I customized advanced search like this:
<config replace="false" evaluator="string-compare" condition="AdvancedSearch">
<advanced-search>
<forms>
<form labelId="rev.search.label" descriptionId="rev.search.description">ag:rev</form>
</forms>
</advanced-search>
</config>
I also defined search form for the type:
<config evaluator="node-type" condition="ag:rev">
<forms>
<form>
… default form is the same as search form …
</form>
<form id="search">
<field-visibility>
<show id="ag:revNum"/>
<show id="ag:lmqSerial"/>
<show id="ag:prevLmqSerial"/>
<show id="ag:oe"/>
<show id="ag:sm"/>
<show id="ag:location"/>
<show id="ag:locCode"/>
<show id="ag:room"/>
<show id="ag:invNum"/>
<show id="ag:revDate"/>
<show id="ag:installed"/>
<show id="ag:sent"/>
</field-visibility>
<appearance>
<set id="reverse" appearance="bordered-panel" label-id="rev.set"/>
<field id="ag:revNum" label-id="rev.revNum" set="reverse"/>
<field id="ag:lmqSerial" label-id="rev.lmqSerial" set="reverse"/>
<field id="ag:prevLmqSerial" label-id="rev.prevLmqSerial" set="reverse"/>
<field id="ag:oe" label-id="rev.oe" set="reverse"/>
<field id="ag:sm" label-id="rev.sm" set="reverse"/>
<field id="ag:location" label-id="rev.location" set="reverse"/>
<field id="ag:locCode" label-id="rev.locCode" set="reverse"/>
<field id="ag:room" label-id="rev.room" set="reverse"/>
<field id="ag:invNum" label-id="rev.invNum" set="reverse"/>
<field id="ag:revDate" label-id="rev.revDate" set="reverse"/>
<field id="ag:installed" label-id="rev.installed" set="reverse"/>
<field id="ag:sent" label-id="rev.sent" set="reverse"/>
</appearance>
</form>
</forms>
</config>
Then when I go to advanced search and search on some property I get this in logs:
13:31:26,962 User:admin ERROR [freemarker.runtime] Expression jsonUtils.encodeJSONString(x) is undefined on line 2, column 15 in org/alfresco/slingshot/search/search.get.json.ftl.
The problematic instruction:
==> ${item.site.shortName} escaped ${jsonUtils.encodeJSONString(item.site.shortName)} [on line 23, column 47 in org/alfresco/slingshot/search/search.get.json.ftl]
Java backtrace for programmers:
freemarker.core.InvalidReferenceException: Expression jsonUtils.encodeJSONString(x) is undefined on line 2, column 15 in org/alfresco/slingshot/search/search.get.json.ftl.
at freemarker.core.TemplateObject.assertNonNull(TemplateObject.java:124)
at freemarker.core.Expression.getStringValue(Expression.java:118)
at freemarker.core.Expression.getStringValue(Expression.java:93)
at freemarker.core.DollarVariable.accept(DollarVariable.java:76)
at freemarker.core.Environment.visit(Environment.java:210)
at freemarker.core.MixedContent.accept(MixedContent.java:92)
at freemarker.core.ConditionalBlock.accept(ConditionalBlock.java:79)
at freemarker.core.IteratorBlock$Context.runLoop(IteratorBlock.java:179)
at freemarker.core.Environment.visit(Environment.java:417)
at freemarker.core.IteratorBlock.accept(IteratorBlock.java:102)
at freemarker.core.EscapeBlock.accept(EscapeBlock.java:84)
at freemarker.core.Environment.process(Environment.java:190)
at freemarker.template.Template.process(Template.java:237)
at org.alfresco.repo.template.FreeMarkerProcessor.process(FreeMarkerProcessor.java:197)
at org.springframework.extensions.webscripts.AbstractWebScript.renderTemplate(AbstractWebScript.java:589)
at org.springframework.extensions.webscripts.DeclarativeWebScript.renderFormatTemplate(DeclarativeWebScript.java:267)
at org.springframework.extensions.webscripts.DeclarativeWebScript.execute(DeclarativeWebScript.java:147)
at org.alfresco.repo.web.scripts.RepositoryContainer$2.execute(RepositoryContainer.java:377)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:381)
at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecute(RepositoryContainer.java:436)
at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecuteAs(RepositoryContainer.java:466)
at org.alfresco.repo.web.scripts.RepositoryContainer.executeScript(RepositoryContainer.java:304)
at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:333)
at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:189)
at org.alfresco.web.app.servlet.GlobalLocalizationFilter.doFilter(GlobalLocalizationFilter.java:58)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:852)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
13:31:26,964 ERROR [extensions.webscripts.AbstractRuntime] Exception from executeScript - redirecting to status template error: 01290006 Wrapped Exception (with status template): 01290018 Error during processing of the template 'Expression jsonUtils.encodeJSONString(x) is undefined on line 2, column 15 in org/alfresco/slingshot/search/search.get.json.ftl.'. Please contact your system administrator.
org.springframework.extensions.webscripts.WebScriptException: 01290006 Wrapped Exception (with status template): 01290018 Error during processing of the template 'Expression jsonUtils.encodeJSONString(x) is undefined on line 2, column 15 in org/alfresco/slingshot/search/search.get.json.ftl.'. Please contact your system administrator.
at org.springframework.extensions.webscripts.AbstractWebScript.createStatusException(AbstractWebScript.java:758)
Caused by: org.alfresco.service.cmr.repository.TemplateException: 01290018 Error during processing of the template 'Expression jsonUtils.encodeJSONString(x) is undefined on line 2, column 15 in org/alfresco/slingshot/search/search.get.json.ftl.'. Please contact your system administrator.
at org.alfresco.repo.template.FreeMarkerProcessor.process(FreeMarkerProcessor.java:201)
… 24 more
Caused by: freemarker.core.InvalidReferenceException: Expression jsonUtils.encodeJSONString(x) is undefined on line 2, column 15 in org/alfresco/slingshot/search/search.get.json.ftl.
… 27 more
