Hello I've upgraded from the version 3.4.e to the version 4.0.d and I have an exception in my alfresco.log.This exception is thrown every 10-30 minutes, not in a regular way.Here is my complete alfresco.log
10:16:18,454 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'sysAdmin' subsystem, ID: [sysAdmin, default]
10:16:18,533 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'sysAdmin' subsystem, ID: [sysAdmin, default] complete
10:16:28,189 WARN [org.alfresco.util.AbstractTriggerBean] Job ehCacheTracerJob is not active/enabled
10:16:31,548 INFO [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor Repository Template Processor for extension ftl
10:16:31,548 INFO [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor Repository Script Processor for extension js
10:16:39,142 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
10:16:40,908 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
10:16:41,236 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Search' subsystem, ID: [Search, managed, solr]
10:16:41,579 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Search' subsystem, ID: [Search, managed, solr] complete
10:16:41,970 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'thirdparty' subsystem, ID: [thirdparty, default]
10:16:42,111 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'thirdparty' subsystem, ID: [thirdparty, default] complete
10:16:42,111 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'OOoDirect' subsystem, ID: [OOoDirect, default]
10:16:43,095 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'OOoDirect' subsystem, ID: [OOoDirect, default] complete
10:16:43,204 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco-com40d\alf_data
10:16:43,204 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
10:16:44,408 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
10:16:44,423 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
10:16:44,470 INFO [org.alfresco.repo.module.ModuleServiceImpl] Starting module 'org_alfresco_module_wcmquickstart' version 1.0.
10:16:44,486 DEBUG [org.alfresco.repo.module.ModuleComponentHelper] Started module 'ModuleDetails[{module.version=1.0, module.description=Web Quick Start, module.id=org_alfresco_module_wcmquickstart, module.repo.version.max=999, module.title=Web Quick Start, module.repo.version.min=3.3, module.installState=INSTALLED, module.installDate=2012-05-07T16:22:27.260+02:00}]' including 0components.
10:16:44,501 DEBUG [org.alfresco.repo.module.ModuleComponentHelper] Installed module found in distribution: org_alfresco_module_wcmquickstart
10:16:44,501 WARN [org.alfresco.repo.module.ModuleServiceImpl] A previously-installed module 'org.alfresco.module.quickr' (version 1.0) is not present in your distribution.
10:16:44,517 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'fileServers' subsystem, ID: [fileServers, default]
10:16:45,189 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
10:16:45,376 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] complete
10:16:45,376 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, passthru1]
10:16:45,533 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, passthru1] complete
10:16:45,533 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, ldap1]
10:16:45,751 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, ldap1] complete
10:16:45,814 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'fileServers' subsystem, ID: [fileServers, default] complete
10:16:45,814 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'imap' subsystem, ID: [imap, default]
10:16:45,954 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'imap' subsystem, ID: [imap, default] complete
10:16:45,954 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'email' subsystem, ID: [email, outbound]
10:16:46,079 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'email' subsystem, ID: [email, outbound] complete
10:16:46,079 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'email' subsystem, ID: [email, inbound]
10:16:46,392 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'email' subsystem, ID: [email, inbound] complete
10:16:46,392 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'googledocs' subsystem, ID: [googledocs, default]
10:16:46,470 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'googledocs' subsystem, ID: [googledocs, default] complete
10:16:46,470 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Subscriptions' subsystem, ID: [Subscriptions, default]
10:16:46,486 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Subscriptions' subsystem, ID: [Subscriptions, default] complete
10:16:46,486 INFO [org.alfresco.repo.usage.UserUsageTrackingComponent] Disabled - clear non-missing user usages …
10:16:46,501 INFO [org.alfresco.repo.usage.UserUsageTrackingComponent] Found 0 users to clear
10:16:46,501 INFO [org.alfresco.repo.usage.UserUsageTrackingComponent] … cleared non-missing usages for 0 users
10:16:46,501 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Synchronization' subsystem, ID: [Synchronization, default]
10:16:46,595 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] Synchronizing users and groups with user registry 'ldap1'
10:16:46,611 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] Retrieving groups changed since 7-mag-2012 14.57.46 from user registry 'ldap1'
10:16:46,658 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] ldap1 Group Analysis: Commencing batch of 0 entries
10:16:46,658 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] ldap1 Group Analysis: Completed batch of 0 entries
10:16:46,658 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] Retrieving users changed since 17-apr-2012 10.23.06 from user registry 'ldap1'
10:16:46,673 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] ldap1 User Creation and Association: Commencing batch of 0 entries
10:16:46,673 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] ldap1 User Creation and Association: Completed batch of 0 entries
10:16:46,736 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] Finished synchronizing users and groups with user registry 'ldap1'
10:16:46,736 INFO [org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer] 0 user(s) and 0 group(s) processed
10:16:46,751 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Synchronization' subsystem, ID: [Synchronization, default] complete
10:16:46,892 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_26-b03; maximum heap size 4551,125MB
10:16:46,908 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community). Current version: 4.0.0 (4003) schema 5.025. Originally installed version: 3.4.0 (e 3419) schema 4.113.
