org.alfresco.repo.domain.schema.SchemaBootstrap.onBootstrap(SchemaBootstrap.java:1552)
at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEventInternal(SafeApplicationEventMulticaster.java:209)
at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:180)
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:303)
at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:911)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:428)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:276)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:197)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4791)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5285)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:618)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:963)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1600)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
2012-10-16 10:43:19,280 ERROR [web.context.ContextLoader] [localhost-startStop-1] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: 09160001 Schema auto-update failed
at org.alfresco.repo.domain.schema.SchemaBootstrap.onBootstrap(SchemaBootstrap.java:1679)
Caused by: org.alfresco.error.AlfrescoRuntimeException: 09160000 A previous schema upgrade failed or was not completed. Revert to the original database before attempting the upgrade again.
… 24 more
Oct 16, 2012 10:43:19 AM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextLoaderListener
… 24 more
SEVERE: Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
… 24 more
SEVERE: Exception sending context initialized event to listener instance of class org.alfresco.repo.webdav.WebDAVSessionListener
… 24 more
Oct 16, 2012 10:43:19 AM com.sun.xml.ws.transport.http.servlet.WSServletContextListener contextInitialized
INFO: WSSERVLET12: JAX-WS context listener initializing
Oct 16, 2012 10:43:22 AM com.sun.xml.ws.transport.http.servlet.WSServletDelegate <init>
INFO: WSSERVLET14: JAX-WS servlet initializing
Oct 16, 2012 10:43:22 AM org.apache.catalina.core.StandardContext startInternal
SEVERE: Error listenerStart
Oct 16, 2012 10:43:22 AM com.sun.xml.ws.transport.http.servlet.WSServletDelegate destroy
INFO: WSSERVLET15: JAX-WS servlet destroyed
Oct 16, 2012 10:43:22 AM com.sun.xml.ws.transport.http.servlet.WSServletContextListener contextDestroyed
INFO: WSSERVLET13: JAX-WS context listener destroyed
Oct 16, 2012 10:43:22 AM org.apache.catalina.core.ApplicationContext log
INFO: Closing Spring root WebApplicationContext
INFO: Shutting down log4j
Oct 16, 2012 10:43:22 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads
SEVERE: The web application [/alfresco] appears to have started a thread named [SolrWatcherScheduler_Worker-1] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [SolrWatcherScheduler_Worker-2] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [SolrWatcherScheduler_Worker-3] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [Timer-1] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [DefaultScheduler_Worker-1] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [DefaultScheduler_Worker-2] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [DefaultScheduler_Worker-3] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [DefaultScheduler_Worker-4] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [DefaultScheduler_Worker-5] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [DefaultScheduler_Worker-6] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [DefaultScheduler_Worker-7] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [DefaultScheduler_Worker-8] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [DefaultScheduler_Worker-9] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [DefaultScheduler_Worker-10] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [Thread-5] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [SolrWatcherScheduler_QuartzSchedulerThread] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/alfresco] appears to have started a thread named [DefaultScheduler_QuartzSchedulerThread] but has failed to stop it. This is very likely to create a memory leak.
Oct 16, 2012 10:43:22 AM org.apache.catalina.loader.WebappClassLoader checkThreadLocalMapForLeaks
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@653f275d]) and a value of type [org.apache.cxf.bus.CXFBusImpl] (value [org.apache.cxf.bus.CXFBusImpl@15317e99]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [com.sun.xml.bind.v2.runtime.Coordinator$1] (value [com.sun.xml.bind.v2.runtime.Coordinator$1@646e79ad]) and a value of type [java.lang.Object[]] (value [[Ljava.lang.Object;@10f6805e]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@2765a405]) and a value of type [org.alfresco.util.CachingDateFormat] (value [yyyy-MM-dd]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [com.sun.xml.bind.v2.ClassFactory$1] (value [com.sun.xml.bind.v2.ClassFactory$1@1f35878]) and a value of type [java.util.WeakHashMap] (value [{class org.alfresco.repo.audit.model._3.Audit=java.lang.ref.WeakReference@65f7ec9c, class org.alfresco.repo.audit.model._3.RecordValue=java.lang.ref.WeakReference@77cf2a10, class org.alfresco.repo.audit.model._3.GenerateValue=java.lang.ref.WeakReference@41d2bde3, class org.alfresco.repo.audit.model._3.AuditPath=java.lang.ref.WeakReference@72b0a3d7, class org.alfresco.repo.audit.model._3.DataGenerator=java.lang.ref.WeakReference@2ad4b314, class org.alfresco.repo.audit.model._3.DataExtractor=java.lang.ref.WeakReference@7238fc03, class org.alfresco.repo.audit.model._3.DataExtractors=java.lang.ref.WeakReference@7b29638a, class org.alfresco.repo.audit.model._3.DataGenerators=java.lang.ref.WeakReference@5a463831, class org.alfresco.repo.audit.model._3.Application=java.lang.ref.WeakReference@38134744, class org.alfresco.repo.audit.model._3.PathMap=java.lang.ref.WeakReference@79abde1e, class javax.xml.bind.annotation.W3CDomHandler=java.lang.ref.WeakReference@283c1fa, class org.alfresco.repo.audit.model._3.PathMappings=java.lang.ref.WeakReference@18340560, class java.util.ArrayList=java.lang.ref.WeakReference@7f4cee09}]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Oct 16, 2012 10:43:23 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory /opt/alfresco-4.2.a/tomcat/webapps/manager
INFO: Deploying web application directory /opt/alfresco-4.2.a/tomcat/webapps/ROOT
INFO: Deploying web application directory /opt/alfresco-4.2.a/tomcat/webapps/host-manager
Oct 16, 2012 10:43:23 AM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-apr-8080"]
INFO: Starting ProtocolHandler ["ajp-apr-8009"]
INFO: Starting ProtocolHandler ["http-bio-8443"]
Oct 16, 2012 10:43:23 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 223359 ms
Oct 16, 2012 10:43:23 AM org.apache.catalina.loader.WebappClassLoader loadClass
INFO: Illegal access: this web application instance has been stopped already. Could not load org.bouncycastle.jce.provider.symmetric.AES$ECB. The eventual following stack trace is caused by an error thrown for debugging purposes as well as to attempt to terminate the thread which caused the illegal access, and has no functional impact.
