Hi, I am new to Alfresco, I have created a process in jpdl having two task. When I add the "snowstorm-model-context.xml" to "tomcat\shared\classes\alfresco\extension\" folder the server is not started properly and it gives following error
SEVERE: Job Solr.CoreTracker-archive threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 09080001 GetModelsDiff return status is 404
at org.alfresco.solr.client.SOLRAPIClient.getModelsDiff(SOLRAPIClient.java:1010)
at org.alfresco.solr.tracker.CoreTracker.trackModels(CoreTracker.java:1630)
at org.alfresco.solr.tracker.CoreTracker.trackRepository(CoreTracker.java:1134)
at org.alfresco.solr.tracker.CoreTracker.updateIndex(CoreTracker.java:491)
at org.alfresco.solr.tracker.CoreTrackerJob.execute(CoreTrackerJob.java:45)
processdefinition.xml
<process-definition xmlns="urn:jbpm.org:jpdl-3.2" name="sswf:Sample">
<swimlane name="initiator"></swimlane>
<start-state name="start">
<task swimlane="initiator" name="sswf:startProcess"></task>
<transition to="task1"></transition>
</start-state>
<task-node name="task1">
<task name="sswf:task1" swimlane="initiator"></task>
<transition to="task2"></transition>
</task-node>
<task-node name="task2">
<task name="sswf:task2" swimlane="initiator"></task>
<transition to="end"></transition>
</task-node>
<end-state name="end"></end-state>
</process-definition>
<beans>
<bean id="extension.dictionaryBootstrap" parent="dictionaryModelBootstrap" depends-on="dictionaryBootstrap">
<property name="models">
<list>
<value>alfresco/extension/snowstormWFModel.xml</value>
</list>
</property>
</bean>
<!– Registration of resource bundles –>
<bean id="extension.workflowBootstrap"
parent="workflowDeployer">
<property name="workflowDefinitions">
<list>
<props>
<prop key="engineId">jbpm</prop>
<prop key="location">alfresco/extension/workflows/snowstorm2/processdefinition.xml</prop>
<prop key="mimetype">text/xml</prop>
<prop key="redeploy">true</prop>
</props>
</list>
</property>
<property name="labels">
<list>
<value>alfresco.extension.snowstormWFModel</value>
</list>
</property>
</bean>
</beans>
snowstormWFModel.properties
# Credit Request workflow properties
sswf_Sample.workflow.title=Snowstorm Workflow Sample
sswf_Sample.workflow.description=Testing WorkFlow
sswf_snowstormWorkflow.type.sswf_startProcess.title=Start Process
sswf_snowstormWorkflow.type.sswf_startProcess.description=Start Process Description
sswf_snowstormWorkflow.type.sswf_task1.title=Task 1
sswf_snowstormWorkflow.type.sswf_task1.description=Task 1 description
sswf_snowstormWorkflow.type.sswf_task2.title=Task 2
sswf_snowstormWorkflow.type.sswf_task2.description=Task 2 description
<!– definition of the workflow model for document validation process –>
<model name="sswf:snowstormWorkflow" xmlns="http://www.alfresco.org/model/dictionary/1.0">
<description> Snowstorm Workflow Model </description>
<author>Shahid Iqbal</author>
<version>1.0</version>
<imports>
<import uri="http://www.alfresco.org/model/dictionary/1.0"
prefix="d" />
<import uri="http://www.alfresco.org/model/bpm/1.0" prefix="bpm" />
</imports>
<namespaces>
<namespace uri="http://www.ensias.ma/model/cr/1.0" prefix="sswf" />
</namespaces>
<types>
<!– Start Process task –>
<type name="sswf:startProcess">
<parent>bpm:startTask</parent>
<properties>
<property name="sswf:firstName">
<title>First Name</title>
<type>d:text</type>
</property>
<property name="sswf:lastName">
<title>Last Name</title>
<type>d:text</type>
</property>
<property name="sswf:adress">
<title>Address</title>
<type>d:text</type>
</property>
<property name="sswf:creditAmount">
<title>Credit Amount</title>
<type>d:float</type>
</property>
<property name="sswf:requestNumber">
<title>Request Number</title>
<type>d:int</type>
</property>
</properties>
</type>
<!– Task 2 model –>
<type name="sswf:task1">
<parent>sswf:startProcess</parent>
<properties>
<property name="sswf:comments">
<title>Comments</title>
<type>d:text</type>
</property>
</properties>
</type>
<!– <type name="sswf:reviseRequest">
<parent>sswf:studyCreditRequest</parent>
</type> –>
<type name="sswf:task2">
<parent>sswf:creditRequest</parent>
<properties>
<property name="sswf:Amount">
</property>
<property name="sswf:creditRate">
</property>
<property name="sswf:creditPeriode">
<type>d:text</type>
</property>
</properties>
</type>
<!– <type name="sswf:studyOffer">
<parent>sswf:prepareOffer</parent>
</type>
<type name="sswf:consultOffer">
</type> –>
</types>
</model>
If there is any mistake please let me know.Thanks!