10:16:46,908 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'ActivitiesFeed' subsystem, ID: [ActivitiesFeed, default]
10:16:46,986 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'ActivitiesFeed' subsystem, ID: [ActivitiesFeed, default] complete
10:16:46,986 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Replication' subsystem, ID: [Replication, default]
10:16:47,001 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Replication' subsystem, ID: [Replication, default] complete
10:17:00,642 WARN [org.springframework.extensions.webscripts.DeclarativeRegistry] Unable to register script classpath:webscripts/org/springframework/extensions/cmis/content.get.desc.xml due to error: 04090000 Web Script document org/springframework/extensions/cmis/content.get.desc.xml is attempting to define the url '/cmis/content:GET' already defined by org/alfresco/cmis/client/content.get.desc.xml
10:17:00,642 INFO [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 476 Web Scripts (+1 failed), 744 URLs
10:17:00,642 INFO [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 2 Package Description Documents (+0 failed)
10:17:00,642 INFO [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 1 Schema Description Documents (+0 failed)
10:17:00,642 INFO [org.springframework.extensions.webscripts.AbstractRuntimeContainer] Initialised Repository Web Script Container (in 8638.66ms)
10:17:00,704 INFO [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
10:17:00,704 INFO [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
10:23:40,392 WARN [org.alfresco.web.app.servlet.AuthenticationHelper] Unable to login as Guest: 04090149 Accesso Negato. Non si dispone di permessi appropriati per eseguire questa operazione.
11:06:00,126 ERROR [org.quartz.core.JobRunShell] Job DEFAULT.org.springframework.scheduling.quartz.MethodInvokingJobDetailFactoryBean#59d6e3d2 threw an unhandled Exception:
org.springframework.scheduling.quartz.JobMethodInvocationFailedException: Invocation of method 'run' on target class [class org.alfresco.module.org_alfresco_module_wcmquickstart.jobs.DynamicCollectionProcessor] failed; nested exception is org.alfresco.repo.search.impl.lucene.LuceneQueryParserException: 04090234
at org.springframework.scheduling.quartz.MethodInvokingJobDetailFactoryBean$MethodInvokingJob.executeInternal(MethodInvokingJobDetailFactoryBean.java:273)
at org.springframework.scheduling.quartz.QuartzJobBean.execute(QuartzJobBean.java:86)
Caused by: org.alfresco.repo.search.impl.lucene.LuceneQueryParserException: 04090234
at org.alfresco.repo.search.impl.solr.SolrQueryHTTPClient.executeQuery(SolrQueryHTTPClient.java:364)
at org.alfresco.repo.search.impl.solr.SolrQueryLanguage.executeQuery(SolrQueryLanguage.java:49)
at org.alfresco.repo.search.impl.solr.SolrSearchService.query(SolrSearchService.java:348)
at org.alfresco.repo.search.impl.solr.SolrSearchService.query(SolrSearchService.java:152)
at org.alfresco.repo.search.SearcherComponent.query(SearcherComponent.java:67)
at org.alfresco.repo.search.AbstractSearcherComponent.query(AbstractSearcherComponent.java:53)
at sun.reflect.GeneratedMethodAccessor637.invoke(Unknown Source)
at org.alfresco.repo.management.subsystems.SubsystemProxyFactory$1.invoke(SubsystemProxyFactory.java:65)
at $Proxy13.query(Unknown Source)