java.lang.IllegalStateException
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1600)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1559)
at java.security.Provider$Service.getImplClass(Provider.java:1279)
at java.security.Provider$Service.newInstance(Provider.java:1237)
at javax.crypto.Cipher.chooseProvider(Cipher.java:845)
at javax.crypto.Cipher.init(Cipher.java:1348)
at sun.security.ssl.CipherBox.<init>(CipherBox.java:175)
at sun.security.ssl.CipherBox.newCipherBox(CipherBox.java:208)
at sun.security.ssl.CipherSuite$BulkCipher.newCipher(CipherSuite.java:467)
at sun.security.ssl.CipherSuite$BulkCipher.isAvailable(CipherSuite.java:507)
at sun.security.ssl.CipherSuite$BulkCipher.isAvailable(CipherSuite.java:485)
at sun.security.ssl.CipherSuite.isAvailable(CipherSuite.java:190)
at sun.security.ssl.SSLContextImpl.getApplicableCipherSuiteList(SSLContextImpl.java:342)
at sun.security.ssl.SSLContextImpl.getDefaultCipherSuiteList(SSLContextImpl.java:293)
at sun.security.ssl.SSLSocketImpl.init(SSLSocketImpl.java:576)
at sun.security.ssl.SSLSocketImpl.<init>(SSLSocketImpl.java:494)
at sun.security.ssl.SSLServerSocketImpl.accept(SSLServerSocketImpl.java:313)
at org.apache.tomcat.util.net.jsse.JSSESocketFactory.acceptSocket(JSSESocketFactory.java:182)
at org.apache.tomcat.util.net.JIoEndpoint$Acceptor.run(JIoEndpoint.java:216)
Oct 16, 2012 10:43:24 AM org.apache.catalina.loader.WebappClassLoader loadClass
Oct 16, 2012 10:43:24 AM org.quartz.core.JobRunShell run
SEVERE: Job Solr.CoreTracker-alfresco threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 09160001 GetModelsDiff return status is 404
at org.alfresco.solr.client.SOLRAPIClient.getModelsDiff(SOLRAPIClient.java:1036)
at org.alfresco.solr.tracker.CoreTracker.trackModels(CoreTracker.java:1863)
at org.alfresco.solr.tracker.CoreTracker.trackRepository(CoreTracker.java:1202)
at org.alfresco.solr.tracker.CoreTracker.updateIndex(CoreTracker.java:548)
at org.alfresco.solr.tracker.CoreTrackerJob.execute(CoreTrackerJob.java:45)
SEVERE: Job Solr.CoreTracker-archive threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 09160000 GetModelsDiff return status is 404
Oct 16, 2012 10:43:24 AM org.quartz.core.ErrorLogger schedulerError
SEVERE: Job (Solr.CoreTracker-archive threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 09160000 GetModelsDiff return status is 404]
at org.quartz.core.JobRunShell.run(JobRunShell.java:227)
Caused by: org.alfresco.error.AlfrescoRuntimeException: 09160000 GetModelsDiff return status is 404
… 1 more
SEVERE: Job (Solr.CoreTracker-alfresco threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 09160001 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 09160001 GetModelsDiff return status is 404
… 1 more
Oct 16, 2012 10:43:30 AM org.quartz.core.JobRunShell run
org.alfresco.error.AlfrescoRuntimeException: 09160002 GetModelsDiff return status is 404
Oct 16, 2012 10:43:30 AM org.quartz.core.ErrorLogger schedulerError
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 09160002 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 09160002 GetModelsDiff return status is 404
… 1 more
org.alfresco.error.AlfrescoRuntimeException: 09160003 GetModelsDiff return status is 404
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 09160003 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 09160003 GetModelsDiff return status is 404
… 1 more
Oct 16, 2012 10:43:45 AM org.quartz.core.JobRunShell run
org.alfresco.error.AlfrescoRuntimeException: 09160004 GetModelsDiff return status is 404
Oct 16, 2012 10:43:45 AM org.quartz.core.ErrorLogger schedulerError
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 09160004 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 09160004 GetModelsDiff return status is 404
… 1 more
org.alfresco.error.AlfrescoRuntimeException: 09160005 GetModelsDiff return status is 404
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 09160005 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 09160005 GetModelsDiff return status is 404
… 1 more
Oct 16, 2012 10:44:00 AM org.quartz.core.JobRunShell run
org.alfresco.error.AlfrescoRuntimeException: 09160006 GetModelsDiff return status is 404
Oct 16, 2012 10:44:00 AM org.quartz.core.ErrorLogger schedulerError
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 09160006 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 09160006 GetModelsDiff return status is 404
… 1 more
org.alfresco.error.AlfrescoRuntimeException: 09160007 GetModelsDiff return status is 404
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 09160007 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 09160007 GetModelsDiff return status is 404
… 1 more