at org.alfresco.module.org_alfresco_module_wcmquickstart.jobs.DynamicCollectionProcessor$1$1.execute(DynamicCollectionProcessor.java:114)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:388)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:259)
at org.alfresco.module.org_alfresco_module_wcmquickstart.jobs.DynamicCollectionProcessor$1.doWork(DynamicCollectionProcessor.java:107)
at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:519)
at org.alfresco.module.org_alfresco_module_wcmquickstart.jobs.DynamicCollectionProcessor.run(DynamicCollectionProcessor.java:102)
at sun.reflect.GeneratedMethodAccessor913.invoke(Unknown Source)
at org.springframework.util.MethodInvoker.invoke(MethodInvoker.java:273)
at org.springframework.scheduling.quartz.MethodInvokingJobDetailFactoryBean$MethodInvokingJob.executeInternal(MethodInvokingJobDetailFactoryBean.java:264)
… 3 more
Caused by: java.net.SocketException: Software caused connection abort: recv failed
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(SocketInputStream.java:129)
at com.sun.net.ssl.internal.ssl.InputRecord.readFully(InputRecord.java:293)
at com.sun.net.ssl.internal.ssl.InputRecord.read(InputRecord.java:331)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:798)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:755)
at com.sun.net.ssl.internal.ssl.AppInputStream.read(AppInputStream.java:75)
at java.io.BufferedInputStream.fill(BufferedInputStream.java:218)
at java.io.BufferedInputStream.read(BufferedInputStream.java:237)
at org.apache.commons.httpclient.HttpParser.readRawLine(HttpParser.java:78)
at org.apache.commons.httpclient.HttpParser.readLine(HttpParser.java:106)
at org.apache.commons.httpclient.HttpConnection.readLine(HttpConnection.java:1116)
at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.readLine(MultiThreadedHttpConnectionManager.java:1413)
at org.apache.commons.httpclient.HttpMethodBase.readStatusLine(HttpMethodBase.java:1973)
at org.apache.commons.httpclient.HttpMethodBase.readResponse(HttpMethodBase.java:1735)
at org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1098)
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398)
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
at org.alfresco.repo.search.impl.solr.SolrQueryHTTPClient.executeQuery(SolrQueryHTTPClient.java:318)
… 26 more
11:06:00,142 ERROR [org.quartz.core.ErrorLogger] Job (DEFAULT.org.springframework.scheduling.quartz.MethodInvokingJobDetailFactoryBean#59d6e3d2 threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.springframework.scheduling.quartz.JobMethodInvocationFailedException: Invocation of method 'run' on target class [class org.alfresco.module.org_alfresco_module_wcmquickstart.jobs.DynamicCollectionProcessor] failed; nested exception is org.alfresco.repo.search.impl.lucene.LuceneQueryParserException: 04090234 ]
at org.quartz.core.JobRunShell.run(JobRunShell.java:227)
Caused by: org.springframework.scheduling.quartz.JobMethodInvocationFailedException: Invocation of method 'run' on target class [class org.alfresco.module.org_alfresco_module_wcmquickstart.jobs.DynamicCollectionProcessor] failed; nested exception is org.alfresco.repo.search.impl.lucene.LuceneQueryParserException: 04090234
… 1 more
… 3 more
… 26 more
All seems to work fine,I do not use the module web quick start even if I have installed it.How can I investigate this problem?Thank you in advance.
